Generator related questions
05-17-2006, 11:19
Thanks. I flipped the breakers a couple of times. I'll look for the
other switches. Kerry --- In WanderlodgeForum@yahoogroups.com, krminyl@... wrote: > > Hi Kerry, > > It may sound elementary, but the breakers are deceiving...flip the breakers > to "off", then to "on" again. When tripped, it's kind of hard to tell > visually if they are tripped. Also, are your overhead toggle switches turned to > the "on" position (on my PT they are overhead and on the left side of the > driver's head...one toggle switch for each roof air/floor level 110V heater). > These switches control the 110V AC heaters located down near the floor, and the > 110V AC roof air conditioners. Make sure only the roof air or floor heaters > are turned on, not both at the same time. If the roof airs still don't work > (toggle switch "on", selector switch on the roof air set to "cool", > shore/gen switch sen to GEN), see if the 110V heaters turn on...if they do, than will > narrow down your troubleshooting to the roof airs. Like with most system > issues with BB, it's usually something simple. > > Good luck, > > Kevin McKeown > Yorba Linda, CA > 86 38PT > > > [Non-text portions of this message have been removed] > |
05-17-2006, 13:42
Kerry,
On my '82 FC35RB 'Bird the airconditioner wall switches are located next to the driver s seat, you can see them in this photo; http://www.pbase.com/iamflagman/image/34374169 Here is what I have listed that I used on my Perkins, for belts, hoses and filters and other items, that you may be interested in making a note of them. My Perkins has a water cooled exhaust manifold, so keep this in mind, to see if yours has the same configuration; These are the part numbers that you need to replace all the hoses on your Kohler/Perkins 12.5 KW . All are available from Auto Zone. 2ea. M-248 (1) thermostat housing to exhaust manifold cooler inlet (1) exhaust manifold cooler outlet to inflow tube to radiator 1ea M-049 top radiator inlet hose from inflow tube 1ea L-326 bottom radiator outlet hose to outflow tube inlet (this tube is reduced down in size directly after the hose connection) 1ea L-978 radiator outflow tube outlet to engine block (SEE NOTE) This is a Cut and Fit project. The Molded hose (L-978) has two different end diameters, make sure that you use the smaller diameter end trimmed down to the block side and cut the larger diameter end off, just before the bend. ///////////////////////////////////////////////////////// PERKINS FILTERS OIL NAPA GOLD 1806 FUEL NAPA 3166 /////////////////////////////////////////////////////////// LOCATE YOUR ENGINE NUMBER NEAR THE IDLER PULLEY FOR THE WATER PUMP/CRANKSHAFT BELT ////////////////////////////////////////////////////////// High Water Temperature Shut Down Sending unit (Perkins Generator Engine) BLUEBIRD #4176483 $88.00 NIXON POWER #241308 (KOHLER PART) $45.72 -------------------------------------------------------- Low Oil Pressure Shut Down sending unit (Perkins Generator Engine) BLUEBIRD #4176491 $41.49 NIXON POWER #271662 (OLD) REPLACED BY #328309 (NEW STYLE KOHLER PART**) $21.36 **FOR INSTALLATION TIP GO TO; http://www.pbase.com/iamflagman/image/50053227 ***Nixon Power Services 800-766-4966*** ////////////////////////////////////////////////////////////////////// // Thermostat NAPA #382-190 Gasket 1038-ST The thermostat is made by VW-AUDI and has these numbers inscribed on it; BTT 050 121 113C 1.180 87 degrees Celsius (that converts to 188.6 Fahrenheit) //////////////////////////////////////////////////////////////////// Perkins "V" Belt 40 inches long AutoZone and Advance Auto part DAYCO #15400 (11A1015) NAPA PREMIUM XL 25-10153 (not positive on this number, be sure to measure) ///////////////////////////////////////////// RADIATOR CAP 7# CARQUEST #33029 //////////////////////////////////////////// OIL PRESSURE SENDING UNIT FOR GAUGE NAPA #OP6622 I hope that this helps. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 HOPKINS, SOUTH CAROLINA ///////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > Thanks. I flipped the breakers a couple of times. I'll look for the > other switches. > > Kerry > > --- In WanderlodgeForum@yahoogroups.com, krminyl@ wrote: > > > > Hi Kerry, > > > > It may sound elementary, but the breakers are deceiving...flip the > breakers > > to "off", then to "on" again. When tripped, it's kind of hard to tell > > visually if they are tripped. Also, are your overhead toggle > switches turned to > > the "on" position (on my PT they are overhead and on the left side > of the > > driver's head...one toggle switch for each roof air/floor level 110V > heater). > > These switches control the 110V AC heaters located down near the > floor, and the > > 110V AC roof air conditioners. Make sure only the roof air or > floor heaters > > are turned on, not both at the same time. If the roof airs still > don't work > > (toggle switch "on", selector switch on the roof air set to "cool", > > shore/gen switch sen to GEN), see if the 110V heaters turn on...if > they do, than will > > narrow down your troubleshooting to the roof airs. Like with most > system > > issues with BB, it's usually something simple. > > > > Good luck, > > > > Kevin McKeown > > Yorba Linda, CA > > 86 38PT > > > > > > [Non-text portions of this message have been removed] > > > |
05-17-2006, 13:58
John:
Thank you very much. Just what I needed. I had figured out the oil and fuel filters today at NAPA but the rest of the those numbers are just what I was looking for. For some reason, the numbers in the manual for the Kohler in my bluebox are not the correct ones for my generator. Those switches look familiar also. I'll check when I go to the storage lot tomorrow to change the oil in the generator. I noticed there was some weeping on either the low oil pressure shut off sender or the gauge sender so those numbers will be of immediate use. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "John" > > Kerry, > > On my '82 FC35RB 'Bird the airconditioner wall switches are located > next to the driver s seat, you can see them in this photo; > > http://www.pbase.com/iamflagman/image/34374169 > > Here is what I have listed that I used on my Perkins, for belts, > hoses and filters and other items, that you may be interested in > making a note of them. My Perkins has a water cooled exhaust > manifold, so keep this in mind, to see if yours has the same > configuration; > > These are the part numbers that you need to replace all the hoses on > your Kohler/Perkins 12.5 KW . All are available from Auto Zone. > > 2ea. M-248 (1) thermostat housing to exhaust manifold cooler inlet > (1) exhaust manifold cooler outlet to inflow tube to > radiator > 1ea M-049 top radiator inlet hose from inflow tube > 1ea L-326 bottom radiator outlet hose to outflow tube inlet (this > tube is reduced down in size directly after the hose connection) > 1ea L-978 radiator outflow tube outlet to engine block (SEE NOTE) > > This is a Cut and Fit project. The Molded hose (L-978) has two > different end diameters, make sure that you use the smaller diameter > end trimmed down to the block side and cut the larger diameter end > off, just before the bend. > > ///////////////////////////////////////////////////////// > > PERKINS FILTERS > > OIL NAPA GOLD 1806 > > FUEL NAPA 3166 > > /////////////////////////////////////////////////////////// > > LOCATE YOUR ENGINE NUMBER NEAR THE IDLER PULLEY FOR THE WATER > PUMP/CRANKSHAFT BELT > > ////////////////////////////////////////////////////////// > > High Water Temperature Shut Down Sending unit (Perkins Generator > Engine) > > BLUEBIRD #4176483 $88.00 > > NIXON POWER #241308 (KOHLER PART) $45.72 > > -------------------------------------------------------- > > Low Oil Pressure Shut Down sending unit (Perkins Generator Engine) > > BLUEBIRD #4176491 $41.49 > > NIXON POWER #271662 (OLD) REPLACED BY #328309 (NEW STYLE KOHLER > PART**) $21.36 > > **FOR INSTALLATION TIP GO TO; > > http://www.pbase.com/iamflagman/image/50053227 > > > ***Nixon Power Services 800-766-4966*** > > ////////////////////////////////////////////////////////////////////// > // > > Thermostat > NAPA #382-190 > > Gasket > 1038-ST > > The thermostat is made by VW-AUDI and has these numbers inscribed on > it; > BTT > 050 121 113C > 1.180 > 87 degrees Celsius (that converts to 188.6 Fahrenheit) > > //////////////////////////////////////////////////////////////////// > > Perkins "V" Belt 40 inches long > > AutoZone and Advance Auto part DAYCO #15400 (11A1015) > > NAPA PREMIUM XL 25-10153 (not positive on this number, be sure to > measure) > > ///////////////////////////////////////////// > > RADIATOR CAP 7# CARQUEST #33029 > > //////////////////////////////////////////// > > OIL PRESSURE SENDING UNIT FOR GAUGE NAPA #OP6622 > > I hope that this helps. > > > "REMEMBER SEPTEMBER 11, 2001" > John Finn > '82 35FCRB > BLUEBIRD WANDERLODGE > TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE > GO TO; > http://www.pbase.com/image/24977457 > HOPKINS, SOUTH CAROLINA > > |
05-22-2006, 14:23
I run Baldwin filters on my Perkins. Next time I am up at the storage place
I can get the part numbers if you wish. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Wednesday, May 17, 2006 11:49 AM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Generator related questions It's an 82 FC. I'll check with NAPA. However, when I purchased the oil and fuel filters from NAPA based on the part numbers in the Bluebox, they were incorrect, so I was hoping to find a Kohler/Perkins expert. Kerry --- In WanderlodgeForum@yahoogroups.com, "John B. Montgomery, AIA" > > David, i get the messages to my email account and your message caught my attention. Check with your auto parts supplier/Store for the hoses. I replaced mine in the last year or so and it is a 1982 Perkins. What model is your coach? > > John > > John B. Montgomery > > johnb@... > > ----- Original Message ----- > From: davidkerryedwards > To: WanderlodgeForum@yahoogroups.com > Sent: Wednesday, May 17, 2006 11:41 AM > Subject: [WanderlodgeForum] Generator related questions > > > The generator slide tray is malfunctioning on my coach. If the > locking mechanism is disengaged and the coach aired up, it pushes out > the generator. Neither the key switch on the slide door or the switch > by the steps makes any difference. I assume there is an air/electric > switch somewhere that is stuck. Can someone tell me where it is > and/or how to troubleshoot it? > > Also, while the tray was out I fired up the generator. I had power to > the outlets but none of the AC's would work. Breakers were all on. > Anyone have any idea what is happening? They all worked ok when I > tested them when purchasing the coach a few months ago. > > Finally, what is a good source for all the radiator hoses on the > Perkins 12.5? Mine are all original and could stand replacing. > > Thanks. > > Kerry > 82 FC 35 > Denver > > > > > > > ---------------------------------------------------------------------------- -- > YAHOO! GROUPS LINKS > > a.. Visit your group "WanderlodgeForum" on the web. > > b.. To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. > > > ---------------------------------------------------------------------------- -- > > > > [Non-text portions of this message have been removed] > SPONSORED LINKS Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4= Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v ehicle+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> vehicles Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+financing&w1=Recre ational+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+r epair&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recre ational+vehicle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> vehicle financing Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+repair&w1=Recreati onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati onal+vehicle+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> vehicle repair Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rental&w1=Recreati onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati onal+vehicle+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> vehicle rental Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+camper&w1=Recreati onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati onal+vehicle+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> vehicle camper Recreational <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rate&w1=Recreation al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreation al+vehicle+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> vehicle rate _____ YAHOO! GROUPS LINKS * Visit your group "WanderlodgeForum <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . _____ [Non-text portions of this message have been removed] |
05-22-2006, 14:50
There's a list of filters for the Perkins in the Files at
http://autos.groups.yahoo.com/group/Wand...20Filters/ Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX (currently in Salt Lake City) --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > I run Baldwin filters on my Perkins. Next time I am up at the storage place > I can get the part numbers if you wish. > > - Chuck Wheeler - > 82 FC 31 SB > Fort Worth, TX > > > _____ > > From: WanderlodgeForum@yahoogroups.com > [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards > Sent: Wednesday, May 17, 2006 11:49 AM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Generator related questions > > > It's an 82 FC. I'll check with NAPA. However, when I purchased the > oil and fuel filters from NAPA based on the part numbers in the > Bluebox, they were incorrect, so I was hoping to find a Kohler/Perkins > expert. > > Kerry > > --- In WanderlodgeForum@yahoogroups.com, "John B. Montgomery, AIA" > > > > > David, i get the messages to my email account and your message > caught my attention. Check with your auto parts supplier/Store for > the hoses. I replaced mine in the last year or so and it is a 1982 > Perkins. What model is your coach? > > > > John > > > > John B. Montgomery > > > > johnb@ > > > > ----- Original Message ----- > > From: davidkerryedwards > > To: WanderlodgeForum@yahoogroups.com > > Sent: Wednesday, May 17, 2006 11:41 AM > > Subject: [WanderlodgeForum] Generator related questions > > > > > > The generator slide tray is malfunctioning on my coach. If the > > locking mechanism is disengaged and the coach aired up, it pushes out > > the generator. Neither the key switch on the slide door or the switch > > by the steps makes any difference. I assume there is an air/electric > > switch somewhere that is stuck. Can someone tell me where it is > > and/or how to troubleshoot it? > > > > Also, while the tray was out I fired up the generator. I had power to > > the outlets but none of the AC's would work. Breakers were all on. > > Anyone have any idea what is happening? They all worked ok when I > > tested them when purchasing the coach a few months ago. > > > > Finally, what is a good source for all the radiator hoses on the > > Perkins 12.5? Mine are all original and could stand replacing. > > > > Thanks. > > > > Kerry > > 82 FC 35 > > Denver > > > > > > > > > > > > > > > ---------------------------------------------------------------------------- > -- > > YAHOO! GROUPS LINKS > > > > a.. Visit your group "WanderlodgeForum" on the web. > > > > b.. To unsubscribe from this group, send an email to: > > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service. > > > > > > > ---------------------------------------------------------------------------- > -- > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > SPONSORED LINKS > Recreational > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicles&w1=Recreational+v > ehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair&w4= > Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreational+v > ehicle+rate&c=6&s=193&.sig=_jXmbh7qWHD7DSskzUir3w> vehicles Recreational > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+financing&w1=Recre > ational+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+r > epair&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recre > ational+vehicle+rate&c=6&s=193&.sig=f_xgT1AKZsKXD6CT0_3nwg> vehicle > financing Recreational > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+repair&w1=Recreati > onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa > ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati > onal+vehicle+rate&c=6&s=193&.sig=0EDYS_wXU1aorG4893QXpQ> vehicle repair > > Recreational > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rental&w1=Recreati > onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa > ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati > onal+vehicle+rate&c=6&s=193&.sig=LNSmSf785IF1UlbWHRIOLA> vehicle rental > Recreational > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+camper&w1=Recreati > onal+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repa > ir&w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreati > onal+vehicle+rate&c=6&s=193&.sig=LoIo4UxSgNx-IyPMRku1lQ> vehicle camper > Recreational > <http://groups.yahoo.com/gads?t=ms&k=Recreational+vehicle+rate&w1=Recreation > al+vehicles&w2=Recreational+vehicle+financing&w3=Recreational+vehicle+repair > &w4=Recreational+vehicle+rental&w5=Recreational+vehicle+camper&w6=Recreation > al+vehicle+rate&c=6&s=193&.sig=N3ia10-EgZXwB7kJhwD4dw> vehicle rate > > _____ > > YAHOO! GROUPS LINKS > > > > * Visit your group "WanderlodgeForum > <http://groups.yahoo.com/group/WanderlodgeForum> " on the web. > > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service > <http://docs.yahoo.com/info/terms/> . > > > _____ > > > > > [Non-text portions of this message have been removed] > |
