Battery Isolator location
11-26-2008, 00:24
I am looking for the battery isolator on my 1987 PT 36. Talking to
Shane about the charging system for the generator battery and he thinks perhaps the isolator is bad. Gave me some direction as to how to check it. He suggested it would be in the compartment where the generator fan is or with the charger. I looked in both locations and can't seem to identify it. Anyone have intimate knowledge on this one? John Heckman central Pa 1987 PT 36 |
11-26-2008, 01:22
I never found an isolator on my 86. Instead, I have a solenoid, (one
of two that are located under the bus near the entrance step area), The solenoid activates when my charger is on, shunting power to my generator battery. Hope this helps, Michael Kramer 86 PT-40 San Diego, CA --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > I am looking for the battery isolator on my 1987 PT 36. Talking to > Shane about the charging system for the generator battery and he thinks > perhaps the isolator is bad. Gave me some direction as to how to check > it. He suggested it would be in the compartment where the generator fan > is or with the charger. I looked in both locations and can't seem to > identify it. Anyone have intimate knowledge on this one? > > John Heckman > central Pa > 1987 PT 36 > |
11-26-2008, 02:01
That might be why I can't find one. I don't think the battery for the
generator is being charged so perhaps there is a soleniod not working. I need to get that fixed so that I can put the bus into my storage spot. I am concerned that I will have starting problems and I want to be certain that I can start the generator so that if needed I can charge the house and engine start batteries (which on my coach are one in the same). I want to but the bus under cover but I am afraid to move it way from 110 until I am confident that it will start. Any more information would be appreciated. John Heckman central Pa 1986 PT 36 > > I never found an isolator on my 86. Instead, I have a solenoid, (one > of two that are located under the bus near the entrance step area), > The solenoid activates when my charger is on, shunting power to my > generator battery. > > Hope this helps, > > Michael Kramer > 86 PT-40 > San Diego, CA > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > wrote: > > > > I am looking for the battery isolator on my 1987 PT 36. Talking to > > Shane about the charging system for the generator battery and he thinks > > perhaps the isolator is bad. Gave me some direction as to how to check > > it. He suggested it would be in the compartment where the generator fan > > is or with the charger. I looked in both locations and can't seem to > > identify it. Anyone have intimate knowledge on this one? > > > > John Heckman > > central Pa > > 1987 PT 36 > > > |
11-26-2008, 05:40
The wanderlodge.org archives has a writeup on a similar problem
entitled "Generator Battery Drain Problem". In it, Ralph F. suggests that the isolator (for a 1986 38' PT) should be on the curb side behind the rear louvered panel. And should be inside the boxed in area were the Rediline is and mounted on the rear support there. Bob McLaughlin Homosassa, Fl still waiting for my property to sell --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" wrote: > > That might be why I can't find one. I don't think the battery for the > generator is being charged so perhaps there is a soleniod not > working. I need to get that fixed so that I can put the bus into my > storage spot. I am concerned that I will have starting problems and I > want to be certain that I can start the generator so that if needed I > can charge the house and engine start batteries (which on my coach > are one in the same). I want to but the bus under cover but I am > afraid to move it way from 110 until I am confident that it will > start. Any more information would be appreciated. > > John Heckman > central Pa > 1986 PT 36 > > > > I never found an isolator on my 86. Instead, I have a solenoid, (one > > of two that are located under the bus near the entrance step area), > > The solenoid activates when my charger is on, shunting power to my > > generator battery. > > > > Hope this helps, > > > > Michael Kramer > > 86 PT-40 > > San Diego, CA > > > > --- In WanderlodgeForum@yahoogroups.com, "bubblerboy64" > > wrote: > > > > > > I am looking for the battery isolator on my 1987 PT 36. Talking > to > > > Shane about the charging system for the generator battery and he > thinks > > > perhaps the isolator is bad. Gave me some direction as to how to > check > > > it. He suggested it would be in the compartment where the > generator fan > > > is or with the charger. I looked in both locations and can't > seem to > > > identify it. Anyone have intimate knowledge on this one? > > > > > > John Heckman > > > central Pa > > > 1987 PT 36 > > > > > > |
11-26-2008, 06:24
John
If you don't find it you could disconnect the battery if it is charged up & it shouldn't run down. I have left car battery's disconnected all winter without them running down Do Spithaler 89 SP 36' Butler , PA On Wed, Nov 26, 2008 at 9:01 AM, bubblerboy64 <"jehdds@hotmail.com"> wrote:
