Oil Pressure Switch
09-23-2005, 01:18
Oil Pressure Switch
Greetings,
I replaced my oil pressure sending unit about a year ago, Pretty tough
finding the correct one, but luckily I found it relatively local here in So Cal
(Carson, CA).
If you have TeleFlex gauges, I believe the sending unit for the gauge (8V92)
is #1507377D if the gauge goes up to 120 PSI (according to the Teleflex
webpage)
I found the sending unit at:
_http://www.custominstrumentpanels.com/_
(http://www.custominstrumentpanels.com/)
Give 'em a call...they do nice work, and should sell you the correct sending
unit. Let us know if it works out.
Kevin McKeown
Yorba Linda, CA
1986 39' PT
8V92
09-23-2005, 02:43
Oil Pressure Switch
I have a 1988 WBWL 8V92 I am trying to find an oil pressure sending
switch for my bus...it it a KYSOR of Cadallic model # 24900-03
