Brake Lights and Hazard Flashers
02-01-2008, 08:27
Scott, mine act in the same manner. Someone with some good electrical savvy could help us out here. Ralph, is this a doable alternative?
Ernie Ekberg 83PT40 Weatherford, Tx Who's never won? Biggest Grammy Award surprises of all time on AOL Music. |
02-01-2008, 12:51
I asked this once before and got no response, thought I'd try again.
On my PT, the tail/brake lights and turn signals are not separated. This means that if the hazard flashers are on and I step on the brake, all the lights around the bus stop flashing. Is there a way to separate the brake lights? To me, the optimum situation would be if one of the two tail lights on each side worked as a brake light and one as a flasher...but I would settle for simply having the front & side lights continue to flash when the brake lights are activated. Any suggestions? Scott Forman 86 PT38 Memphis |
02-01-2008, 18:24
Scott Go back there and isolate the leads for the brakes and the signals..I don't think that you will find that the signals and the hazards are on seperate leads. on my coach they are on the port (driverside) I am guessing that someone connected them together, should be pretty easy to attch the leads to the lamps you want. jim riordan 88wbwl xxv stuart fl Scott Forman <sforman@...> wrote:
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. [url=http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR...o8Wcj9tAcJ ] Try it now.[/url] |
02-02-2008, 03:58
I thought the brakes and the directional filament were the same?
Greg --- In WanderlodgeForum@yahoogroups.com, jim riordan wrote: > > Scott > > Go back there and isolate the leads for the brakes and the signals..I don't think that you will find that the signals and the hazards are on seperate leads. on my coach they are on the port (driverside) I am guessing that someone connected them together, should be pretty easy to attch the leads to the lamps you want. > > jim riordan > 88wbwl xxv > stuart fl > Scott Forman <sforman@...> wrote: > I asked this once before and got no response, thought I'd try again. > > On my PT, the tail/brake lights and turn signals are not separated. > This means that if the hazard flashers are on and I step on the brake, > all the lights around the bus stop flashing. > > Is there a way to separate the brake lights? To me, the optimum > situation would be if one of the two tail lights on each side worked as > a brake light and one as a flasher...but I would settle for simply > having the front & side lights continue to flash when the brake lights > are activated. > > Any suggestions? > > Scott Forman > 86 PT38 > Memphis > > > > > > > --------------------------------- > Be a better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now. > |
02-02-2008, 04:08
They are, that is why I am looking for a way to separate the lights,
like my old FC-the bottom light was the tail/brake light and the top was the signal. Scott --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > I thought the brakes and the directional filament were the same? > Greg > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > wrote: > > > > Scott > > > > Go back there and isolate the leads for the brakes and the > signals..I don't think that you will find that the signals and the > hazards are on seperate leads. on my coach they are on the port > (driverside) I am guessing that someone connected them together, > should be pretty easy to attch the leads to the lamps you want. > > > > jim riordan > > 88wbwl xxv > > stuart fl > > Scott Forman <sforman@> wrote: > > I asked this once before and got no response, thought > I'd try again. > > > > On my PT, the tail/brake lights and turn signals are not > separated. > > This means that if the hazard flashers are on and I step on the > brake, > > all the lights around the bus stop flashing. > > > > Is there a way to separate the brake lights? To me, the optimum > > situation would be if one of the two tail lights on each side > worked as > > a brake light and one as a flasher...but I would settle for simply > > having the front & side lights continue to flash when the brake > lights > > are activated. > > > > Any suggestions? > > > > Scott Forman > > 86 PT38 > > Memphis > > > > > > > > > > > > > > --------------------------------- > > Be a better friend, newshound, and know-it-all with Yahoo! > Mobile. Try it now. > > > |
02-02-2008, 12:18
It may be easier to add a strobe kit to the head lights and
taillight/running light wire and remove the emergancy flasher. the more common the led bulbs s get the less noticable the filament lights become. I purchased some led screw-in bulbs for a tail-light retrofit attempt and the salesman warned me that I needed red led's in the bulb. His claim that the white bulbs would show up white even through the red lenz was correct!!!!!!!. Even when I reordered the red bulbs the result was disapointing. The red leds showed up like a big red dot and the bulds attempt to fill the lenz with light was poor. Tricklight.com has cool strobe kits GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > They are, that is why I am looking for a way to separate the lights, > like my old FC-the bottom light was the tail/brake light and the top > was the signal. > > Scott > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > I thought the brakes and the directional filament were the same? > > Greg > > > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > > wrote: > > > > > > Scott > > > > > > Go back there and isolate the leads for the brakes and the > > signals..I don't think that you will find that the signals and the > > hazards are on seperate leads. on my coach they are on the port > > (driverside) I am guessing that someone connected them together, > > should be pretty easy to attch the leads to the lamps you want. > > > > > > jim riordan > > > 88wbwl xxv > > > stuart fl > > > Scott Forman <sforman@> wrote: > > > I asked this once before and got no response, thought > > I'd try again. > > > > > > On my PT, the tail/brake lights and turn signals are not > > separated. > > > This means that if the hazard flashers are on and I step on the > > brake, > > > all the lights around the bus stop flashing. > > > > > > Is there a way to separate the brake lights? To me, the optimum > > > situation would be if one of the two tail lights on each side > > worked as > > > a brake light and one as a flasher...but I would settle for > simply > > > having the front & side lights continue to flash when the brake > > lights > > > are activated. > > > > > > Any suggestions? > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > Be a better friend, newshound, and know-it-all with Yahoo! > > Mobile. Try it now. > > > > > > |
02-03-2008, 03:25
This sounds like an application requiring diodes. (The selection of the diode is dependent on the current that it will be handling.) If you don't like the inherent .7 volt drop across the diode, the diode could activate an automotive relay similar to the common BB headlamp and rear lamp relay modifications. It's a matter of deciding exactly what you would like to see lit and when, then supplying that info to someone with basic electrical skills. The challenge is to find a tech capable of wiring it neatly and documenting the work for future service. Donn 76 FC33 South Kingstown, RI From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman Sent: Saturday, February 02, 2008 11:08 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Brake Lights and Hazard Flashers They are, that is why I am looking for a way to separate the lights, like my old FC-the bottom light was the tail/brake light and the top was the signal. Scott --- In WanderlodgeForum@yahoogroups.com > > I thought the brakes and the directional filament were the same? > Greg > > --- In WanderlodgeForum@yahoogroups.com > wrote: > > > > Scott > > > > Go back there and isolate the leads for the brakes and the > signals..I don't think that you will find that the signals and the > hazards are on seperate leads. on my coach they are on the port > (driverside) I am guessing that someone connected them together, > should be pretty easy to attch the leads to the lamps you want. > > > > jim riordan > > 88wbwl xxv > > stuart fl > > Scott Forman <sforman@> wrote: > > I asked this once before and got no response, thought > I'd try again. > > > > On my PT, the tail/brake lights and turn signals are not > separated. > > This means that if the hazard flashers are on and I step on the > brake, > > all the lights around the bus stop flashing. > > > > Is there a way to separate the brake lights? To me, the optimum > > situation would be if one of the two tail lights on each side > worked as > > a brake light and one as a flasher...but I would settle for simply > > having the front & side lights continue to flash when the brake > lights > > are activated. > > > > Any suggestions? > > > > Scott Forman > > 86 PT38 > > Memphis |
