10-19-2013, 03:47
Post: #131
RE: Time to replace defective and potentially dangerous absorption fridge
Cory, where did you cap off the propane from the Dometic?
Morey Zuber 99LXi41 |
10-20-2013, 08:28
Post: #132
Morey, there is a shut off valve right at floor level. I just turned it off and left it with the exit pipe removed that used to go to old fridge.
Corey Noble Laurel Park, NC 2000 LXi 46,000 miles and counting Added features: Overbuilt cycle lift, built-in vacuum, flat panel LCD TVs, Vetus macerating toilet, Samsung fridge, Lifeline batteries, headlight cover removal campaign. |
03-31-2019, 22:16
Post: #133
Urnie-Medie
This is the thread I was referring to. It is worth the read. Gregg Gregg & Jane Gesse 1994 WLWB 40 Mid-Door |
