Monitor Panel
03-26-2011, 06:31
Monitor Panel
Does any one have a wiring diagram/ - 1982 FC 31Sb |
03-30-2011, 02:51
Monitor Panel
Did you ever get your problem resolved? It sounds like some crossed wiring.
Wayne Kotila
96PT42
From: Chuck Wheeler To: WanderlodgeForum@yahoogroups.com Sent: Sat, March 26, 2011 12:31:08 PM Subject: [WanderlodgeForum] Monitor Panel Does any one have a wiring diagram/ schematic of the monitor panel? When we had our accident a while back the wiring was damaged at the grey water tank. I thought I could figure it out but get strange results. Fresh water will indicate correctly if the grey and black are empty. As the grey tank fills up the black and fresh water follow it. They all indicate the same. The black also creates some strange problems as it fills up. Propane is OK. I have looked through the ââ¬Åfilesââ¬Â section of the various BB sites and cannot find any documentation on the monitor panels.
- Chuck Wheeler- 1982 FC 31Sb Fort Worth TX |
03-30-2011, 03:23
Monitor Panel
I have a good idea of what it is. I can - Chuck From: Did you ever get your problem resolved? It sounds like some Wayne Kotila 96PT42 From: Chuck Wheeler Does any one have a wiring diagram/ schematic of the monitor - 1982 FC 31Sb |
04-01-2011, 16:20
Monitor Panel
Chuck, It sounds like your getting the problem figured out.
Good Luck
Wayne kotila
From: Chuck Wheeler To: WanderlodgeForum@yahoogroups.com Sent: Wed, March 30, 2011 10:23:11 AM Subject: RE: [WanderlodgeForum] Monitor Panel Wayne, I have a good idea of what it is. I can measure a ground on the common for the grey tank. The commons are switched to select the tank you want to measure and all the sensor probes are connected in parallel so the monitor is always measuring the grey tank plus any other tank selected. The resulting measurement is the greater of the level in the grey tank or the selected tank. I started out believing that the sensors were switched. After helping a buddy with his SOB and looking at a drawing that Donald Watson found it was pretty obvious once you understood that the commons were switched and not the sensor probes. I am still going to make a drawing and schenmatic and will post when done.
- Chuck Wheeler- From: WanderlodgeForum@yahoogroups.com [mailto: WanderlodgeForum@yahoogroups.com ] On Behalf Of Wayne Kotila
Did you ever get your problem resolved? It sounds like some crossed wiring. Wayne Kotila 96PT42
From: Chuck Wheeler < cwheeler@... > Does any one have a wiring diagram/ schematic of the monitor panel? When we had our accident a while back the wiring was damaged at the grey water tank. I thought I could figure it out but get strange results. Fresh water will indicate correctly if the grey and black are empty. As the grey tank fills up the black and fresh water follow it. They all indicate the same. The black also creates some strange problems as it fills up. Propane is OK. I have looked through the ââ¬Åfilesââ¬Â section of the various BB sites and cannot find any documentation on the monitor panels.
