In motion satellite
06-25-2005, 00:07
In motion satellite
We've got a KVH L3 in motion satellite dish. The signals coming in are
strong on transponders 1&2. We get a message that says "antenna pointing mismatch." The system says it's updating the guide, and that's where it ends. No channels come in. It worked fine in VA. We are now in NY State. Any help would be appreciated. Dick & Sandy Friedkin 2004 Wanderlodge 2003 PT Cruiser |
06-25-2005, 07:08
In motion satellite
Hi Dick,
Sounds like the dish may be locked onto the wrong satellite. I had that happen when I moved a long distance with the dish off and then re- powered. Yours may be different but my book (at the back) shows a manual acquisition sequence you can follow after plugging the serial cable from the dish into a laptop. You can "zap" the present settings and restart or even manually point it by zip code. Other way is to move with it off and re-power again. The tech's at KVH are very helpful and will walk you through the process if you need. Rich D. '99LXi43' --- In WanderlodgeForum@yahoogroups.com, "richardfriedkin" > We've got a KVH L in motion satellite dish. The signals coming in are > strong on transponders 1&2. We get a message that says "antenna > pointing mismatch." The system says it's updating the guide, and > that's where it ends. No channels come in. It worked fine in VA. We > are now in NY State. Any help would be appreciated. > > Dick & Sandy Friedkin > 2004 Wanderlodge > 2003 PT Cruiser |
