Onan 8.0 89sp glow plugs-how can you tell if good?
05-13-2006, 06:42
I have to crank my gen set a long time before it starts firing and
then it sputters a while before it finnaly runs smooth. I just read a
post recentily that a glow plun can be bad and cause this problem. How
can you check them to see if they are bad? With a meter? Do you have
to pull them out?
Thanks in advance for any help-- Im still working on the ideas from
the forum on my telescoping , or non-telescoping steering wheel
Ed 89sp
Arlington Texas
05-13-2006, 06:57
Ed,
Are you holding the switch to the 'stop' position to activate the glow
plugs and fuel pump before going to the 'start' position?
If not, I believe this is the proper technique. I normally count to
between ten and twenty while holding the switch, depending on
conditions.
Gary Miller
83 FC 33 - Powertech 7.0 diesel
Milwaukee area
--- In WanderlodgeForum@yahoogroups.com, "ED GARDELS"
a
How
> to pull them out?
from
> Ed 89sp
> Arlington Texas
