coolant question from CO
05-28-2006, 00:08
Guy- had one of those hoses leak on my coach. Closed all valves- and no
problem. You can fix it later. Ernie-83pt40- Livingston, Montana [Non-text portions of this message have been removed] |
05-28-2006, 00:17
thosse valvs are hard to find and tough to get to. I believe there are 4?
Ernie- not at tthe coach to count [Non-text portions of this message have been removed] |
05-28-2006, 04:06
Hi
we are in Breckenridge CO loving it. Tiger Run RV resort which is great. The BB is running good after settling in I notice the secondary coolant hoses that go to the heating system was leaking, the main hoses are fine it is har to see which hose is leaking. my question the engine is running cool so if i close the values (4) to the heating system am I ok to run the coach? as I mentiom the main hoses to and from the engine & radiator are fine. I would prefer to work on her at home. I have a silver 92 v8 tubo any thoughts? guy smalley 86 pt 40 |
05-28-2006, 04:09
Hi Guy:
Close the valves and run. Remember though, you may not have the hydro heat to the hot water tank after a run. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 04:06 PM 5/28/2006 +0000, you wrote: >Hi >we are in Breckenridge CO loving it. Tiger Run RV resort which is great. >The BB is running good after settling in I notice the secondary coolant >hoses that go to the >heating system was leaking, the main hoses are fine it is har to see which >hose is leaking. >my question the engine is running cool so if i close the values (4) to the >heating system am I >ok to run the coach? as I mentiom the main hoses to and from the engine & >radiator are fine. >I would prefer to work on her at home. I have a silver 92 v8 tubo >any thoughts? > >guy smalley >86 pt 40 |
05-28-2006, 05:31
The blue book says four I found three easy then the fourth behind the back
bumper -guy smalley --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > thosse valvs are hard to find and tough to get to. I believe there are 4? > Ernie- not at tthe coach to count > > > [Non-text portions of this message have been removed] > |
