Mounting things to the ceiling
02-15-2008, 08:17
On Thu, Feb 14, 2008 at 4:42 PM, martingregg598
> Come on Ryan, don't they make some super scientific mounting system out > there where you work? Probably, Marty. I should pickup some superconducting magnets, then I could just "stick" it to the ceiling. 'course I'd have to add a tank of LN2 to the coach to keep it up there... That could get interesting. John: On Thu, Feb 14, 2008 at 7:50 PM, John McGinnis > I thought the CO detector was mounted close to the floor in those > coaches that have the built in detector. You're thinking of propane sensors. Propane is significantly heavier than air. I don't know of many coaches with built in CO sensors, but C3H8 sensors are common. On my PT-40, turning the sensor on/off also turns the gas on/off, which is a nice safety feature in my opinion. -Ryan '86 PT-40 8V92 |
02-15-2008, 16:33
Ryan, I put a co2 detector above my bed (center queen). You should be able to use a half inch wood screw with out damaging the metal. If you did not want to put screw holes in the ceiling vinyl you could try velcro, but this would possibly make the vinyl sag...my factory installed gas detector is installed in the base of my dinette. Jim Riordan 88WBWL XXV Stuart, Fl. Ryan Wright
Be a better friend, newshound, and know-it-all with Yahoo! Mobile. [url=http://us.rd.yahoo.com/evt=51733/*http://mobile.yahoo.com/;_ylt=Ahu06i62sR...o8Wcj9tAcJ ] Try it now.[/url] |
