Detroit 6V92 High Idle
01-24-2008, 13:37
Hi everybody. I been here a long time but just read, generally. Been
runnin' Birds since '94, on our 3rd now, an '83 PT35 that we've had for a little over 11 years. My high idle doesn't seem to want to kick in when I throw the switch. It over-rides the foot throttle, as normal, but only increases rpm by maybe 50. Definitely not normal. When High Idle is off the foot throttle seems normal. Since I live in NV I never use the cruise and, as far as I know, all of the original parts are still in the system. Could that be part of the problem? Dennis Davis '83 PT35 Las Vegas, NV "LOONEYBIN" |
01-24-2008, 15:15
Hi Dennis:
Your high idle and cruise are separate systems. Since your rpm's are increasing, it sounds like the transducer in the rear is loose. Open the engine compartment and while facing the 6v on your peft side of the engine, up high on the side of a grey/silver box, you should see a round cylinder about the size of your finger and it will be partially behind the turbo exhaust tube. That is the transducer at the end run of the high idle. See if it is loose. If it is, start the Coach and adjust for the proper high idle rpm (between 750 and 1000 rpm?) Inside the transducer ( small cylinder) is a plunger that goes in against a bell crank to raise the rpm's, that bell crank and or plunger can and does get worn. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 01:37 AM 1/25/2008 +0000, you wrote: >Hi everybody. I been here a long time but just read, generally. Been >runnin' Birds since '94, on our 3rd now, an '83 PT35 that we've had >for a little over 11 years. My high idle doesn't seem to want to kick >in when I throw the switch. It over-rides the foot throttle, as >normal, but only increases rpm by maybe 50. Definitely not normal. >When High Idle is off the foot throttle seems normal. Since I live in >NV I never use the cruise and, as far as I know, all of the original >parts are still in the system. Could that be part of the problem? > Dennis Davis > > '83 PT35 > Las Vegas, NV > "LOONEYBIN" > > > |
01-24-2008, 15:52
Thanks, Ralph. I'll take a look at that and let you know. Nice to
talk to you. I followed you through Camping World's University. I only took several modules, but enjoyed those courses enormously. I have followed your activities on this site for quite some time and am very glad you are well and everything seems to be going well for you. Again, Thank you. Dennis Davis 83 PT 35 Las Vegas, Nevada "Looneybin" |
01-24-2008, 16:46
Ralph, is that high idle part that you refer to a Detroit part?
01-24-2008, 17:20
Dennis, I am not positive, it may have been a BB add on to the 6 and 8 v's.
The Allen Air metered air valve that the high idle switch activates is normally closed electrically held open and send metered air to that transducer/cylinder. I know you can't miss it when you look to the left of center up on the frontish side going into an enclosed part of the engine. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 04:46 AM 1/25/2008 +0000, you wrote: >Ralph, is that high idle part that you refer to a Detroit part? > Dennis Davis > '83 PT35 > Las Vegas, NV > "LOONEYBIN" > > > |
