Adding an a/c chiller to a Webasto heater system
07-12-2011, 14:41
I hate the noise and cost to run my 3 roof a/c units.
Has anyone ever seen or setup with an a/c chiller system that runs through the Webasto heater system? I have a 3 station (radiator) Webasto setup in my Bus conversion (sob) thought you guys may have some experience or ideas. 1994 Country Coach Concept Bus conversion 8v92 Detroit/Allison Gillig Chassis Hot in Granbury TX Bryce Collerette |
07-16-2011, 04:00
--- In WanderlodgeForum@yahoogroups.com, "bryce"
> > I hate the noise and cost to run my 3 roof a/c units. > Has anyone ever seen or setup with an a/c chiller system that runs through the Webasto heater system? > I have a 3 station (radiator) Webasto setup in my Bus conversion (sob) > thought you guys may have some experience or ideas. > 1994 Country Coach Concept Bus conversion 8v92 Detroit/Allison Gillig Chassis > Hot in Granbury TX > Bryce Collerette > I think you'd have a real problem with condensation throughout the system. We get water running out of the Dometic ceiling grills in high humidity conditions and have to run the fans on continuous to cure it. |
