					FASCO Cheater Heater Questions
					10-17-2009, 06:20
				 Post: #1 | |||
					My 87 FC 35 has this type of heater under the sofa and I am having problems finding anything on them. Does anyone know where to get replacement parts for these heaters? The one that I have has the thermostat switch broken in it. I am looking to get a new switch. If that is not possible, I would be interested in replacing the complete unit with a compatible one. Any help with this would be greatly appreciated. Thank you in advance, Bob Maloney | |||
					10-17-2009, 09:05
				 Post: #2 | |||
					I replace all mine with Cadet Perfectoe baseboard heaters. Smaller, so I had to place wood boards under the vertical ones. A LOT quieter. Easy replacement. Used the oversized heating grills we had with the Fasco's to cover the whole opening. Check online for these. Bob Lawrence 84 PT36 Ft Lauderdale, Fl (Till Mon) > My 87 FC 35 has this type of heater under the sofa and I am having problems finding anything on them. Does anyone know where to get replacement parts for these heaters? The one that I have has the thermostat switch broken in it. I am looking to get a new switch. If that is not possible, I would be interested in replacing the complete unit with a compatible one. Any help with this would be greatly appreciated. > Thank you in advance, > Bob Maloney > | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
