Radiator Rebuilt For Our 84FC
02-25-2008, 09:25
Eric, on my FC, the transmission cooler was placed, horizontally, under the curbside forward compartment. That location enabled a good deal of air movement. The unit was covered with a heavy screen, to keep rocks from stopping you on the side of the road with a leak. It worked very well, when I had the coach. In fact, a forum member, now owns that coach.
83PT40
Livingston, Montana
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
02-25-2008, 14:19
I opened the front of our coach today to check belts and attend to some small
A/F leaks. I
removed the radiator and took it to a local radiator shop. The radiator was
rodded out six
years ago but I've never been satisfied with the performance. I'm considering a
new core
rebuild rather than another clean out. I've been running Caterpillar extended
life pre-diluted
A/F on the cooling circuit so I don't believe I've got a bad fouling problem,
however the
exterior side of the fins look to be pretty well covered with corrosion scale.
We've discussed a similar subject on the forum awhile back and I remember Ernie
and others
suggested a separate transmission cooler as a good way to increase FC cooling
capacity. So
my personal debate is whether it would be better to replace the core or just rod
it out and
modify the transmission cooling circuit.
Any thoughts or suggestions from other FC owners would be appreciated.
Eric in San Antonio
84FC35SBWL2
02-26-2008, 13:54
--- In WanderlodgeForum@yahoogroups.com, "Eric Johnson"
some small A/F leaks. I
radiator was rodded out six
considering a new core
Caterpillar extended life pre-diluted
fouling problem, however the
corrosion scale.
remember Ernie and others
FC cooling capacity. So
core or just rod it out and
appreciated.
> Eric in San Antonio
> 84FC35SBWL2
eric iread your post about your radiator and somewhat of a heating
problem you are having. where is your sending unit for the
transmission located, mine was at the filter up high on the road
side. it was reading very high temps and as per advice from some
folks on this forum i moved the sending unit to the pan where the
transmission picks up the oil to use in the next cycle. the temps at
this location are lower and a new sending unit and guage have eased
my worries.
my problem a far as heating troubles is the engine oil temp. i
replaced the sending unit and the guage and my temps still hover
around 200-230f. when i replaced the sending unit it was already in
the pan so location was not the problem. i also replaced the engine
oil cooler. iam going to add and external oil cooler and the plan is
to place it in a location as near the front and in some sort of air
stream. i think this will solve my problem.
if it was me i would try to add and oil cooler. if you add the oil
cooler make sure in your plan that you add several valves to isolate
the cooler if need be in a hurry.
we sure did enjoy visiting with you and mary ann this trip and hope
you enjoyed the ralley also.
ed and peggy mcstay
"lonesome dove"
02-26-2008, 14:09
Ed,
I read your message three times to be sure it said oil temp. I am
curious as to why you think engine oil temp of 200-230F is a problem?
Sounds normal to me. ????
1991 WB40 "Texas Minivan"
--- In WanderlodgeForum@yahoogroups.com, "Peggy & Ed McStay"
> corrosion scale.
> appreciated.
> > Eric in San Antonio
> > 84FC35SBWL2
> my worries.
> ed and peggy mcstay
> "lonesome dove"
02-26-2008, 15:08
Last summer with the toter home, towing the 5th wheel gross wieght 42K. @ 2200 rpm 210/220 oil temp, 1700 rpm 170/180 oil temp. No extra oil cooler. The lesson is keep the engine speed down. Flat land FCs with turbo need 4:11.
MH
Sent: Tuesday, February 26, 2008 8:09 PM
Subject: [WanderlodgeForum] Re: Radiator Rebuilt For Our 84FC
Ed,
--- In "WanderlodgeForum@yahoogroups.com", "Peggy & Ed McStay"
> --- In "WanderlodgeForum@yahoogroups.com", "Eric Johnson"
> corrosion scale.
> appreciated.
> > Eric in San Antonio
> > 84FC35SBWL2
> my worries.
> ed and peggy mcstay
> "lonesome dove"
02-27-2008, 02:55
Interesting point about RPM Mike. We typically run 2600 cruising at 60-65 mph.
Changing the rear end would probably help. Cooling seems OK when running down
road but things start heating up when we slow down or start pulling hills. I
don't have an
engine oil temp on this coach just radiator temperature. When I talk about
heating up, I
mean the fan comes on from time to time. No boil over. I'm also towing a
heavier vehicle
now and that could be contributing to the engine and cooling load.
Thanks, Eric in San Antonio
84FC35SBWL2
--- In WanderlodgeForum@yahoogroups.com, "Mike Hohnstein" <MHOHNSTEIN@...>
2200 rpm
is keep
> MH
> From: mbulriss
> Ed,
> Mike Bulriss
> San Antonio, TX
> > corrosion scale.
> > appreciated.
> > > Eric in San Antonio
> > > 84FC35SBWL2
> > my worries.
> > ed and peggy mcstay
> > "lonesome dove"
02-27-2008, 06:48
Eric:
I have an 84 as well, mine with the 4:11 gears, but living in the hilly country of BC, I would rather go to the 4:63 gear setup. I do not have a problem on the hills with temperature, but I do go slow,I also pull a 10,000 lb trailer, usually fully loaded.
Mike is right though, on the flats, she just purrs along.
Terrace, B.C. Canada
Sent: Wednesday, February 27, 2008 6:55:52 AM
Changing the rear end would probably help. Cooling seems OK when running down the
road but things start heating up when we slow down or start pulling hills. I don't have an
engine oil temp on this coach just radiator temperature. When I talk about heating up, I
mean the fan comes on from time to time. No boil over. I'm also towing a heavier vehicle
84FC35SBWL2
--- In "WanderlodgeForum%40yahoogroups.com", "Mike Hohnstein" <MHOHNSTEIN@ ...>
> MH
> From: mbulriss
> Ed,
> Mike Bulriss
> San Antonio, TX
> --- In WanderlodgeForum@ yahoogroups.
com
> > --- In "WanderlodgeForum%40yahoogroups.com", "Eric Johnson"
> > corrosion scale.
> > appreciated.
> > > Eric in San Antonio
> > > 84FC35SBWL2
> > my worries.
problem.
> > ed and peggy mcstay
> > "lonesome dove"
Looking for the perfect gift? Give the gift of Flickr!
03-01-2008, 10:34
Hi Ed,
We also had a great time at the Spring Texas rally and hope we'll see you folks
again in
April. Seems to me that having some Louisiana Birds at the Lone Star rallies
sure adds a
lot of life to the party!
On the subject of the radiator, the shop advised me not to get a new core since
they
found less than 10% plugged tubes. They rodded it out and repaired a couple of
small
leaks on the top tank seams. I put it back in and ran down to I-10 to fill up
at the Flying J.
The coach jacket water temperature is running measurably cooler, slightly under
180
degrees, at 60-65 mph.
Looks like I cured the small hose leaks we noticed at the rally. Combination of
double
clamping those joints with the copper tubing and used gasket shellac with a
single clamp
on the pipe joints close to the block. Carefully positioned the clamps so they
can be
tightened up from below.
Eric in San Antonio
84FC35SBWL
> corrosion scale.
> appreciated.
> > Eric in San Antonio
> > 84FC35SBWL2
> my worries.
> ed and peggy mcstay
> "lonesome dove"
