Getting Hard Water Scale in Plumbing, What To Do?
12-30-2008, 08:39
Howdy.
I just took apart the solenoid for our coach's Microphor 12 V Commode to see why it wouldn't shut off the water. Water was running into the commode's bowl constantly. The Microphor tech said,"Look for sand in the valve part of the solenoid." I did that and did NOT find any SAND but pieces of scale instead. I am too old and lazy to keep tearing that solenoid apart every two weeks. There must be an answer to solve this hard water scale problem. Ideas, suggestions would be appreciated.
A source of C4 as a permanent solution?
TIA,
Jack
Regards,
Jack and Liz Pearce
Fulltiming in a 1993 Wanderlodge WB40
D'Hanis, TX in the Winter
Buena Vista, CO in the Summer
12-30-2008, 10:26
Hi Jack,
We fulltime also and use a water softner by Flow Pure. When we first
got it 3 years ago, after using it for about 2 weeks, I noticed that
when I flushed, white chunks started coming out of the toilet head.
Turns out to be hard water chunks. Problem solved for us.
When we first check in somewhere, I test the water with test strips
and if hard enough, I put on the water softner.
Cost was $290, but recharging it with cheap salt (33 cents) every 800
gallons or so (depending on how hard the water is), is a cheap
solution.
Bob Lawrence
84 PT36
South Padre Island, Tx (where we are using the softner)
> Howdy.
Commode to
in the
but
this
> TIA,
> Jack
> Regards,
> Jack and Liz Pearce
12-30-2008, 11:00
Where did you get the water softener?
Bill Jowers
83PT36
Sent: Tuesday, December 30, 2008 4:26 PM
Subject: [WanderlodgeForum] Re: Getting Hard Water Scale in Plumbing, What To Do?
Hi Jack,
solution.
Bob Lawrence
84 PT36
> Howdy.
Commode to
in the
but
this
> TIA,
> Jack
> Regards,
> Jack and Liz Pearce
12-30-2008, 14:17
Jack: You might try a water softener. Talk to Chet Parks about that.
He is an expert and also makes softeners.
--- In WanderlodgeForum@yahoogroups.com, "Jack and Liz Pearce"
> Howdy.
> TIA,
> Jack
> Regards,
> Jack and Liz Pearce
12-31-2008, 10:03
Hey Bill,
Try Flowpur.com. That should do it. Flowpur has more gold in it that
the Camping World model.
Bob Lawrence
84 PT36
Padre Island, Tx
> Bill Jowers
> 83PT36
> From: Bob Lawrence
> Hi Jack,
first
that
head.
strips
800
> solution.
> Bob Lawrence
> 84 PT36
> > Howdy.
> Commode to
sand
> in the
SAND
> but
that
solve
> this
appreciated.
> > TIA,
> > Jack
> > Regards,
> > Jack and Liz Pearce
