Engine Belts
10-20-2011, 03:18
Engine Belts
I was wandering what the rule of thumb to change your engine belts on a 3208
cat. Whether it be miles or years. what do most of you guys do. I don't want to
take off good belts & replace them to soon Thanks for your input.
Don Spithaler
89 SP 36'
Butler, PA
10-20-2011, 03:34
Engine Belts
Don
I make it a habit to change drive belts on any vehicle after 5 years,but use the “turn it over and look for cracks”at each oil check.
Fred & Jeanne Hulse
Morristown,Arizona
97 WLWB41
10-20-2011, 05:02
Engine Belts
The 3208 does not seem to be real easy on
belts. I check the tension before any long
runs, and open up for a look every year or
so, or if I'm in there for other service. I
don't think I get more than 3-4 years out of
the belts. That's about 15K-20K miles.
Because the belts are not that convenient on
an FC, any belt I don't like the looks of
gets replaced when the front is open.
Tension and idler pulleys need to be watched
for worn bearings; sloppy bearings lead to
premature belt wear and thrown belts.
Spare belts and a set of tools are good
insurance.
Bob Griesel '84 FC31 WLII WA
-----Original Message-----
[mailto:WanderlodgeForum@yahoogroups.com] On
Behalf Of DonS
Sent: Thursday, October 20, 2011 8:18 AM
Subject: [WanderlodgeForum] Engine Belts
change your engine belts on a 3208 cat.
you guys do. I don't want to take off good
input.
Don Spithaler
89 SP 36'
Butler, PA
Yahoo! Groups Links
http://groups.yahoo.com/group/WanderlodgeForu
m/
m/join
(Yahoo! ID required)
WanderlodgeForum-fullfeatured@yahoogroups.com
10-21-2011, 05:16
Engine Belts
I always carry a old set of belts & plenty of tools to do the job. Mine are two years old & I always use the Gates Green Stripe. I guess I'll swing the rad out & check them for cracks as the power steering & compressor belts need tightening.      Thanks guys.
Don Spithaler
89 SP 36'
Butler, PA
insurance.
[mailto:"WanderlodgeForum%40yahoogroups.com"] On
Behalf Of DonS
To: "WanderlodgeForum%40yahoogroups.com"
input.
Don Spithaler
89 SP 36'
Butler, PA
Yahoo! Groups Links
m/
m/join
"WanderlodgeForum-fullfeatured%40yahoogroups.com"
"WanderlodgeForum-unsubscribe%40yahoogroups.com"
