Old Fuel ?
05-26-2008, 05:46
Old Fuel ?
With the price of a tank of fuel approching the value of the coach, it
is prudent to take shorter and fewer trips with our Birds. This
being the case, the coach may sit for months or more than a year
without being refuled. I hope the fuel seting in the tank will react
to getting old better than I do!
True, the fuel stabalizer will help, but will burning old gas or
diesel cause any problems in the engine? (This must be a concern for
Boaters, also).
What effect will old ethonol have on gasoline engines when they sit
for a while, (months or years)?
Any thoughts on this?
Jack Smith
1973-FC-31 (for sale)
SoCal
05-26-2008, 06:01
Old Fuel ?
Burning old diesel is no problem
but gas unless dosed up with fuel stabilizer can be
causes hard staring rough running and the varnish gums up the works
Stephen 77fc35 come and see us at dupreeproducts.com
--- In WanderlodgeForum@yahoogroups.com, "Jack & Donna Smith"
> Boaters, also).
> Jack Smith
> SoCal
05-26-2008, 06:41
Old Fuel ?
Another point to discuss is how many or how few miles does a person
have to "put on" a BB to make it worth keeping. Personally I would
sell my coach rather then "hurt" it by letting it sit. I drive mine at
least every couple weeks and plan to do that until.... but I understand
your question and perhaps your prespective. For me if I am not going to
use it and use it well I'll part with it and be happy with the
memories. I can't see having it unless you would be putting 4k a year
on it.
John Heckman
central Pa
1973 FC. PS. Thank you to all of you Vets. We should remember more
then once a year.
> Boaters, also).
> Jack Smith
> SoCal
05-26-2008, 07:06
Old Fuel ?
Jack, It is best to keep the tank
full because it prevents moisture from accumulating in the tank through
condensation. Also put in some biocide to kill microbes in the fuel.
Dan
88pt38
Jackson, MS
WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Jack & Donna Smith
Sent: Monday, May 26, 2008 12:47
PM
To:
wanderlodgeforum@yahoogroups.com
Subject: [WanderlodgeForum] Old
Fuel ?
of the coach, it
Boaters, also).
Jack Smith
SoCal
05-26-2008, 11:27
Old Fuel ?
How do you burn old diesel? I have about 300 gallons that I removed from my coach because it would not ignite.
Drdigger
83FC35
KCMO
Sent: Monday, May 26, 2008 1:01 PM
Subject: [WanderlodgeForum] Re: Old Fuel ?
--- In "WanderlodgeForum@yahoogroups.com", "Jack & Donna Smith"
> Boaters, also).
> Jack Smith
> SoCal
05-26-2008, 11:47
Old Fuel ?
That seems odd? I know a guy who was given an old '63 Gillig conversion last
month; it had been converted to an 8V92 in the past. It sat in a park for the
past 12+ years, having been relinquished for back rent close to that long ago.
He and a mechanic brought in a bank of batteries and started it up, and drove it
to his place a few miles away. This was in Redding, California, so it would have
been through cold and heat over those years.
>Drdigger
>83FC35
>KCMO
05-26-2008, 12:06
Old Fuel ?
This one set for years and when I got it I started it and drove it home. And a couple of times after and it ran like a top. Then last spring it wouldn't start and I fought it all summer. Would fire with a shot of ether, though, Finally got a mechanic out and bad fuel was his call and it appears correct as the diesel is off color and doesn't smell right.
In the process of purging all tanks, lines and filters, but still getting bad fuel sometimes. Coach is trying to start so we're getting closer
Sent: Monday, May 26, 2008 6:47 PM
Subject: Re: [WanderlodgeForum] Re: Old Fuel ?
That seems odd? I know a guy who was given an old '63 Gillig conversion last month; it had been converted to an 8V92 in the past. It sat in a park for the past 12+ years, having been relinquished for back rent close to that long ago. He and a mechanic brought in a bank of batteries and started it up, and drove it to his place a few miles away. This was in Redding, California, so it would have been through cold and heat over those years.
>Drdigger
>83FC35
>KCMO
05-26-2008, 14:18
Old Fuel ?
I think the secret is to stay longer at your destination. It does
cost a lot of money to run a coach, but if you plan your trip and
stay long enough it still beats a motel and riding in the car.
For me, it is a hobby; A hobby that has recently taken on a pretty
high cost. I have to rationalize it by knowing that I love the drive
in the Bird as much as the final destination.
I don't know how long I can hold onto the rationilizaton, but it's
my story and I'm stickin to it.
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "bubblerboy64"
person
would
mine at
understand
going to
year
> on it.
> John Heckman
> central Pa
more
> then once a year.
coach, it
react
concern for
> > Boaters, also).
sit
> > Jack Smith
> > SoCal
