Electric Heaters, galley, salon, bedroom-the long thin heaters
09-10-2008, 06:44
Has anyone found the direct replacement for the electric heaters
found in the Galley, Salon and Bedroom? Am familiar with the Cadet PerfectToe. I've replaced a few in the Prevost coaches. The PerfectToe heaters have not been tested and are NOT recommended for Vertical installations such as those in the Bedroom and Galley heaters in 80's Birds. Have researched the forum and read Dayton and Fasco names, but have not been able to find correct heaters by these companies. My heaters have been cleaned and they still operate, though with little air movement and limited high thermostat settings. Would like to just buy 3 new heaters to replace the originals and be done, not buying pieces and parts to recondition them. But will if thats the best answer ;~} Thanks jay darst 85PT40 91PrevostRoyale40XL 96PrevostCountryCoach40XL Sullivan, IL 217 - 971 - 0036 cell |
09-10-2008, 07:07
Do an Internet search on "toe heater".
On Wed, Sep 10, 2008 at 11:44 AM, Jay Darst <"jdarstpt40@yahoo.com"> wrote:
-- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA |
09-10-2008, 09:56
wrote: Jay I used this one in the bath room Dayton Fan force wall 3UG16D Grainger catalog page 3194.Tomorrow ill be going to my bird I can get you the info on the replacement for the bedroom. Bob Loomas 1985 PT 36 Harahan La. > > Has anyone found the direct replacement for the electric heaters > found in the Galley, Salon and Bedroom? > > Am familiar with the Cadet PerfectToe. I've replaced a few in the > Prevost coaches. The PerfectToe heaters have not been tested and are > NOT recommended for Vertical installations such as those in the > Bedroom and Galley heaters in 80's Birds. > > Have researched the forum and read Dayton and Fasco names, but have > not been able to find correct heaters by these companies. > > My heaters have been cleaned and they still operate, though with > little air movement and limited high thermostat settings. > > Would like to just buy 3 new heaters to replace the originals and be > done, not buying pieces and parts to recondition them. But will if > thats the best answer ;~} > > Thanks > jay darst > 85PT40 > 91PrevostRoyale40XL > 96PrevostCountryCoach40XL > Sullivan, IL > 217 - 971 - 0036 cell > |
09-10-2008, 10:42
Just got done replacing the bedroom and kitchen heaters with new
Cadet Perfectoe heaters. When I pulled the old ones out, they had stamped on them "No for vertical installation". Figured if old ones could be vertical, new ones could also. New ones are smaller, so had to modify openings. Bob Lawrence 84 PT36 Branson, Mo. (Still workcamping) > Jay I used this one in the bath room Dayton Fan force wall > 3UG16D Grainger catalog page 3194.Tomorrow ill be going to my bird > I can get you the info on the replacement for the bedroom. > Bob Loomas 1985 PT 36 > Harahan La. > > > > Has anyone found the direct replacement for the electric heaters > > found in the Galley, Salon and Bedroom? > > > > Am familiar with the Cadet PerfectToe. I've replaced a few in the > > Prevost coaches. The PerfectToe heaters have not been tested and > are > > NOT recommended for Vertical installations such as those in the > > Bedroom and Galley heaters in 80's Birds. > > > > Have researched the forum and read Dayton and Fasco names, but have > > not been able to find correct heaters by these companies. > > > > My heaters have been cleaned and they still operate, though with > > little air movement and limited high thermostat settings. > > > > Would like to just buy 3 new heaters to replace the originals and > be > > done, not buying pieces and parts to recondition them. But will if > > thats the best answer ;~} > > > > Thanks > > jay darst > > 85PT40 > > 91PrevostRoyale40XL > > 96PrevostCountryCoach40XL > > Sullivan, IL > > 217 - 971 - 0036 cell > > > |
09-11-2008, 04:11
Jay,
Nope, and I spent a good deal of time last year searching, too. My heaters move enough air but also have limited high thermostat settings which drives me to supplement with LP during the hard cold of winter. I've been considering installing an automation controller, replacing all heat & air thermostats with relays and temperature sensors, and controlling HVAC throughout the entire bus from a small touchpanel. This would allow me to set the heaters to any temperature and give me a single control point. Unfortunately it also requires a lot of time disassembling panels and running wires throughout the coach, which is why I've not done it yet. One thing you're going to notice, and the reason I gave up my search for new heaters, is that nobody makes a 20 amp 120 volt toe heater anymore. Your existing heaters are 20 amps a pop and the extra power is nice on a cold winter night. So even if you do find something that fits, it's not going to put out as much heat. If someone does happen to find 20 amp heaters that fit, they're going to sell a bunch of 'em. -Ryan '86 PT-40 8V92 On Wed, Sep 10, 2008 at 11:44 AM, Jay Darst > Has anyone found the direct replacement for the electric heaters > found in the Galley, Salon and Bedroom? > > Am familiar with the Cadet PerfectToe. I've replaced a few in the > Prevost coaches. The PerfectToe heaters have not been tested and are > NOT recommended for Vertical installations such as those in the > Bedroom and Galley heaters in 80's Birds. > > Have researched the forum and read Dayton and Fasco names, but have > not been able to find correct heaters by these companies. > > My heaters have been cleaned and they still operate, though with > little air movement and limited high thermostat settings. > > Would like to just buy 3 new heaters to replace the originals and be > done, not buying pieces and parts to recondition them. But will if > thats the best answer ;~} > > Thanks > jay darst > 85PT40 > 91PrevostRoyale40XL > 96PrevostCountryCoach40XL > Sullivan, IL > 217 - 971 - 0036 cell > > |
09-11-2008, 05:54
These heaters are not as wide as the ones in my coach, 17 3/4" but
they might work for you. http://www.heatersplus.com/qts.htm Kurt Horvath 95 PT-42 10AC --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > Jay, > > Nope, and I spent a good deal of time last year searching, too. My > heaters move enough air but also have limited high thermostat settings > which drives me to supplement with LP during the hard cold of winter. > I've been considering installing an automation controller, replacing > all heat & air thermostats with relays and temperature sensors, and > controlling HVAC throughout the entire bus from a small touchpanel. > This would allow me to set the heaters to any temperature and give me > a single control point. Unfortunately it also requires a lot of time > disassembling panels and running wires throughout the coach, which is > why I've not done it yet. > > One thing you're going to notice, and the reason I gave up my search > for new heaters, is that nobody makes a 20 amp 120 volt toe heater > anymore. Your existing heaters are 20 amps a pop and the extra power > is nice on a cold winter night. So even if you do find something that > fits, it's not going to put out as much heat. > > If someone does happen to find 20 amp heaters that fit, they're going > to sell a bunch of 'em. > > -Ryan > '86 PT-40 8V92 > > On Wed, Sep 10, 2008 at 11:44 AM, Jay Darst > > Has anyone found the direct replacement for the electric heaters > > found in the Galley, Salon and Bedroom? > > > > Am familiar with the Cadet PerfectToe. I've replaced a few in the > > Prevost coaches. The PerfectToe heaters have not been tested and are > > NOT recommended for Vertical installations such as those in the > > Bedroom and Galley heaters in 80's Birds. > > > > Have researched the forum and read Dayton and Fasco names, but have > > not been able to find correct heaters by these companies. > > > > My heaters have been cleaned and they still operate, though with > > little air movement and limited high thermostat settings. > > > > Would like to just buy 3 new heaters to replace the originals and be > > done, not buying pieces and parts to recondition them. But will if > > thats the best answer ;~} > > > > Thanks > > jay darst > > 85PT40 > > 91PrevostRoyale40XL > > 96PrevostCountryCoach40XL > > Sullivan, IL > > 217 - 971 - 0036 cell > > > > > |
09-11-2008, 06:05
--- In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
> > These heaters are not as wide as the ones in my coach, 17 3/4" but > they might work for you. > The grill on this one looks like the ones in my coach. http://www.cadetco.com/show_product.php?prodid=1005 Some other options? > http://www.heatersplus.com/qts.htm http://www.houseneeds.com/Shop/HeatingPr...electrical /mysonelectricaltoekickheaters.htm > http://www.qmarkmeh.com/develop/prod_pdf...-QTSOO.pdf http://www.grainger.com/Grainger/items/2...Item=2YV10 > > Kurt Horvath > 95 PT-42 > 10AC > > --- In WanderlodgeForum@yahoogroups.com, "Ryan Wright" > > > > > Jay, > > > > Nope, and I spent a good deal of time last year searching, too. My > > heaters move enough air but also have limited high thermostat > settings > > which drives me to supplement with LP during the hard cold of > winter. > > I've been considering installing an automation controller, replacing > > all heat & air thermostats with relays and temperature sensors, and > > controlling HVAC throughout the entire bus from a small touchpanel. > > This would allow me to set the heaters to any temperature and give > me > > a single control point. Unfortunately it also requires a lot of time > > disassembling panels and running wires throughout the coach, which > is > > why I've not done it yet. > > > > One thing you're going to notice, and the reason I gave up my search > > for new heaters, is that nobody makes a 20 amp 120 volt toe heater > > anymore. Your existing heaters are 20 amps a pop and the extra power > > is nice on a cold winter night. So even if you do find something > that > > fits, it's not going to put out as much heat. > > > > If someone does happen to find 20 amp heaters that fit, they're > going > > to sell a bunch of 'em. > > > > -Ryan > > '86 PT-40 8V92 > > > > On Wed, Sep 10, 2008 at 11:44 AM, Jay Darst > > > Has anyone found the direct replacement for the electric heaters > > > found in the Galley, Salon and Bedroom? > > > > > > Am familiar with the Cadet PerfectToe. I've replaced a few in the > > > Prevost coaches. The PerfectToe heaters have not been tested and > are > > > NOT recommended for Vertical installations such as those in the > > > Bedroom and Galley heaters in 80's Birds. > > > > > > Have researched the forum and read Dayton and Fasco names, but > have > > > not been able to find correct heaters by these companies. > > > > > > My heaters have been cleaned and they still operate, though with > > > little air movement and limited high thermostat settings. > > > > > > Would like to just buy 3 new heaters to replace the originals and > be > > > done, not buying pieces and parts to recondition them. But will if > > > thats the best answer ;~} > > > > > > Thanks > > > jay darst > > > 85PT40 > > > 91PrevostRoyale40XL > > > 96PrevostCountryCoach40XL > > > Sullivan, IL > > > 217 - 971 - 0036 cell > > > > > > > > > |
