What is this sensor?
03-23-2006, 10:53
There is a sensor on my bus that is crushed and I do
not know what its for. Apparently someone did not like this electronic
device, because it has been smashed..??$^*#$@#
My hunch is the "panic button" Buzzer in the kitchen.? It is to the
right of the florescent Light above the sink. When I hit the 'panic
button' nothing happens. However, could be wrong... I have posted a
picture under "files section" that I will delete in a day or so if you
can check it out.
Thank you,
Stephen
81 FC-33SB
Plant City, FL
03-23-2006, 11:40
Doesn't help us much since you didn't give us a picture of the button
or sensor. All you show in your picture is where it is located. You
would be surprised at how different each coach can be and each years
location of controls and sensors.
Send a shot looking at the specific sensor.
Thanks,
> can check it out.
> Thank you,
> Stephen
> 81 FC-33SB
> Plant City, FL
03-23-2006, 12:00
I know- I didn't have one here at home.:-( I will go to the bus and get a
picture of the broken sensor (what's left of it) .
Thanks,
Stephen
81 FC-33SB
Plant City, FL
_____
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of ronmarabito2002
Sent: Thursday, March 23, 2006 6:41 PM
Subject: [WanderlodgeForum] Re: What is this sensor?
Thanks,
03-23-2006, 12:33
I can't see it in the photo, but it is probably the indoor
temperature sensor (thermistor) for the galley monitor panel.
- Jeff Miller
in Holland, MI
electronic
you
> can check it out.
> Thank you,
> Stephen
> 81 FC-33SB
> Plant City, FL
