Patterns for doghouse insulation
03-25-2006, 07:24
Kerry, did you insulate the base of the dooghouse, also? Ernie-83pt40 in
Texas [Non-text portions of this message have been removed] |
03-25-2006, 11:55
I installed insulation in the doghouse top of my 82 FC35 today. I
made patterns first and then cut out sections of heavy foam, foil and a heavy layer and glued them in. I'm going to throw away the patterns unless someone wants to use them to cut out insulation for the doghouse. The patterns are not perfect but they are close. If you want them, PM me and I'll drop them in the mail to you. It'll save you 45 minutes of pattern making. There are four pieces, front, back, and two small pieces for the indentation on the driver's side. Kerry 82 FC 35 Denver |
03-25-2006, 12:56
I'll do the left side tomorrow when I reinstall the top. The right
is tighter, requiring the removal of the oil fill mechanism so I think I'll wait on that. It had been reinsulated in the past with poor quality foil covered matting of some kind. It was gone on most of the top, but is still in place on the sides. Kerry --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Kerry, did you insulate the base of the dooghouse, also? Ernie-83pt40 in > Texas > > > [Non-text portions of this message have been removed] > |
