Bendix cruise control creeps
05-25-2010, 16:08
Hi All
I have an '86 PT40 with the Bendix cruise. Last season it didn't work and this
winter I gave it the once over (everything worked) but now I have a new problem
.... it creeps up in speed.
It will run fine for miles, and then all of a sudden we're from 65 to 80 ...
sometimes going UP hills.
Anyone else experienced this ?
Is there something I should do to "clear" the memorized speed other than using
the brakes ?
Marty Spaulding
'86 PT40
Kalamazoo
05-25-2010, 17:48
Marty:
There is a re build kit for the cc5 cylinder, which sticks a little or acts
slow. Then you may have an o-ring leaking slightly on the set valves.
Is your throttle a little slow acting when you push the peddle?
It does not sound like the control unit. In your manual, you will find a
trouble shooting guide, but were it mine, I would suspect an o-ring leaking
past.
Safe travels,
"84FC35 "Ruff Diamond"
Duncan, Oklahoma
At 04:08 AM 5/26/2010 +0000, you wrote:
>Hi All
>this winter I gave it the once over (everything worked) but now I have a
>new problem .... it creeps up in speed.
>... sometimes going UP hills.
>using the brakes ?
>Marty Spaulding
>'86 PT40
>Kalamazoo
05-26-2010, 00:08
Hi Marty- I second Ralph's suggestion about a dirty valve on the cruise assembly
or a sticky air throttle cylinder. Once on a trip across Iowa, mine started
behaving the same way- but it turned out to be a broken throttle return spring-
check those too. The combination of the sticky throttle cylinder and a broken
return spring will make for quite a thrill ride!
Shane Fedeli
85PT40
Hershey, PA
--- In WanderlodgeForum@yahoogroups.com, "zboy59" wrote:
> Hi All
the brakes ?
> Marty Spaulding
> '86 PT40
> Kalamazoo
