"wast odor control" and Drain pipes
10-18-2008, 07:15
I am replacing the drain pipes under the coach because the waste odor
control motor broke at the fitting and someone previous to me had replaced the pipes, but put the valves in the wrong order at the black water. Looking at my blue book diagrams it doesn't show the odor control motor in the schematic. Presently the two are tied into the system after the valves or down from them. Is this correct? Where in line should they be A. tank/motor/valve or B. tank/valve/motor as they are now, seems that it should be A. not the way it is now. I appreciate anyones input? Thanks. John Mann 1985 pt40 Granbury Tx. |
