Chassis Heat?
03-23-2006, 05:53
Chassis Heat?
Hi Henry,
Do you have a "Summer/Winter" switch? Do you have an "Aux Pump" switch? If so, it needs to be switched to "Winter" and the aux pump assists in getting all that hot coolant (contrary terms) into the coach heater cores. There are Sporlan Valves in that system, so one might be stuck, too, if the aforementioned don't work. Heaters not needed here in SoCal right now.....just got done mowing both lawns, and I'm tired!! Kevin McKeown Yorba Linda, CA 1986 38' PT [Non-text portions of this message have been removed] |
03-23-2006, 05:55
Chassis Heat?
Henry,
Forgot to mention...your engine coolant has to be up to operating temp if you expect any heat from the chassis heaters. But, you probably already know that...right? Kevin YL CA 86 38 PT [Non-text portions of this message have been removed] |
03-23-2006, 10:30
Chassis Heat?
My chasis heat thermostat turns on all three blowers so I figure that
it's working. I opened the round valves in the hoses under the engine to allow hot water to flow to the back of the coach. All I get is cold air from the registers. What should I check next? Henry@... In Austin, Tx., 1979 FC 35. |
03-23-2006, 11:53
Chassis Heat?
You need to verify the circulation pump is on, my rear bath FC likes the pump
even running down the road. There is a lot of coolant to move and the engine water pump can't do it all. That is the reason the accessory pump was added. Mike Hohnstein Germantown, WI 83FC35 ----- Original Message ----- From: krminyl@... To: WanderlodgeForum@yahoogroups.com Sent: Thursday, March 23, 2006 4:55 PM Subject: Re: [WanderlodgeForum] Chassis Heat? Henry, Forgot to mention...your engine coolant has to be up to operating temp if you expect any heat from the chassis heaters. But, you probably already know that...right? Kevin YL CA 86 38 PT [Non-text portions of this message have been removed] SPONSORED LINKS Recreational vehicles Wanderlodge Automotive maintenance Recreational vehicle dealer Used recreational vehicles Automotive radiators ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
03-23-2006, 12:28
Chassis Heat?
Near the floor in the rear are two push-pull cables. For rear heat, one
out one in, for no rear heat and domestic-water heat only (motoraid), the other cable out/other cable in. The valves can be seen at the other end of the cables by lifting the mattress and plywood under the bed, next to the water heater. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, Henry Claeys > > My chasis heat thermostat turns on all three blowers so I figure that > it's working. I opened the round valves in the hoses under the engine > to allow hot water to flow to the back of the coach. All I get is cold > air from the registers. What should I check next? > Henry@... In Austin, Tx., 1979 FC 35. > |
03-23-2006, 20:21
Chassis Heat?
Kevin. I have both switches but only turned on the "Summer/Winter" switch
because I didn't know what the "Aux Pump" switch was for. I'll try turning both switches on, next time, and see what happens. Thanks. Henry@... in Austin, Tx. 1979 FC 35. Message: 22 Date: Thu, 23 Mar 2006 17:53:52 EST From: krminyl@... Subject: Re: Chassis Heat? Hi Henry, Do you have a "Summer/Winter" switch? Do you have an "Aux Pump" switch? If so, it needs to be switched to "Winter" and the aux pump assists in getting all that hot coolant (contrary terms) into the coach heater cores. There are Sporlan Valves in that system, so one might be stuck, too, if the aforementioned don't work. Heaters not needed here in SoCal right now.....just got done mowing both lawns, and I'm tired!! Kevin McKeown Yorba Linda, CA 1986 38' PT |
