genset tray
11-04-2005, 04:04
genset tray
I just got the genset pulled in order to replace the slide. It appears
the whole thing was sloppily flame cut. Does anyone have any idea if this might be the OEM or a patch from the previous owner. Also any idea to what the tray should be constructed with? Glenn Shehorn 83FC35 Kansas City Mo |
11-04-2005, 06:44
genset tray
Them boys that did the heavy duty work, chassis and fabrication, don't show the
best craftsmanship. Kinda like the wiring, crude but it works for a while. Mike Hohnstein ----- Original Message ----- From: drdigger@... To: WanderlodgeForum@yahoogroups.com Sent: Friday, November 04, 2005 10:04 AM Subject: [WanderlodgeForum] genset tray I just got the genset pulled in order to replace the slide. It appears the whole thing was sloppily flame cut. Does anyone have any idea if this might be the OEM or a patch from the previous owner. Also any idea to what the tray should be constructed with? Glenn Shehorn 83FC35 Kansas City Mo ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
11-06-2005, 00:38
genset tray
--- In WanderlodgeForum@yahoogroups.com, "drdigger@s..."
> > I just got the genset pulled in order to replace the slide. It appears > the whole thing was sloppily flame cut. Does anyone have any idea if > this might be the OEM or a patch from the previous owner. Also any idea > to what the tray should be constructed with? > Glenn Shehorn > 83FC35 > Kansas City Mo > Hello Glenn, Not sure what your construction question is specifically directed at. Floor of the tray appears to be 1/4 inch thick steel plate, reinforced with pieces of angle iron welded to the bottom. Happy to provide more information if you have further questions on construction. Eric Johnson 84FC35SB San Antonio Texas |
11-06-2005, 02:29
genset tray
sounds exactly like mine, with the exception of about a 4" sag. I hate to add
anymore weight, but think I will redo with 3/8 and extra braces. Thanks to you and Mike ----- Original Message ----- From: Eric Johnson To: WanderlodgeForum@yahoogroups.com Sent: Sunday, November 06, 2005 6:38 AM Subject: [WanderlodgeForum] Re: genset tray --- In WanderlodgeForum@yahoogroups.com, "drdigger@s..." wrote: > > I just got the genset pulled in order to replace the slide. It appears > the whole thing was sloppily flame cut. Does anyone have any idea if > this might be the OEM or a patch from the previous owner. Also any idea > to what the tray should be constructed with? > Glenn Shehorn > 83FC35 > Kansas City Mo > Hello Glenn, Not sure what your construction question is specifically directed at. Floor of the tray appears to be 1/4 inch thick steel plate, reinforced with pieces of angle iron welded to the bottom. Happy to provide more information if you have further questions on construction. Eric Johnson 84FC35SB San Antonio Texas ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
11-23-2005, 05:08
genset tray
A question for John and anyone else that might know.
It appears from the pictures of your radiator upgrade that the oil pan of the Perkins sets above the slide out tray, Is this correct? On my bird the tray has been cut to allow the oil pan to set below that tray and the isolation springs boIt thru the tray. believe that to be the reason the tray buckled in the center.Has any one had this issue and is there a possibility to remanufacture and raise the genset to eliminate this weakness? Glenn Shehorn 83 FC 35 Kansas City Mo ----- Original Message ----- From: John To: wanderlodge@yahoogroups.com Sent: Wednesday, November 23, 2005 9:35 AM Subject: [wanderlodge] Re: MORE PHOTOS OF FC MODEL GENSET MODIFICATION I forgot to answer the temperature question from Randy, although it is cool here this morning and hasen't gotten into the 70's since I have been here, the temperatures have been similar to what I had experienced with the original configuration, right now it is 55 degrees outside and under load the temperature is running at 170 degrees, the highest the temperature has gone is 175 degrees so far. Randy wired the fan speed the same as what his genset fan speed was wired at on his 'Bird. I don't think that temperature will be an issue, as I can wire the fan to run at three different speeds and I believe that it is currently wired at the middle speed. John Finn "FINN'S INN EXPRESS" '82 Bluebird Wanderlodge 35FCRB Hopkins, SC "ON THE ROAD IN ORLANDO, FLA." To Visit the Finn's Inn Express Remodeling Adventure go to; http://www.pbase.com/iamflagman/image/24977457 ///////////////////////////////////////////////////////////////////// --- In wanderlodge@yahoogroups.com, "Scott" > > "oil leaks" I know where there is a perkins that doesn't leak a drop > of oil and only has 1800 hrs on it! John sounds great did the> temps come down..bet you like the door for service and checking > fluids that is a great idea... > > Scott B > 86FC35 > SC (with a cast on right arm..tore a muscle trying to open water > filter on coach...dinner gonna be interesting tommorrow!) > > --- In wanderlodge@yahoogroups.com, randydupree > > > > john,now that you've been running it for a day or so,hows the > temps,and how did we do on the oil leaks? > > randy > > ----- Original Message ----- > > From: John > > To: wanderlodge@yahoogroups.com > > Sent: Wednesday, November 23, 2005 2:40 AM > > Subject: [wanderlodge] MORE PHOTOS OF FC MODEL GENSET MODIFICATION > > > > > > I have added and rearranged some of the photos of the genset > > modification that was done by Randy Dupree on my 'Bird. The new > > photos show how the framework was built for the swing open door > and > > how it works, in conjunction with the original genset slide, also > > shown is how the original oil bath air filter was reused as a > > muffler for the air intake along with the new free flowing Dupree > > air filter, it had to be remounted to add clearance when the > drawer > > is closed. > > > > I suggest that you view all of the photos of this modification > > starting from the beginning at; > > > > http://www.pbase.com/image/52361793 > > > > John Finn > > "FINN'S INN EXPRESS" > > '82 Bluebird Wanderlodge 35FCRB > > Hopkins, SC > > "ON THE ROAD IN ORLANDO, FLA." > > To Visit the Finn's Inn Express Remodeling Adventure go to; > > http://www.pbase.com/iamflagman/image/24977457 > > > > > > > > > > > > ----------------------------------------------------------------- --- > ---------- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "wanderlodge" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > wanderlodge-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > > > > > ----------------------------------------------------------------- --- > ---------- > > > ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "wanderlodge" on the web. b.. To unsubscribe from this group, send an email to: wanderlodge-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
11-23-2005, 05:26
genset tray
The oil pan on my 1982 FC35 perkins generator is several inches above
the tray. There are no cutouts in it. Tom Warner 1982 FC35 Vernon Center,NY At 12:08 PM 11/23/2005, you wrote: >A question for John and anyone else that might know. > >It appears from the pictures of your radiator upgrade that the oil >pan of the Perkins sets above the slide out tray, Is this correct? >On my bird the tray has been cut to allow the oil pan to set below >that tray and the isolation springs boIt thru the tray. believe >that to be the reason the tray buckled in the center.Has any one had >this issue and is there a possibility to remanufacture and raise the >genset to eliminate this weakness? > >Glenn Shehorn >83 FC 35 >Kansas City Mo > ----- Original Message ----- > From: John > To: wanderlodge@yahoogroups.com > Sent: Wednesday, November 23, 2005 9:35 AM > Subject: [wanderlodge] Re: MORE PHOTOS OF FC MODEL GENSET MODIFICATION > > > I forgot to answer the temperature question from Randy, although it > is cool here this morning and hasen't gotten into the 70's since I > have been here, the temperatures have been similar to what I had > experienced with the original configuration, right now it is 55 > degrees outside and under load the temperature is running at 170 > degrees, the highest the temperature has gone is 175 degrees so far. > Randy wired the fan speed the same as what his genset fan speed was > wired at on his 'Bird. I don't think that temperature will be an > issue, as I can wire the fan to run at three different speeds and I > believe that it is currently wired at the middle speed. > > John Finn > "FINN'S INN EXPRESS" > '82 Bluebird Wanderlodge 35FCRB > Hopkins, SC > "ON THE ROAD IN ORLANDO, FLA." > To Visit the Finn's Inn Express Remodeling Adventure go to; > ><http://www.pbase.com/iamflagman/image/24977457>http://www.pbase.com/iamflagman\ /image/24977457 > > ///////////////////////////////////////////////////////////////////// > > --- In wanderlodge@yahoogroups.com, "Scott" > > > > "oil leaks" I know where there is a perkins that doesn't leak a > drop > > of oil and only has 1800 hrs on it! John sounds great did the> > temps come down..bet you like the door for service and checking > > fluids that is a great idea... > > > > Scott B > > 86FC35 > > SC (with a cast on right arm..tore a muscle trying to open water > > filter on coach...dinner gonna be interesting tommorrow!) > > > > --- In wanderlodge@yahoogroups.com, randydupree > > > > > > john,now that you've been running it for a day or so,hows the > > temps,and how did we do on the oil leaks? > > > randy > > > ----- Original Message ----- > > > From: John > > > To: wanderlodge@yahoogroups.com > > > Sent: Wednesday, November 23, 2005 2:40 AM > > > Subject: [wanderlodge] MORE PHOTOS OF FC MODEL GENSET > MODIFICATION > > > > > > > > > I have added and rearranged some of the photos of the genset > > > modification that was done by Randy Dupree on my 'Bird. The > new > > > photos show how the framework was built for the swing open > door > > and > > > how it works, in conjunction with the original genset slide, > also > > > shown is how the original oil bath air filter was reused as a > > > muffler for the air intake along with the new free flowing > Dupree > > > air filter, it had to be remounted to add clearance when the > > drawer > > > is closed. > > > > > > I suggest that you view all of the photos of this modification > > > starting from the beginning at; > > > > > > > <http://www.pbase.com/image/52361793>http://www.pbase.com/image/52361793 > > > > > > John Finn > > > "FINN'S INN EXPRESS" > > > '82 Bluebird Wanderlodge 35FCRB > > > Hopkins, SC > > > "ON THE ROAD IN ORLANDO, FLA." > > > To Visit the Finn's Inn Express Remodeling Adventure go to; > > > > <http://www.pbase.com/iamflagman/image/24977457>http://www.pbase.com/iamflagman/\ image/24977457 > > > > > > > > > > > > > > > > > > ----------------------------------------------------------------- > --- > > ---------- > > > YAHOO! GROUPS LINKS > > > > > > a.. Visit your group "wanderlodge" on the web. > > > > > > b.. To unsubscribe from this group, send an email to: > > > wanderlodge-unsubscribe@yahoogroups.com > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! > Terms > > of Service. > > > > > > > > > ----------------------------------------------------------------- > --- > > ---------- > > > > > > > > > > > > >------------------------------------------------------------------------------ > YAHOO! GROUPS LINKS > > a.. Visit your group "wanderlodge" on the web. > > b.. To unsubscribe from this group, send an email to: > wanderlodge-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > of Service. > > >------------------------------------------------------------------------------ > > > >[Non-text portions of this message have been removed] > > > >---------- >YAHOO! GROUPS LINKS > > * Visit your group > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > >---------- |
11-23-2005, 11:09
genset tray
mine is factory as far as i can tell and it is above the floor
you musta had somebody cutting on the floor to change oil with outsliding the set out or ......a add on big dia. gen set that wouldnot fit under frame! that is why scott got a side mounted gen set in his fc at powerteck! woody 81 fbrbsgd ft bragg nc --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > The oil pan on my 1982 FC35 perkins generator is several inches above > the tray. There are no cutouts in it. > > Tom Warner > 1982 FC35 > Vernon Center,NY > > At 12:08 PM 11/23/2005, you wrote: > >A question for John and anyone else that might know. > > > >It appears from the pictures of your radiator upgrade that the oil > >pan of the Perkins sets above the slide out tray, Is this correct? > >On my bird the tray has been cut to allow the oil pan to set below > >that tray and the isolation springs boIt thru the tray. believe > >that to be the reason the tray buckled in the center.Has any one had > >this issue and is there a possibility to remanufacture and raise the > >genset to eliminate this weakness? > > > >Glenn Shehorn > >83 FC 35 > >Kansas City Mo > > ----- Original Message ----- > > From: John > > To: wanderlodge@yahoogroups.com > > Sent: Wednesday, November 23, 2005 9:35 AM > > Subject: [wanderlodge] Re: MORE PHOTOS OF FC MODEL GENSET MODIFICATION > > > > > > I forgot to answer the temperature question from Randy, although it > > is cool here this morning and hasen't gotten into the 70's since I > > have been here, the temperatures have been similar to what I had > > experienced with the original configuration, right now it is 55 > > degrees outside and under load the temperature is running at 170 > > degrees, the highest the temperature has gone is 175 degrees so far. > > Randy wired the fan speed the same as what his genset fan speed was > > wired at on his 'Bird. I don't think that temperature will be an > > issue, as I can wire the fan to run at three different speeds and I > > believe that it is currently wired at the middle speed. > > > > John Finn > > "FINN'S INN EXPRESS" > > '82 Bluebird Wanderlodge 35FCRB > > Hopkins, SC > > "ON THE ROAD IN ORLANDO, FLA." > > To Visit the Finn's Inn Express Remodeling Adventure go to; > > > ><http://www.pbase.com/iamflagman/image/24977457>http://www.pbase.com /iamflagman/image/24977457 > > > > ///////////////////////////////////////////////////////////////// //// > > > > --- In wanderlodge@yahoogroups.com, "Scott" wrote: > > > > > > "oil leaks" I know where there is a perkins that doesn't leak a > > drop > > > of oil and only has 1800 hrs on it! John sounds greatdid the > > > temps come down..bet you like the door for service and checking > > > fluids that is a great idea... > > > > > > Scott B > > > 86FC35 > > > SC (with a cast on right arm..tore a muscle trying to open water > > > filter on coach...dinner gonna be interesting tommorrow!) > > > > > > --- In wanderlodge@yahoogroups.com, randydupree wrote: > > > > > > > > john,now that you've been running it for a day or so,hows the > > > temps,and how did we do on the oil leaks? > > > > randy > > > > ----- Original Message ----- > > > > From: John > > > > To: wanderlodge@yahoogroups.com > > > > Sent: Wednesday, November 23, 2005 2:40 AM > > > > Subject: [wanderlodge] MORE PHOTOS OF FC MODEL GENSET > > MODIFICATION > > > > > > > > > > > > I have added and rearranged some of the photos of the genset > > > > modification that was done by Randy Dupree on my 'Bird. The > > new > > > > photos show how the framework was built for the swing open > > door > > > and > > > > how it works, in conjunction with the original genset slide, > > also > > > > shown is how the original oil bath air filter was reused as a > > > > muffler for the air intake along with the new free flowing > > Dupree > > > > air filter, it had to be remounted to add clearance when the > > > drawer > > > > is closed. > > > > > > > > I suggest that you view all of the photos of this modification > > > > starting from the beginning at; > > > > > > > > > > <http://www.pbase.com/image/52361793>http://www.pbase.com/image/52361 793 > > > > > > > > John Finn > > > > "FINN'S INN EXPRESS" > > > > '82 Bluebird Wanderlodge 35FCRB > > > > Hopkins, SC > > > > "ON THE ROAD IN ORLANDO, FLA." > > > > To Visit the Finn's Inn Express Remodeling Adventure go to; > > > > > > <http://www.pbase.com/iamflagman/image/24977457>http://www.pbase.com/ iamflagman/image/24977457 > > > > > > > > > > > > > > > > > > > > > > > > ----------------------------------------------------------- ------ > > --- > > > ---------- > > > > YAHOO! GROUPS LINKS > > > > > > > > a.. Visit your group "wanderlodge" on the web. > > > > > > > > b.. To unsubscribe from this group, send an email to: > > > > wanderlodge-unsubscribe@yahoogroups.com > > > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! > > Terms > > > of Service. > > > > > > > > > > > > ----------------------------------------------------------- ------ > > --- > > > ---------- > > > > > > > > > > > > > > > > > > > > > > >------------------------------------------------------------------ ------------ > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "wanderlodge" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > wanderlodge-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > > of Service. > > > > > >------------------------------------------------------------------ ------------ > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > |
11-23-2005, 11:25
genset tray
Prabably factory. Genset has only 276 hours on it
----- Original Message ----- From: rwoodysurplus To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, November 23, 2005 5:09 PM Subject: [WanderlodgeForum] Re: Genset tray mine is factory as far as i can tell and it is above the floor you musta had somebody cutting on the floor to change oil with outsliding the set out or ......a add on big dia. gen set that wouldnot fit under frame! that is why scott got a side mounted gen set in his fc at powerteck! woody 81 fbrbsgd ft bragg nc --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > The oil pan on my 1982 FC35 perkins generator is several inches above > the tray. There are no cutouts in it. > > Tom Warner > 1982 FC35 > Vernon Center,NY > > At 12:08 PM 11/23/2005, you wrote: > >A question for John and anyone else that might know. > > > >It appears from the pictures of your radiator upgrade that the oil > >pan of the Perkins sets above the slide out tray, Is this correct? > >On my bird the tray has been cut to allow the oil pan to set below > >that tray and the isolation springs boIt thru the tray. believe > >that to be the reason the tray buckled in the center.Has any one had > >this issue and is there a possibility to remanufacture and raise the > >genset to eliminate this weakness? > > > >Glenn Shehorn > >83 FC 35 > >Kansas City Mo > > ----- Original Message ----- > > From: John > > To: wanderlodge@yahoogroups.com > > Sent: Wednesday, November 23, 2005 9:35 AM > > Subject: [wanderlodge] Re: MORE PHOTOS OF FC MODEL GENSET MODIFICATION > > > > > > I forgot to answer the temperature question from Randy, although it > > is cool here this morning and hasen't gotten into the 70's since I > > have been here, the temperatures have been similar to what I had > > experienced with the original configuration, right now it is 55 > > degrees outside and under load the temperature is running at 170 > > degrees, the highest the temperature has gone is 175 degrees so far. > > Randy wired the fan speed the same as what his genset fan speed was > > wired at on his 'Bird. I don't think that temperature will be an > > issue, as I can wire the fan to run at three different speeds and I > > believe that it is currently wired at the middle speed. > > > > John Finn > > "FINN'S INN EXPRESS" > > '82 Bluebird Wanderlodge 35FCRB > > Hopkins, SC > > "ON THE ROAD IN ORLANDO, FLA." > > To Visit the Finn's Inn Express Remodeling Adventure go to; > > > ><http://www.pbase.com/iamflagman/image/24977457>http://www.pbase.com /iamflagman/image/24977457 > > > > ///////////////////////////////////////////////////////////////// //// > > > > --- In wanderlodge@yahoogroups.com, "Scott" wrote: > > > > > > "oil leaks" I know where there is a perkins that doesn't leak a > > drop > > > of oil and only has 1800 hrs on it! John sounds greatdid the > > > temps come down..bet you like the door for service and checking > > > fluids that is a great idea... > > > > > > Scott B > > > 86FC35 > > > SC (with a cast on right arm..tore a muscle trying to open water > > > filter on coach...dinner gonna be interesting tommorrow!) > > > > > > --- In wanderlodge@yahoogroups.com, randydupree wrote: > > > > > > > > john,now that you've been running it for a day or so,hows the > > > temps,and how did we do on the oil leaks? > > > > randy > > > > ----- Original Message ----- > > > > From: John > > > > To: wanderlodge@yahoogroups.com > > > > Sent: Wednesday, November 23, 2005 2:40 AM > > > > Subject: [wanderlodge] MORE PHOTOS OF FC MODEL GENSET > > MODIFICATION > > > > > > > > > > > > I have added and rearranged some of the photos of the genset > > > > modification that was done by Randy Dupree on my 'Bird. The > > new > > > > photos show how the framework was built for the swing open > > door > > > and > > > > how it works, in conjunction with the original genset slide, > > also > > > > shown is how the original oil bath air filter was reused as a > > > > muffler for the air intake along with the new free flowing > > Dupree > > > > air filter, it had to be remounted to add clearance when the > > > drawer > > > > is closed. > > > > > > > > I suggest that you view all of the photos of this modification > > > > starting from the beginning at; > > > > > > > > > > <http://www.pbase.com/image/52361793>http://www.pbase.com/image/52361 793 > > > > > > > > John Finn > > > > "FINN'S INN EXPRESS" > > > > '82 Bluebird Wanderlodge 35FCRB > > > > Hopkins, SC > > > > "ON THE ROAD IN ORLANDO, FLA." > > > > To Visit the Finn's Inn Express Remodeling Adventure go to; > > > > > > <http://www.pbase.com/iamflagman/image/24977457>http://www.pbase.com/ iamflagman/image/24977457 > > > > > > > > > > > > > > > > > > > > > > > > ----------------------------------------------------------- ------ > > --- > > > ---------- > > > > YAHOO! GROUPS LINKS > > > > > > > > a.. Visit your group "wanderlodge" on the web. > > > > > > > > b.. To unsubscribe from this group, send an email to: > > > > wanderlodge-unsubscribe@yahoogroups.com > > > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! > > Terms > > > of Service. > > > > > > > > > > > > ----------------------------------------------------------- ------ > > --- > > > ---------- > > > > > > > > > > > > > > > > > > > > > > >------------------------------------------------------------------ ------------ > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "wanderlodge" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > wanderlodge-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > > of Service. > > > > > >------------------------------------------------------------------ ------------ > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
11-23-2005, 15:10
genset tray
Glen,
I modified my 78 FC to get rid of the Onan 6KW and install a 10KW Wrico Diesel which was the biggest I could get into the space. The best mod I even made to any RV! I am sure you could modify/repair the stock rack. You might be able to simply jack up the deck and put some reinforcing braces across the inside of the deck fore and aft of the gen mounts. Cutting the hole probably did weaken the deck. If you need any help, give us a call. 940-241-2244 Bob & Judy Johannesen 91WLWB40 "Seldom Blue" g Prabably factory. Genset has only 276 hours on it ----- Original Message ----- From: rwoodysurplus To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, November 23, 2005 5:09 PM Subject: [WanderlodgeForum] Re: Genset tray mine is factory as far as i can tell and it is above the floor you musta had somebody cutting on the floor to change oil with outsliding the set out or ......a add on big dia. gen set that wouldnot fit under frame! that is why scott got a side mounted gen set in his fc at powerteck! woody 81 fbrbsgd ft bragg nc --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > The oil pan on my 1982 FC35 perkins generator is several inches above > the tray. There are no cutouts in it. > > Tom Warner > 1982 FC35 > Vernon Center,NY > > At 12:08 PM 11/23/2005, you wrote: > >A question for John and anyone else that might know. > > > >It appears from the pictures of your radiator upgrade that the oil > >pan of the Perkins sets above the slide out tray, Is this correct? > >On my bird the tray has been cut to allow the oil pan to set below > >that tray and the isolation springs boIt thru the tray. believe > >that to be the reason the tray buckled in the center.Has any one had > >this issue and is there a possibility to remanufacture and raise the > >genset to eliminate this weakness? > > > >Glenn Shehorn > >83 FC 35 > >Kansas City Mo > > ----- Original Message ----- > > From: John > > To: wanderlodge@yahoogroups.com > > Sent: Wednesday, November 23, 2005 9:35 AM > > Subject: [wanderlodge] Re: MORE PHOTOS OF FC MODEL GENSET MODIFICATION > > > > > > I forgot to answer the temperature question from Randy, although it > > is cool here this morning and hasen't gotten into the 70's since I > > have been here, the temperatures have been similar to what I had > > experienced with the original configuration, right now it is 55 > > degrees outside and under load the temperature is running at 170 > > degrees, the highest the temperature has gone is 175 degrees so far. > > Randy wired the fan speed the same as what his genset fan speed was > > wired at on his 'Bird. I don't think that temperature will be an > > issue, as I can wire the fan to run at three different speeds and I > > believe that it is currently wired at the middle speed. > > > > John Finn > > "FINN'S INN EXPRESS" > > '82 Bluebird Wanderlodge 35FCRB > > Hopkins, SC > > "ON THE ROAD IN ORLANDO, FLA." > > To Visit the Finn's Inn Express Remodeling Adventure go to; > > > ><http://www.pbase.com/iamflagman/image/24977457>http://www.pbase.com /iamflagman/image/24977457 > > > > ///////////////////////////////////////////////////////////////// //// > > > > --- In wanderlodge@yahoogroups.com, "Scott" wrote: > > > > > > "oil leaks" I know where there is a perkins that doesn't leak a > > drop > > > of oil and only has 1800 hrs on it! John sounds greatdid the > > > temps come down..bet you like the door for service and checking > > > fluids that is a great idea... > > > > > > Scott B > > > 86FC35 > > > SC (with a cast on right arm..tore a muscle trying to open water > > > filter on coach...dinner gonna be interesting tommorrow!) > > > > > > --- In wanderlodge@yahoogroups.com, randydupree wrote: > > > > > > > > john,now that you've been running it for a day or so,hows the > > > temps,and how did we do on the oil leaks? > > > > randy > > > > ----- Original Message ----- > > > > From: John > > > > To: wanderlodge@yahoogroups.com > > > > Sent: Wednesday, November 23, 2005 2:40 AM > > > > Subject: [wanderlodge] MORE PHOTOS OF FC MODEL GENSET > > MODIFICATION > > > > > > > > > > > > I have added and rearranged some of the photos of the genset > > > > modification that was done by Randy Dupree on my 'Bird. The > > new > > > > photos show how the framework was built for the swing open > > door > > > and > > > > how it works, in conjunction with the original genset slide, > > also > > > > shown is how the original oil bath air filter was reused as a > > > > muffler for the air intake along with the new free flowing > > Dupree > > > > air filter, it had to be remounted to add clearance when the > > > drawer > > > > is closed. > > > > > > > > I suggest that you view all of the photos of this modification > > > > starting from the beginning at; > > > > > > > > > > <http://www.pbase.com/image/52361793>http://www.pbase.com/image/52361 793 > > > > > > > > John Finn > > > > "FINN'S INN EXPRESS" > > > > '82 Bluebird Wanderlodge 35FCRB > > > > Hopkins, SC > > > > "ON THE ROAD IN ORLANDO, FLA." > > > > To Visit the Finn's Inn Express Remodeling Adventure go to; > > > > > > <http://www.pbase.com/iamflagman/image/24977457>http://www.pbase.com/ iamflagman/image/24977457 > > > > > > > > > > > > > > > > > > > > > > > > ----------------------------------------------------------- ------ > > --- > > > ---------- > > > > YAHOO! GROUPS LINKS > > > > > > > > a.. Visit your group "wanderlodge" on the web. > > > > > > > > b.. To unsubscribe from this group, send an email to: > > > > wanderlodge-unsubscribe@yahoogroups.com > > > > > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! > > Terms > > > of Service. > > > > > > > > > > > > ----------------------------------------------------------- ------ > > --- > > > ---------- > > > > > > > > > > > > > > > > > > > > > > >------------------------------------------------------------------ ------------ > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "wanderlodge" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > wanderlodge-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms > > of Service. > > > > > >------------------------------------------------------------------ ------------ > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > >---------- > >YAHOO! GROUPS LINKS > > > > * Visit your group > > "<http://groups.yahoo.com/group/WanderlodgeForum>WanderlodgeForum" on the web. > > * > > * To unsubscribe from this group, send an email to: > > * > > > > > > * > > * Your use of Yahoo! Groups is subject to the > > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. > > > > > >---------- > ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators --------------------------------- YAHOO! GROUPS LINKS Visit your group "WanderlodgeForum" on the web. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. --------------------------------- --------------------------------- Yahoo! Music Unlimited - Access over 1 million songs. Try it free. [Non-text portions of this message have been removed] |
