basement air conditioners
05-23-2006, 05:09
I notice a lack of performace on my acs so I took out the filters which I clean
normally. no different, so I look back into the air return its dark so I used my flash light to see up close and realized theres a sreen mesh inserted next to the cooling coils which were completely blocked with years of crud. now I can hang meat inside the BB, what a difference. I didn;t know the screens were there! guy smalley chilling out in UT 86 pt 40 |
05-27-2006, 01:54
Guy,
Do you have the central air in the basement. Did you access these screens inside the coach or in the basement. How many screens did you find. Do you think this was a factory install item. Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: guysmalley To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, May 23, 2006 1:09 PM Subject: [WanderlodgeForum] basement air conditioners I notice a lack of performace on my acs so I took out the filters which I clean normally. no different, so I look back into the air return its dark so I used my flash light to see up close and realized theres a sreen mesh inserted next to the cooling coils which were completely blocked with years of crud. now I can hang meat inside the BB, what a difference. I didn;t know the screens were there! guy smalley chilling out in UT 86 pt 40 SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-27-2006, 04:49
The basement air's are Cruise Air units. They are a split system, condenser
in the basement and the evaporator in the Coach. There are 3 of these systems in the Coaches. The screens are original with the systems and are important as it keeps dust/pet hair and the rest out of the coils. Or rather helps to anyway. I removed mine, cleaned them then I did wrap tape around the edges to help put them back in the proper place. Air flow keeps the icing down of course so cleaning them is essential. The are charged with R-22 and a little more fussy when servicing them but when done right, you can hang meat in the Coach Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 09:54 AM 5/27/2006 -0400, you wrote: >Guy, >Do you have the central air in the basement. Did you access these screens >inside the coach or in the basement. How many screens did you find. Do you >think this was a factory install item. >Howard Truitt >Camilla, Ga. >86 PT40 > ----- Original Message ----- > From: guysmalley > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, May 23, 2006 1:09 PM > Subject: [WanderlodgeForum] basement air conditioners > > > I notice a lack of performace on my acs so I took out the filters which > I clean normally. no > different, so I look back into the air return its dark so I used my > flash light to see up close > and realized theres a sreen mesh inserted next to the cooling coils > which were completely > blocked with years of crud. now I can hang meat inside the BB, what a > difference. > I didn;t know the screens were there! > > guy smalley > chilling out in UT > 86 pt 40 > > > > > |
05-27-2006, 22:23
Howard, on my cruise airs, my filters were way up inside the air cavity. You
can see them when you remove the first filter. Use a good flashlite. Ernie-83pt40 in Montana, snow in the mountains, no air conditioning required [Non-text portions of this message have been removed] |
05-28-2006, 02:20
Ralph,
I have replaced the square metal filters because the foam had deteriorated. Am I to understand that there is another set of filters or screens in front of the evaporators. Where do I find the evaporators and how do I access the filters at the evaporators. Thanks, Howard Truitt Camilla, Ga. 86 PT40 ----- Original Message ----- From: Ralph L. Fullenwider To: WanderlodgeForum@yahoogroups.com Sent: Saturday, May 27, 2006 12:49 PM Subject: Re: [WanderlodgeForum] basement air conditioners The basement air's are Cruise Air units. They are a split system, condenser in the basement and the evaporator in the Coach. There are 3 of these systems in the Coaches. The screens are original with the systems and are important as it keeps dust/pet hair and the rest out of the coils. Or rather helps to anyway. I removed mine, cleaned them then I did wrap tape around the edges to help put them back in the proper place. Air flow keeps the icing down of course so cleaning them is essential. The are charged with R-22 and a little more fussy when servicing them but when done right, you can hang meat in the Coach Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 09:54 AM 5/27/2006 -0400, you wrote: >Guy, >Do you have the central air in the basement. Did you access these screens >inside the coach or in the basement. How many screens did you find. Do you >think this was a factory install item. >Howard Truitt >Camilla, Ga. >86 PT40 > ----- Original Message ----- > From: guysmalley > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, May 23, 2006 1:09 PM > Subject: [WanderlodgeForum] basement air conditioners > > > I notice a lack of performace on my acs so I took out the filters which > I clean normally. no > different, so I look back into the air return its dark so I used my > flash light to see up close > and realized theres a sreen mesh inserted next to the cooling coils > which were completely > blocked with years of crud. now I can hang meat inside the BB, what a > difference. > I didn;t know the screens were there! > > guy smalley > chilling out in UT > 86 pt 40 > > > > > SPONSORED LINKS Recreational vehicles Recreational vehicle financing Recreational vehicle repair Recreational vehicle rental Recreational vehicle camper Recreational vehicle rate ------------------------------------------------------------------------------ YAHOO! GROUPS LINKS a.. Visit your group "WanderlodgeForum" on the web. b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. ------------------------------------------------------------------------------ [Non-text portions of this message have been removed] |
05-28-2006, 02:37
Howard:
When you open the return air grills with the wafered foam filters, look deep inside and you will see the evaporator. In front of that coil there should be a mesh screen that needs to be pulled, replaced or cleaned then put back. This same screen will be on all 3 of your units. Safe travels, Ralph and Charolette Fullenwider Ralph's RV Solutions, Duncan, Oklahoma http://home.swbell.net/rlf47/index.htm At 10:20 AM 5/28/2006 -0400, you wrote: >Ralph, >I have replaced the square metal filters because the foam had >deteriorated. Am I to understand that there is another set of filters or >screens in front of the evaporators. Where do I find the evaporators and >how do I access the filters at the evaporators. >Thanks, >Howard Truitt >Camilla, Ga. >86 PT40 > ----- Original Message ----- > From: Ralph L. Fullenwider > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, May 27, 2006 12:49 PM > Subject: Re: [WanderlodgeForum] basement air conditioners > > > The basement air's are Cruise Air units. They are a split system, > condenser > in the basement and the evaporator in the Coach. There are 3 of these > systems in the Coaches. The screens are original with the systems and are > important as it keeps dust/pet hair and the rest out of the coils. Or > rather helps to anyway. I removed mine, cleaned them then I did wrap tape > around the edges to help put them back in the proper place. Air flow keeps > the icing down of course so cleaning them is essential. The are charged > with R-22 and a little more fussy when servicing them but when done right, > you can hang meat in the Coach > > |
