jacobs electric retarder------ help
05-05-2007, 13:49
a few weeks ago my retarder brake stopped working and now its time to
look for the problem. i have looked at the prints and info in the files and it tells me to check the 6amp fuse in line to the switch. can anyone tell me how to fine this fuse or do you know where it might be. it is a pain in the b---, but i hope that is the problem. i have checked the 12volt power to the retarder itsself and i have the required power. i have not opened the contact box yet and hope that i dont have to. the lever that controls the brake is mounted to the side of the trans shift lever box and has 5 wires running to it. anyone that has worked on this type unit and can help please chime in. thanks to all that share their knowledge with others. ed and peggy mcstay 83fc rb 35ft. "lonesome dove" lake charles, louisiana |
05-05-2007, 15:34
Ed I had my retarder quit also and spent a lot of time on it. Check
for 12v on your hand control with the dash switch on and the lever in position 1,in postion 2 you should have power at terminal 1 & 2,in position 3 power on 1,2 & 3. You should hear your brake light relay click when ever you move from off to position 1. Power at terminals but no click? your problem is under the bus. On mine the relay box/retarder ground was bad(Bluebird used a star washer between frame and cable-rusty)Remove heavy battery leads from blade fuse above relay box(disconnect coach batteries first) Mine were black from oxidation and only had a 1/32 of clean surface to carry 100+amps- won't work. I removed my relay box(mark all of the wires first) and on the bench removed & cleaned all of the dog bone shaped connector strips on the relays(strips on relay 1 & 2 had seen a lot of heat and one fell apart so I made a new one out of two non- insulated ring terminals and a piece of 14 gauge ground wire)Clean the points on the relays lightly with a point file check both side and top gaps as per Retarder service manual in Files. Remove and clean any terminal nuts you can Then spray all down with a good quality electronics cleaner. Reinstall & clean the wire terminals on the wires you unhooked. Tighten all connections including the ones on the retarder. power up and you should now have the brake light relay clicking and the retarder retarding. After I did all of this mine now works like new and it is even effective in normal driving(slowing up for stop signs etc.) Jim Matus FC35SB Rescue CA -- - In WanderlodgeForum@yahoogroups.com, "Peggy & Ed McStay" > > a few weeks ago my retarder brake stopped working and now its time to > look for the problem. i have looked at the prints and info in the files > and it tells me to check the 6amp fuse in line to the switch. can > anyone tell me how to fine this fuse or do you know where it might be. > it is a pain in the b---, but i hope that is the problem. i have > checked the 12volt power to the retarder itsself and i have the > required power. i have not opened the contact box yet and hope that i > dont have to. the lever that controls the brake is mounted to the side > of the trans shift lever box and has 5 wires running to it. anyone that > has worked on this type unit and can help please chime in. thanks to > all that share their knowledge with others. > > ed and peggy mcstay > 83fc rb 35ft. > "lonesome dove" > lake charles, louisiana > |
