aux. air compressor check valve
09-24-2009, 01:53
We are trying to find a source for the auxially air compressor check valve. Does anyone have any suggestions? We have tried all the stores that are available locally, and no one has one.Â
Â
Thanks.
Jana Ewart
1989PT40WB
-- Blessed are the people whose God is the Lord. (Psalm 144:15) |
09-24-2009, 03:48
Jana, go to http://www.gastmfg.com and click on Service Information. You will get a
list of authorized service centers for Gast, which I assume is the brand of auxillary air compressor you have. According to my Gast Operation & Maintenance Technical Manual, the part number for the check valve is AJ550. Make sure to verify the number with Gast. Also, while you are at the Gast web site you probably can download the manual if you need it. Royal Washburn 97 43'BBWL --- In WanderlodgeForum@yahoogroups.com, Jana Ewart > > We are trying to find a source for the auxially air compressor check valve. > Does anyone have any suggestions? We have tried all the stores that are > available locally, and no one has one. > > Thanks. > Jana Ewart > 1989PT40WB > > -- > Blessed are the people whose God is the Lord. (Psalm 144:15) > |
09-24-2009, 03:55
Thanks! Â We will "check" it out.
Jana
