Inverter recommendation
11-26-2007, 13:15
Considering adding an inverter to my 86 PT38. A few questions:
1) Any suggestions on models? 2) How hard is it to install one of these? 3) I would like to be able to run TV, DVD, outside entertainment center, etc. off inverter. Is this reasonable to expect? Thanks Scott Forman 86 PT38 Memphis |
11-26-2007, 13:40
Scott I would suggest the Magnum MS series inverter/ charger. I had mine installed,and are going back this week to install a solar panel, at D&R in Glendale AZ.It runs all those items you mentioned. Mario 1985FC35 Leucadia CA. In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Considering adding an inverter to my 86 PT38. A few questions: > > 1) Any suggestions on models? > 2) How hard is it to install one of these? > 3) I would like to be able to run TV, DVD, outside entertainment > center, etc. off inverter. Is this reasonable to expect? > > Thanks > Scott Forman > 86 PT38 > Memphis > |
11-27-2007, 03:04
Scott,
I ran 3 TV cables to pass through curb side bay (satellite, shore, stand-up antenna), installed a JVC CD/radio, TV, DVD player, Sirius satellite radio, speakers, small inverter, added 12v fuse and ground panels, installed a 12V master switch ahead of the 12V fuse panel. The TV runs off the inverter. The inverter is plugged into the factory installed 12V receptacle in the bay. Let me know if you need more detail. On Nov 26, 2007 5:40 PM, mariopatti1 > --- > Scott I would suggest the Magnum MS series inverter/ charger. > I had mine installed,and are going back this week to install a solar > panel, at D&R in Glendale AZ.It runs all those items you mentioned. > Mario 1985FC35 Leucadia CA. > In WanderlodgeForum@yahoogroups.com > "Scott Forman" <sforman@...> > > wrote: > > > > Considering adding an inverter to my 86 PT38. A few questions: > > > > 1) Any suggestions on models? > > 2) How hard is it to install one of these? > > 3) I would like to be able to run TV, DVD, outside entertainment > > center, etc. off inverter. Is this reasonable to expect? > > > > Thanks > > Scott Forman > > 86 PT38 > > Memphis > > > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
