UPDATE: the ever controversial "DASH AIR"
08-20-2005, 15:43
We rebuild and repainted the condenser motors, replaced the fan blades,
they are good as new. We used the fluorescent dye and found two leaks, one where the hose connects to the fitting that goes through the roof to the condenser, and one where the expansion valve connect to the evaporator. We left the guages connected, hopefully the pressure holds. Thanks Bruce Campbell Clearwater, FL 83'FCSB "Blue Skies" --- In WanderlodgeForum@yahoogroups.com, erniecarpet@a... wrote: > Bruce- there maybe some crud on the winding. take some fine sandpaper and > make it shine- should work fine. ernie > > > [Non-text portions of this message have been removed] |
