Orange water-pump lights on 2000 LXI
02-09-2009, 02:50
We have two of this particular kind. One in the water/sewer
compartment and one beneath the medicine cabinet in the hall bathroom. I believe they are some kind of LED. The water pumps both work fine but the 2 bulbs are out. Where to get more bulbs? How to remove and replace? Thanks. Ron & Ruth in 2000 LXI |
02-09-2009, 03:13
I removed my burned out pump pilot bulb in the utility compartment and
found a replacement 12VDC LED at Radio Shack that snapped right into the hole. Be sure to follow the correct poliarity (+/-) when connecting the new one. Rich D. '99LXi43' CT --- In WanderlodgeForum@yahoogroups.com, "luckyron1" wrote: > > We have two of this particular kind. One in the water/sewer > compartment and one beneath the medicine cabinet in the hall bathroom. > I believe they are some kind of LED. The water pumps both work fine > but the 2 bulbs are out. Where to get more bulbs? How to remove and > replace? Thanks. > > Ron & Ruth in 2000 LXI > |
02-09-2009, 07:10
If the light is about 1/2" in diameter, it is a regular bulb, not an LED. These are available at Radio Shack in a variety of colors (you replace the whole assembly, as the bulb is not accessible). They're only a couple of bucks.
Here's one that is an LED with a fuse holder: Bunch of different ones here, both LED, neon, and regular: Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Feb 9, 2009, at 6:50 AM, luckyron1 wrote:
02-09-2009, 07:50
OK, Thanks. I started tinkering around and figured out that you
couldn't just screw the amber lens off so I removed the switch plate. It looks like the amber lens assembly slips on to a plastic sleeve that must contain the diode or the bulb. At the terminal end of the plastic sleeve there are what appear to be 2 compressible retention clips, 180 degrees apart, that would hold the Amber lens on. I don't have the tool for that if there is such a thing, and I am afraid to break it. Do you know what I need? Thanks --- In WanderlodgeForum@yahoogroups.com, Pete Masterson wrote: > > If the light is about 1/2" in diameter, it is a regular bulb, not an > LED. These are available at Radio Shack in a variety of colors (you > replace the whole assembly, as the bulb is not accessible). They're > only a couple of bucks. > > Here's one that is an LED with a fuse holder: > <http://www.radioshack.com/product/index....Id=3087860> > > Bunch of different ones here, both LED, neon, and regular: > <http://www.radioshack.com/family/index.j...Id=2032293> > > Pete Masterson > '95 Blue Bird Wanderlodge WBDA 42 (For Sale) > <http://www.aeonix.biz/BBforsale.html> > El Sobrante CA > aeonix1@... > > > > > On Feb 9, 2009, at 6:50 AM, luckyron1 wrote: > > > We have two of this particular kind. One in the water/sewer > > compartment and one beneath the medicine cabinet in the hall bathroom. > > I believe they are some kind of LED. The water pumps both work fine > > but the 2 bulbs are out. Where to get more bulbs? How to remove and > > replace? Thanks. > > > > Ron & Ruth in 2000 LXI > > > > > > > > > > ------------------------------------ > > > > Yahoo! Groups Links > > > > > > > |
02-09-2009, 08:56
I simply replaced the whole assembly. Indeed, when I had a service at CCW last spring, they found the outside pump light (in the utility connection compartment) had gone bad, and they just swapped in a new one. There were 'pigtail' wires on the one I had that were clipped and butt connected. But some have the slip on 'ears' that take the wires.
I didn't bother trying to open it up to then find a replacement bulb. It might have been replaceable, but there was the hassle of disassembling to get the old lamp holder out, then disassembling the lamp holder, identifying the bulb, seeking a bulb replacement (it could be 50 cents or $5, who knows?) and so on. The technician at CCW said they couldn't be opened without destroying them. I noticed that the replacement they made didn't even show up on my bill (nice, as the bill was plenty high). The technician had the panel out for another reason (which I was billed for)... Some of these cheap little things can be a surprise -- I had an LED "flashlight" that hooked to a key ring. I'd received it as a freebie at a trade show. It finally quit, but it was assembled with screws -- I got to the battery (it took four) and went to Radio Shack -- and the 4 button batteries would have been over $20 -- but you could buy similar lights for $5.... (I tossed it out as I have several similar ones also gotten at trade shows as give aways.) Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 (For Sale) El Sobrante CA "aeonix1@mac.com" On Feb 9, 2009, at 11:50 AM, luckyron1 wrote:
