1070 31ft Wanderlodge
06-10-2006, 05:09
Howdy!
I'm a newbie and looking at a 1970 WL. And like any newbie have a lot of questions. Below is a description of an Ebay listing. Seems to me that this maybe a gas to diesel conversion. As it has the older 6 speed allison. Don't know why it has a clutch pedal....I think that some of the older units offered a 2 speed axle with the old big block gas engines. I like the older units. Its located in St. Louis Mo., and listed on Ebay (which may or may not be a good thing!) It sounds to me like it may have been in storage prior to this owner. 1) Is any one familiar with this unit? 2) Any thought about bidding or buying on bay or this unit? 3) Any good bus shops in the St. Louis Mo. that could go over it and give a good safety check and let what really needs to be done? 4) if I got the build number would BlueBird be able to give me any info? 5) Can the old Allison 6 speeds handle the torque of a 3208? 6) Is my fantasy hitting a wall of reality? 6) All comments gratefully received ![]() Thanks Thanks Jerry Hers the link <<http://cgi.ebay.com/ebaymotors/ws/eBayIS...rd=1&\ sspagename=STRK%3AMEWA%3AIT&rd=1>> Heres the discription: This is a 1970 Bluebird wanderlodge that has a 3208 catapiller diesel engine and a Alison 6 speed automatic transmission.The odometer reads 29975 and it seems to work fine,I am not the original owner so i can not verify.The bus has a clutch pedal in it too,not sure if it had a standard shift some time.I just had a new injector pump installed ($1100.00) also a fuel pump installed ($150.00).The batters are lass then a year old as well. The bus starts and runs great shifts great.The brakes seem ok,the radiator has a very small leak towards the bottom,shouldn't be too much to fix or just keep water in it.The coach sleeps 6 has central heat,2 roof air conditioners.4 burner stove,refrigerator,freezer,hot water heater,toilet stainless shower ,stainless double sink,onan generator (gas) electric start.Have NOT had generator running this year yet,The chassis has 2 diesel tanks and 1 gas tank for generator.The rear tank (diesel) is Not hooked up now It had old fuel in it ,so it was disconnected til it gets flushed out.The roof a/c have not been checked either.I really don't know much about the bus ,I bought it with intentions of doing a total restoration,but seem to have lost interest in project.The interior is all solid wood not vynl and plastic like all the newer coaches seem to have.It is also built on a blue Bird Bus Chassis not a beefed up pick up chassis like some of the other rv's out there.I would not hesitate to drive this anywere.The entry door needs a small piece of glass replaced and the door needs a key made too.The awning will need a replacement vynl but the rest of it seems fine.There are some slite signs of water marks on ceiling but seems like the problem was already fixed ,just needs to repaint ceiling.Roof looks fine,it also has a spare tire and wheel, there is a large luggage rack with railing around it wih ladder..see pics and e mail me for any other pics you may want. |
06-10-2006, 07:50
Jerry,
Welcome to the forum and good luck in your search. If you have not spent time looking at the history section over at http://www.vintagebirds.com, that's a good place to start the learning experience. That Bird certainly has an attractive starting price and doesn't look back in the pictures, but I guess I would have expected it to have a 391 Ford gas engine. Hopefully Jeff Miller will see your message and address your questions. Jeff is one of the Wanderlodge community's resident experts on the older Birds. Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Jerry Thompson" > > Howdy! > > I'm a newbie and looking at a 1970 WL. And like any newbie have a lot > of questions. > > Below is a description of an Ebay listing. > > Seems to me that this maybe a gas to diesel conversion. > > As it has the older 6 speed allison. > > Don't know why it has a clutch pedal....I think that some of the older > units offered a 2 speed axle with the old big block gas engines. > > I like the older units. > > Its located in St. Louis Mo., and listed on Ebay (which may or may not > be a good thing!) It sounds to me like it may have been in storage > prior to this owner. > > 1) Is any one familiar with this unit? > > 2) Any thought about bidding or buying on bay or this unit? > > 3) Any good bus shops in the St. Louis Mo. that could go over it and > give a good safety check and let what really needs to be done? > > 4) if I got the build number would BlueBird be able to give me any info? > > 5) Can the old Allison 6 speeds handle the torque of a 3208? > > 6) Is my fantasy hitting a wall of reality? > > 6) All comments gratefully received ![]() > > Thanks > > Thanks > > Jerry > > Hers the link > > <<http://cgi.ebay.com/ebaymotors/ws/eBayIS...rd=1&\ sspagename=STRK%3AMEWA%3AIT&rd=1>> > > > > Heres the discription: > > This is a 1970 Bluebird wanderlodge that has a 3208 catapiller diesel > engine and a Alison 6 speed automatic transmission.The odometer reads > 29975 and it seems to work fine,I am not the original owner so i can > not verify.The bus has a clutch pedal in it too,not sure if it had a > standard shift some time.I just had a new injector pump installed > ($1100.00) also a fuel pump installed ($150.00).The batters are lass > then a year old as well. The bus starts and runs great shifts > great.The brakes seem ok,the radiator has a very small leak towards > the bottom,shouldn't be too much to fix or just keep water in it.The > coach sleeps 6 has central heat,2 roof air conditioners.4 burner > stove,refrigerator,freezer,hot water heater,toilet stainless shower > ,stainless double sink,onan generator (gas) electric start.Have NOT > had generator running this year yet,The chassis has 2 diesel tanks and > 1 gas tank for generator.The rear tank (diesel) is Not hooked up now > It had old fuel in it ,so it was disconnected til it gets flushed > out.The roof a/c have not been checked either.I really don't know much > about the bus ,I bought it with intentions of doing a total > restoration,but seem to have lost interest in project.The interior is > all solid wood not vynl and plastic like all the newer coaches seem to > have.It is also built on a blue Bird Bus Chassis not a beefed up pick > up chassis like some of the other rv's out there.I would not hesitate > to drive this anywere.The entry door needs a small piece of glass > replaced and the door needs a key made too.The awning will need a > replacement vynl but the rest of it seems fine.There are some slite > signs of water marks on ceiling but seems like the problem was already > fixed ,just needs to repaint ceiling.Roof looks fine,it also has a > spare tire and wheel, there is a large luggage rack with railing > around it wih ladder..see pics and e mail me for any other pics you > may want. > |
06-10-2006, 09:06
Jerry,
I would look at as many Birds as possible, before I would tackle this project. If you are considering this project you must have the necessary skills, (as I do not and could not). There are about eight Birds on ebay, There are many on the Vintage Bird Site , http://vintagebirds.com/ There is a good price on an 84 FC, with lots of newer and up-dated parts , It seems the owner is a forum member. Also Look at http://www.birdconnection.com/ These sites will give examples of ASKING prices. Check out the picture album at http://autos.groups.yahoo.com/group/FC_W...d=51123124 message # 413, This is a great renovation project. Any old Bird will need atleast 10,000, some a lot more. Do not give up there is a Bird out there for you. Bill's Opinion, 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Jerry Thompson" > > Howdy! > > I'm a newbie and looking at a 1970 WL. And like any newbie have a lot > of questions. > > Below is a description of an Ebay listing. > > Seems to me that this maybe a gas to diesel conversion. > > As it has the older 6 speed allison. > > Don't know why it has a clutch pedal....I think that some of the older > units offered a 2 speed axle with the old big block gas engines. > > I like the older units. > > Its located in St. Louis Mo., and listed on Ebay (which may or may not > be a good thing!) It sounds to me like it may have been in storage > prior to this owner. > > 1) Is any one familiar with this unit? > > 2) Any thought about bidding or buying on bay or this unit? > > 3) Any good bus shops in the St. Louis Mo. that could go over it and > give a good safety check and let what really needs to be done? > > 4) if I got the build number would BlueBird be able to give me any info? > > 5) Can the old Allison 6 speeds handle the torque of a 3208? > > 6) Is my fantasy hitting a wall of reality? > > 6) All comments gratefully received ![]() > > Thanks > > Thanks > > Jerry > > Hers the link > > <<http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll? ViewItem&item=4648731419&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1>> > > > > Heres the discription: > > This is a 1970 Bluebird wanderlodge that has a 3208 catapiller diesel > engine and a Alison 6 speed automatic transmission.The odometer reads > 29975 and it seems to work fine,I am not the original owner so i can > not verify.The bus has a clutch pedal in it too,not sure if it had a > standard shift some time.I just had a new injector pump installed > ($1100.00) also a fuel pump installed ($150.00).The batters are lass > then a year old as well. The bus starts and runs great shifts > great.The brakes seem ok,the radiator has a very small leak towards > the bottom,shouldn't be too much to fix or just keep water in it.The > coach sleeps 6 has central heat,2 roof air conditioners.4 burner > stove,refrigerator,freezer,hot water heater,toilet stainless shower > ,stainless double sink,onan generator (gas) electric start.Have NOT > had generator running this year yet,The chassis has 2 diesel tanks and > 1 gas tank for generator.The rear tank (diesel) is Not hooked up now > It had old fuel in it ,so it was disconnected til it gets flushed > out.The roof a/c have not been checked either.I really don't know much > about the bus ,I bought it with intentions of doing a total > restoration,but seem to have lost interest in project.The interior is > all solid wood not vynl and plastic like all the newer coaches seem to > have.It is also built on a blue Bird Bus Chassis not a beefed up pick > up chassis like some of the other rv's out there.I would not hesitate > to drive this anywere.The entry door needs a small piece of glass > replaced and the door needs a key made too.The awning will need a > replacement vynl but the rest of it seems fine.There are some slite > signs of water marks on ceiling but seems like the problem was already > fixed ,just needs to repaint ceiling.Roof looks fine,it also has a > spare tire and wheel, there is a large luggage rack with railing > around it wih ladder..see pics and e mail me for any other pics you > may want. > |
