					1987 PT - Head Lights dont work
					05-31-2009, 10:15
				 Post: #1 | |||
					Was checking lights and when I tested headlights, they no longer come on.  I have tried to read post and book and cannot find where a fuse or breaker for headlight circuit would be. Have opened panel in front of driver and above driver but found nothing there. Thanks Paul & Debbie Potter 1987 PT40 Hesperia CA | |||
					05-31-2009, 16:55
				 Post: #2 | |||
					Hi Paul: This one can be easy or hard and a VOM is almost a must, though you can trouble shoot with a 12 vdc test light. You need to open the drivers side headlight panel and on that head light will be an orange or red wire and a green. Follow those to the terminal strip located above the opening. Then see if they go to 2 black Bosh relays (this is a headlight mod) if not then those wires will go to the dimmer switch and from the dimmer switch to the headlight switch. The power going to the headlight switch will be located on the second row of breakers looking into the headlight opening from the front. You can be fairly assure that the breaker is ok if you switch on the headlight switch and see if you have lights on the gauges. But 12 vdc may be going into the headlight switch but coming out to the dimmer switch. Or if it is then switch the dimmer switch to see of the bright's or dim's come on? You can see where this one step at a time goes in the trouble shooting process. Ok, you will find the problem I am sure. If you have the headlight mod, then follow the power to where the power is tapped into a breaker, usually in front. And there is also a ground that should be on the brass terminal bar in the same general area. If you do not have the headlight mod, now is the time to do it, and this is a GOOD mod to do. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" Duncan, Oklahoma At 10:15 PM 5/31/2009 +0000, you wrote: >Was checking lights and when I tested headlights, they no longer come >on. I have tried to read post and book and cannot find where a fuse or >breaker for headlight circuit would be. Have opened panel in front of >driver and above driver but found nothing there. >Thanks > >Paul & Debbie Potter >1987 PT40 >Hesperia CA > > | |||
					06-01-2009, 15:10
				 Post: #3 | |||
| 1987 PT - Head Lights dont work OK, I will try that. After reading many post I went to the headlight switch and I will let you know what I find. Thanks Paul & Debbie 87PT40 Hesperia CA From:
					06-01-2009, 15:23
				 Post: #4 | |||
					The headlight switch is a "known weak spot" in the wiring system. The switch in my coach is a rocker-switch with a split head/fog light part. It's a Delco switch. Wasn't hard to replace, except the mounting holes were a little small and I had to ream them out to fit the mounting screws on the back of the dash board. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 El Sobrante CA "aeonix1@mac.com" On Jun 1, 2009, at 8:10 PM, P & D wrote:
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
