Water drain system on 82 FC 35
06-15-2006, 02:09
Luck has squat to do with it
you dont have to fill the hot water tank to freeze protect the system In the same vein do you have to completely fill the fresh water tank with anti freeze to protect it? the answer is no The system is a demand type system it uses the available liquid to flush the system no liquid no pressure it is not necessary to fill the hot water tank with anti freeze to protect the system. It is a waste of money but if you want to use that much anti freeze be my guest If the system is drained and replaced with anti freeze It is simply not necessary to use a "minimum of 12 gallons" to protect your system Iam sure you could always ask a rv tech to show you economical and proper to freeze protect your water system They will be more than happy to sell you 12 gallons of antifreeze when 3-4 will adequately do the job Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, Tom Warner > > Simply without a bypass for the hotwater heater there is no way you > can get antifreeze into the hot water lines without pressurizing > (filling it with pink stuff first) the hot water tank. Look at the BB > drawing for your fresh water system and you will see why. You have > been lucky so far. I have used the air system to blow out my FC35 > every year but have always been nervous doing it. I want to make > absolutely sure that it is protected. > Tom Warner > Vernon Center,NY > 1985 PT 40 > > 2006, you wrote: > > >we winterize our coach with 3-4 gallons of antifreeze > >there is a pickup installed on the supply side of fresh water pump > >avaialble at camping supply store about 10 bucks > >drain and blow out water system > >inject antifreeze with fresh water pump going to each faucet and the > >toilet individually and opening faucet or treadle till antifreeze appears > >isolate ice maker and drain > >you dont want antifreeze in ice maker > >if the fresh water tank is drained I have not found it necessaary to > >to put antifreeze in tank, Drain hot water tank and if you have a > >bypass use it > >We used to use the city water connection but it is easier to use to > >antifreeze pickup on the pump > >have not had any problems in 8 years with freeze problems in Niagara > >Falls. > >I certainly dont think you need 12 gallons of anti freeze > >Also Use Prestone rv antifreeze if you can find it does not impart the > >nasty aftertaste as the cheap pink stuff > >Antifreeze is Freeze proctection not fluid replacement > > > >Stephen > > > >--- In > > > >Tom Warner > > > > > > If you go thru the city water connection with antifreeze everything > > > is NOT protected unless you do the following and even then its going > > > to take a lot of antifreeze unless you bypass the hot water heater. > > > > > > 1. Activate the sporlan valve so the antifreeze will go into the > > > fresh water tank first, then after a few gallons the water pump can > > > pick it up and force it to the fixtures so when you turn on each > > > individual faucet, toilet fixture etc the line will be purged and > > > antifreeze will be added to that line. When you open a hot water > > > faucet the antifreeze will go into the hotwater tank first until it > > > is filled and then will go to each hot water line until antifreeze > > > comes out of that fixture when you open it. That is why you need a > > > bypass. If not you must pump approximately 12 gallons of antifreeze > > > into the system before you will get any distributed thru the hot > > > water pipes to the kitchen sink, bath sink and shower. Hmmmm. > > > 2. Purge the water from the instant hot and then pump antifreeze > >into it. > > > > > > 3. Pour a cup or so of antifreeze into each water trap in the sinks, > > > and shower. > > > > > > 4. Purge the water in the ice maker if you have one and then pump > > > antifreeze into it. > > > > > > Pray. > > > > > > tom warner > > > Vernon Center,NY > > > 1985 PT 40 > > > > > > > > > At 02:55 PM 6/14/2006, you wrote: > > > > > > >Yes, > > > >If you go thru the city water hook-up, I think everything is > > > >protected. Rig an air compressor fitting to the city hook-up. > > > >I do not exceed 40 psi, Then rig up a pump line into the same city > > > >water hook-up, all fittings available at HomeDepot/ Hardware Store, > > > >Etc. The drain was accessable for the HWT, your 82 may be > > > >different. > > > >Drilled a hole into the floor, I think it was plywood then a steel > > > >sheeting, On our 88 Fc, if you keep drilling you are into the fuel > > > >Tank, Go carefully and slow with the drill bits. > > > > > > > >Bill 88 FC Michigan > > > > > > > >--- In > > > > > > > > > > > >"davidkerryedwards" > > > > > > > > > > > > > > I like the idea of a drain on the hw heater. Where is the petcock > > > >for > > > > > that drain, I can't see one on mine. > > > > > I was thinking of some kind of overkill system like you use. How > > > >do > > > > > you pump in the antifreeze thru the city pressure hookup? > > > > > > > > > > Kerry > > > > > > > > > > --- In > > > > > > > > > > > > "pattypape" > > > > > wrote: > > > > > > > > > > > > > > > > > > Kerry, > > > > > > > > > > > > On our 88 FC, there was no HWT bypass nor a HWT drain. > > > > > > All water in the pipes are drained by the internal air pressure > > > > > > system, the fresk tank drain and the outside faucet. > > > > > > > > > > > > Not trusting this method, I drilled a hole in the floor to drain > > > >the > > > > > > HWT thru the drain cockpet. I now use the BB air system to blow > > > >the > > > > > > pipes out, then use a shop compressor to blow-blow-blow more > > > >water > > > > > > out. > > > > > > Then pump in the pink the stuff, thru the city water hookup into > > > >the > > > > > > plumbing and fresh tank. Run the pump, look for pink stuff at > > > >each > > > > > > faucet, toilet etc, Then, I blow it out again. I feel this is a > > > >bit > > > > > > overkill, But inline with the entire Wanderlodge Overkill. > > > > > > We get really hard freezes and the time spent is worthwhile. > > > > > > No fresh water is added until we head South for Winter. > > > > > > Frozen pipes are always a worry, but this has worked for us. > > > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > > > > > > > > > > > > > > > --- In > > > > > > > > > > > > "davidkerryedwards" > > > > > > > > > > > > > > > > > > > > Having just repaired freeze breaks in my plumbing I'd like to > > > >get a > > > > > > > conceptual grasp of how the drain system works for the > > > >plumbing. I > > > > > > > know there's a manual drain under the vanity and an external > > > > > > faucet > > > > > > in > > > > > > > the propane compartment. I also see three cable operated > > > >valves > > > > > > near > > > > > > > the hw heater and tank in the back but I don't understand how > > > >they > > > > > > > work. How do the hot water heater and water tank drain and > > > >does > > > > > > > anyone have an easy way of retrofitting a system which gets > > > > > > antifreeze > > > > > > > into the system? Since there are no bypass fittings on the > > > >water > > > > > > > heater it seems virtually impossible to get antifreeze in the > > > >hot > > > > > > > water pipes. > > > > > > > > > > > > > > Kerry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
06-15-2006, 02:46
Yikes,
I just love the tire debate and the winterization debate. Usually the Pink Stuff debate waits until Fall. I am paranoid about pipes freezing, So, I spend lots of time once per year to winterize, I never want to repair old, non-standard copper. I use 3 to 5 gallon. Hand pump into the city water hook- up. Use the fresh water pump, until pink runs at all outlets, hand pump backwards into the faucets to purge the hot lines, I also try to place the mixing valves in the center, and block the faucet outlets, This "MAY" help the antifreeze/air pressure to back flow the hot lines. And Yes, there are other concerns such as Insta Hot, ice maker, and more. BLow, Blow, BLow with 40 psi, it is amazing how much water the system holds. I also add 235 gallons of diesel to winterize the fuel tank. Michigan is well below freezing in winter. I need all the inputs and everyone ideas, then one must decide what is relative to our own situation. Bill 88 FC Randy does not understand the freeze topic. --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > Luck has squat to do with it > you dont have to fill the hot water tank to freeze protect the system > In the same vein do you have to completely fill the fresh water tank > with anti freeze to protect it? > the answer is no > The system is a demand type system it uses the available liquid to > flush the system no liquid no pressure it is not necessary to fill the > hot water tank with anti freeze to protect the system. > It is a waste of money but if you want to use that much anti freeze be > my guest > If the system is drained and replaced with anti freeze It is simply > not necessary to use a "minimum of 12 gallons" to protect your system > Iam sure you could always ask a rv tech to show you economical and > proper to freeze protect your water system > They will be more than happy to sell you 12 gallons of antifreeze when > 3-4 will adequately do the job > Stephen 77fc35 > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > > > Simply without a bypass for the hotwater heater there is no way you > > can get antifreeze into the hot water lines without pressurizing > > (filling it with pink stuff first) the hot water tank. Look at the BB > > drawing for your fresh water system and you will see why. You have > > been lucky so far. I have used the air system to blow out my FC35 > > every year but have always been nervous doing it. I want to make > > absolutely sure that it is protected. > > Tom Warner > > Vernon Center,NY > > 1985 PT 40 > > > > 2006, you wrote: > > > > >we winterize our coach with 3-4 gallons of antifreeze > > >there is a pickup installed on the supply side of fresh water pump > > >avaialble at camping supply store about 10 bucks > > >drain and blow out water system > > >inject antifreeze with fresh water pump going to each faucet and the > > >toilet individually and opening faucet or treadle till antifreeze > appears > > >isolate ice maker and drain > > >you dont want antifreeze in ice maker > > >if the fresh water tank is drained I have not found it necessaary to > > >to put antifreeze in tank, Drain hot water tank and if you have a > > >bypass use it > > >We used to use the city water connection but it is easier to use to > > >antifreeze pickup on the pump > > >have not had any problems in 8 years with freeze problems in Niagara > > >Falls. > > >I certainly dont think you need 12 gallons of anti freeze > > >Also Use Prestone rv antifreeze if you can find it does not impart the > > >nasty aftertaste as the cheap pink stuff > > >Antifreeze is Freeze proctection not fluid replacement > > > > > >Stephen > > > > > >--- In > > > > > > > >Tom Warner > > > > > > > > If you go thru the city water connection with antifreeze everything > > > > is NOT protected unless you do the following and even then its going > > > > to take a lot of antifreeze unless you bypass the hot water heater. > > > > > > > > 1. Activate the sporlan valve so the antifreeze will go into the > > > > fresh water tank first, then after a few gallons the water pump can > > > > pick it up and force it to the fixtures so when you turn on each > > > > individual faucet, toilet fixture etc the line will be purged and > > > > antifreeze will be added to that line. When you open a hot water > > > > faucet the antifreeze will go into the hotwater tank first until it > > > > is filled and then will go to each hot water line until antifreeze > > > > comes out of that fixture when you open it. That is why you need a > > > > bypass. If not you must pump approximately 12 gallons of antifreeze > > > > into the system before you will get any distributed thru the hot > > > > water pipes to the kitchen sink, bath sink and shower. Hmmmm. > > > > 2. Purge the water from the instant hot and then pump antifreeze > > >into it. > > > > > > > > 3. Pour a cup or so of antifreeze into each water trap in the sinks, > > > > and shower. > > > > > > > > 4. Purge the water in the ice maker if you have one and then pump > > > > antifreeze into it. > > > > > > > > Pray. > > > > > > > > tom warner > > > > Vernon Center,NY > > > > 1985 PT 40 > > > > > > > > > > > > At 02:55 PM 6/14/2006, you wrote: > > > > > > > > >Yes, > > > > >If you go thru the city water hook-up, I think everything is > > > > >protected. Rig an air compressor fitting to the city hook- up. > > > > >I do not exceed 40 psi, Then rig up a pump line into the same city > > > > >water hook-up, all fittings available at HomeDepot/ Hardware Store, > > > > >Etc. The drain was accessable for the HWT, your 82 may be > > > > >different. > > > > >Drilled a hole into the floor, I think it was plywood then a steel > > > > >sheeting, On our 88 Fc, if you keep drilling you are into the fuel > > > > >Tank, Go carefully and slow with the drill bits. > > > > > > > > > >Bill 88 FC Michigan > > > > > > > > > >--- In > > > > > > > > > > > > > > > >"davidkerryedwards" > > > > > > > > > > > > > > > > > I like the idea of a drain on the hw heater. Where is the > petcock > > > > >for > > > > > > that drain, I can't see one on mine. > > > > > > I was thinking of some kind of overkill system like you use. How > > > > >do > > > > > > you pump in the antifreeze thru the city pressure hookup? > > > > > > > > > > > > Kerry > > > > > > > > > > > > --- In > > > > > > > > > > > > > > > > > "pattypape" > > > > > > wrote: > > > > > > > > > > > > > > > > > > > > > Kerry, > > > > > > > > > > > > > > On our 88 FC, there was no HWT bypass nor a HWT drain. > > > > > > > All water in the pipes are drained by the internal air > pressure > > > > > > > system, the fresk tank drain and the outside faucet. > > > > > > > > > > > > > > Not trusting this method, I drilled a hole in the floor to > drain > > > > >the > > > > > > > HWT thru the drain cockpet. I now use the BB air system to > blow > > > > >the > > > > > > > pipes out, then use a shop compressor to blow-blow- blow more > > > > >water > > > > > > > out. > > > > > > > Then pump in the pink the stuff, thru the city water > hookup into > > > > >the > > > > > > > plumbing and fresh tank. Run the pump, look for pink stuff at > > > > >each > > > > > > > faucet, toilet etc, Then, I blow it out again. I feel this > is a > > > > >bit > > > > > > > overkill, But inline with the entire Wanderlodge Overkill. > > > > > > > We get really hard freezes and the time spent is worthwhile. > > > > > > > No fresh water is added until we head South for Winter. > > > > > > > Frozen pipes are always a worry, but this has worked for us. > > > > > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In > > > > > > > > > > > > > > > > > "davidkerryedwards" > > > > > > > > > > > > > > > > > > > > > > > Having just repaired freeze breaks in my plumbing I'd > like to > > > > >get a > > > > > > > > conceptual grasp of how the drain system works for the > > > > >plumbing. I > > > > > > > > know there's a manual drain under the vanity and an external > > > > > > > faucet > > > > > > > in > > > > > > > > the propane compartment. I also see three cable operated > > > > >valves > > > > > > > near > > > > > > > > the hw heater and tank in the back but I don't > understand how > > > > >they > > > > > > > > work. How do the hot water heater and water tank drain and > > > > >does > > > > > > > > anyone have an easy way of retrofitting a system which gets > > > > > > > antifreeze > > > > > > > > into the system? Since there are no bypass fittings on the > > > > >water > > > > > > > > heater it seems virtually impossible to get antifreeze > in the > > > > >hot > > > > > > > > water pipes. > > > > > > > > > > > > > > > > Kerry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
06-15-2006, 03:51
Hey Guys...Am I missing somethig here??
Why?...Why use antifreeze in the water system? I know, the obvious answer is to avoid freezing, right? I have lived in the South for 46 years and believe me it can get cold enough to freeze water pipes here, especially when the temp is in the teens. I have a female hose connected to a male npt air hose connection. I set the pressure regulator to 40 psi and systematically drain all connections including the ice Maker. Hey Guys, 20 years and not a single leak. This is on the '77, '87 says to use coach air to remove all water, THEN use a small amount of antifreeze in the "P" traps and holding tanks. Why contaminate the fresh water system with "pink stuff" that has to be flushed out later on? I carry a portable air compressor and do the same thing to vacant rental property in the Winter, it works!!! Bob '87 FC35 Greenville, SC PS: Yes, I have been in Buffalo, NY and Great Falls,MN when it was cold enough for the moisture in the exaust to "SNOW" on the ground. I believe it will work there too! --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > > Yikes, > > I just love the tire debate and the winterization debate. > Usually the Pink Stuff debate waits until Fall. > > I am paranoid about pipes freezing, So, I spend lots of time once > per year to winterize, I never want to repair old, non-standard > copper. I use 3 to 5 gallon. Hand pump into the city water hook- > up. Use the fresh water pump, until pink runs at all outlets, hand > pump backwards into the faucets to purge the hot lines, I also try > to place the mixing valves in the center, and block the faucet > outlets, This "MAY" help the antifreeze/air pressure to back flow > the hot lines. And Yes, there are other concerns such as Insta Hot, > ice maker, and more. BLow, Blow, BLow with 40 psi, it is amazing how > much water the system holds. > > I also add 235 gallons of diesel to winterize the fuel tank. > Michigan is well below freezing in winter. > I need all the inputs and everyone ideas, then one must > decide what is relative to our own situation. > > > Bill 88 FC Randy does not understand the freeze topic. > > > > --- In WanderlodgeForum@yahoogroups.com, "Stephen Birtles" > > > > > Luck has squat to do with it > > you dont have to fill the hot water tank to freeze protect the > system > > In the same vein do you have to completely fill the fresh water > tank > > with anti freeze to protect it? > > the answer is no > > The system is a demand type system it uses the available liquid to > > flush the system no liquid no pressure it is not necessary to fill > the > > hot water tank with anti freeze to protect the system. > > It is a waste of money but if you want to use that much anti > freeze be > > my guest > > If the system is drained and replaced with anti freeze It is simply > > not necessary to use a "minimum of 12 gallons" to protect your > system > > Iam sure you could always ask a rv tech to show you economical and > > proper to freeze protect your water system > > They will be more than happy to sell you 12 gallons of antifreeze > when > > 3-4 will adequately do the job > > Stephen 77fc35 > > > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote: > > > > > > Simply without a bypass for the hotwater heater there is no way > you > > > can get antifreeze into the hot water lines without pressurizing > > > (filling it with pink stuff first) the hot water tank. Look at > the BB > > > drawing for your fresh water system and you will see why. You > have > > > been lucky so far. I have used the air system to blow out my > FC35 > > > every year but have always been nervous doing it. I want to make > > > absolutely sure that it is protected. > > > Tom Warner > > > Vernon Center,NY > > > 1985 PT 40 > > > > > > 2006, you wrote: > > > > > > >we winterize our coach with 3-4 gallons of antifreeze > > > >there is a pickup installed on the supply side of fresh water > pump > > > >avaialble at camping supply store about 10 bucks > > > >drain and blow out water system > > > >inject antifreeze with fresh water pump going to each faucet > and the > > > >toilet individually and opening faucet or treadle till > antifreeze > > appears > > > >isolate ice maker and drain > > > >you dont want antifreeze in ice maker > > > >if the fresh water tank is drained I have not found it > necessaary to > > > >to put antifreeze in tank, Drain hot water tank and if you have > a > > > >bypass use it > > > >We used to use the city water connection but it is easier to > use to > > > >antifreeze pickup on the pump > > > >have not had any problems in 8 years with freeze problems in > Niagara > > > >Falls. > > > >I certainly dont think you need 12 gallons of anti freeze > > > >Also Use Prestone rv antifreeze if you can find it does not > impart the > > > >nasty aftertaste as the cheap pink stuff > > > >Antifreeze is Freeze proctection not fluid replacement > > > > > > > >Stephen > > > > > > > >--- In > > > > > > > > > > > >Tom Warner > > > > > > > > > > If you go thru the city water connection with antifreeze > everything > > > > > is NOT protected unless you do the following and even then > its going > > > > > to take a lot of antifreeze unless you bypass the hot water > heater. > > > > > > > > > > 1. Activate the sporlan valve so the antifreeze will go into > the > > > > > fresh water tank first, then after a few gallons the water > pump can > > > > > pick it up and force it to the fixtures so when you turn on > each > > > > > individual faucet, toilet fixture etc the line will be > purged and > > > > > antifreeze will be added to that line. When you open a hot > water > > > > > faucet the antifreeze will go into the hotwater tank first > until it > > > > > is filled and then will go to each hot water line until > antifreeze > > > > > comes out of that fixture when you open it. That is why you > need a > > > > > bypass. If not you must pump approximately 12 gallons of > antifreeze > > > > > into the system before you will get any distributed thru the > hot > > > > > water pipes to the kitchen sink, bath sink and shower. Hmmmm. > > > > > 2. Purge the water from the instant hot and then pump > antifreeze > > > >into it. > > > > > > > > > > 3. Pour a cup or so of antifreeze into each water trap in > the sinks, > > > > > and shower. > > > > > > > > > > 4. Purge the water in the ice maker if you have one and then > pump > > > > > antifreeze into it. > > > > > > > > > > Pray. > > > > > > > > > > tom warner > > > > > Vernon Center,NY > > > > > 1985 PT 40 > > > > > > > > > > > > > > > At 02:55 PM 6/14/2006, you wrote: > > > > > > > > > > >Yes, > > > > > >If you go thru the city water hook-up, I think everything is > > > > > >protected. Rig an air compressor fitting to the city hook- > up. > > > > > >I do not exceed 40 psi, Then rig up a pump line into the > same city > > > > > >water hook-up, all fittings available at HomeDepot/ > Hardware Store, > > > > > >Etc. The drain was accessable for the HWT, your 82 may be > > > > > >different. > > > > > >Drilled a hole into the floor, I think it was plywood then > a steel > > > > > >sheeting, On our 88 Fc, if you keep drilling you are into > the fuel > > > > > >Tank, Go carefully and slow with the drill bits. > > > > > > > > > > > >Bill 88 FC Michigan > > > > > > > > > > > >--- In > > > > > > > > > > > > > > > > > > > >"davidkerryedwards" > > > > > > > > > > > > > > > > > > > > I like the idea of a drain on the hw heater. Where is the > > petcock > > > > > >for > > > > > > > that drain, I can't see one on mine. > > > > > > > I was thinking of some kind of overkill system like you > use. How > > > > > >do > > > > > > > you pump in the antifreeze thru the city pressure hookup? > > > > > > > > > > > > > > Kerry > > > > > > > > > > > > > > --- In > > > > > > > > > > > > > > > > > > > > > > "pattypape" > > > > > > > wrote: > > > > > > > > > > > > > > > > > > > > > > > > Kerry, > > > > > > > > > > > > > > > > On our 88 FC, there was no HWT bypass nor a HWT drain. > > > > > > > > All water in the pipes are drained by the internal air > > pressure > > > > > > > > system, the fresk tank drain and the outside faucet. > > > > > > > > > > > > > > > > Not trusting this method, I drilled a hole in the > floor to > > drain > > > > > >the > > > > > > > > HWT thru the drain cockpet. I now use the BB air > system to > > blow > > > > > >the > > > > > > > > pipes out, then use a shop compressor to blow-blow- > blow more > > > > > >water > > > > > > > > out. > > > > > > > > Then pump in the pink the stuff, thru the city water > > hookup into > > > > > >the > > > > > > > > plumbing and fresh tank. Run the pump, look for pink > stuff at > > > > > >each > > > > > > > > faucet, toilet etc, Then, I blow it out again. I feel > this > > is a > > > > > >bit > > > > > > > > overkill, But inline with the entire Wanderlodge > Overkill. > > > > > > > > We get really hard freezes and the time spent is > worthwhile. > > > > > > > > No fresh water is added until we head South for Winter. > > > > > > > > Frozen pipes are always a worry, but this has worked > for us. > > > > > > > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In > > > > > > > > > > > > > > > > > > > > > > "davidkerryedwards" > > > > > > > > > > > > > > > > > > > > > > > > > > Having just repaired freeze breaks in my plumbing I'd > > like to > > > > > >get a > > > > > > > > > conceptual grasp of how the drain system works for > the > > > > > >plumbing. I > > > > > > > > > know there's a manual drain under the vanity and an > external > > > > > > > > faucet > > > > > > > > in > > > > > > > > > the propane compartment. I also see three cable > operated > > > > > >valves > > > > > > > > near > > > > > > > > > the hw heater and tank in the back but I don't > > understand how > > > > > >they > > > > > > > > > work. How do the hot water heater and water tank > drain and > > > > > >does > > > > > > > > > anyone have an easy way of retrofitting a system > which gets > > > > > > > > antifreeze > > > > > > > > > into the system? Since there are no bypass fittings > on the > > > > > >water > > > > > > > > > heater it seems virtually impossible to get > antifreeze > > in the > > > > > >hot > > > > > > > > > water pipes. > > > > > > > > > > > > > > > > > > Kerry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > |
06-15-2006, 09:20
The reason to use antifreeze is because compressed air is not enough to
remove all the water in some coaches. For example....the air will push the water up a deadend (eg expansion tube) and after the air pressure is removed it flows down to the lowest level. This is not to say that this is the case for all coaches but certainly some have these hidden spots for water to hide. IMHO the best method is to blow it out with low pressure and use the pink stuff. Rob 94 Pt Frozen north On 15/06/06, one_dusty_hoot > > Hey Guys...Am I missing somethig here?? > > Why?...Why use antifreeze in the water system? > I know, the obvious answer is to avoid freezing, right? > > I have lived in the South for 46 years and believe > me it can get cold enough to freeze water pipes here, > especially when the temp is in the teens. > > I have a female hose connected to a male npt air hose > connection. I set the pressure regulator to 40 psi and > systematically drain all connections including the ice > Maker. > > Hey Guys, 20 years and not a single leak. > > This is on the '77, '87 says to use coach air to > remove all water, THEN use a small amount of antifreeze > in the "P" traps and holding tanks. > > Why contaminate the fresh water system with "pink stuff" > that has to be flushed out later on? > > I carry a portable air compressor and do the same thing > to vacant rental property in the Winter, it works!!! > > Bob '87 FC35 Greenville, SC > PS: Yes, I have been in Buffalo, NY and Great Falls,MN > when it was cold enough for the moisture in the exaust > to "SNOW" on the ground. I believe it will work there too! > > --- In WanderlodgeForum@yahoogroups.com > "pattypape" > wrote: > > > > > > Yikes, > > > > I just love the tire debate and the winterization debate. > > Usually the Pink Stuff debate waits until Fall. > > > > I am paranoid about pipes freezing, So, I spend lots of time once > > per year to winterize, I never want to repair old, non-standard > > copper. I use 3 to 5 gallon. Hand pump into the city water hook- > > up. Use the fresh water pump, until pink runs at all outlets, > hand > > pump backwards into the faucets to purge the hot lines, I also try > > to place the mixing valves in the center, and block the faucet > > outlets, This "MAY" help the antifreeze/air pressure to back flow > > the hot lines. And Yes, there are other concerns such as Insta > Hot, > > ice maker, and more. BLow, Blow, BLow with 40 psi, it is amazing > how > > much water the system holds. > > > > I also add 235 gallons of diesel to winterize the fuel tank. > > Michigan is well below freezing in winter. > > I need all the inputs and everyone ideas, then one must > > decide what is relative to our own situation. > > > > > > Bill 88 FC Randy does not understand the freeze topic. > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > "Stephen Birtles" > > > > > > > > Luck has squat to do with it > > > you dont have to fill the hot water tank to freeze protect the > > system > > > In the same vein do you have to completely fill the fresh water > > tank > > > with anti freeze to protect it? > > > the answer is no > > > The system is a demand type system it uses the available liquid > to > > > flush the system no liquid no pressure it is not necessary to > fill > > the > > > hot water tank with anti freeze to protect the system. > > > It is a waste of money but if you want to use that much anti > > freeze be > > > my guest > > > If the system is drained and replaced with anti freeze It is > simply > > > not necessary to use a "minimum of 12 gallons" to protect your > > system > > > Iam sure you could always ask a rv tech to show you economical > and > > > proper to freeze protect your water system > > > They will be more than happy to sell you 12 gallons of > antifreeze > > when > > > 3-4 will adequately do the job > > > Stephen 77fc35 > > > > > > --- In WanderlodgeForum@yahoogroups.com > Tom Warner > > wrote: > > > > > > > > Simply without a bypass for the hotwater heater there is no > way > > you > > > > can get antifreeze into the hot water lines without > pressurizing > > > > (filling it with pink stuff first) the hot water tank. Look at > > the BB > > > > drawing for your fresh water system and you will see why. You > > have > > > > been lucky so far. I have used the air system to blow out my > > FC35 > > > > every year but have always been nervous doing it. I want to > make > > > > absolutely sure that it is protected. > > > > Tom Warner > > > > Vernon Center,NY > > > > 1985 PT 40 > > > > > > > > 2006, you wrote: > > > > > > > > >we winterize our coach with 3-4 gallons of antifreeze > > > > >there is a pickup installed on the supply side of fresh water > > pump > > > > >avaialble at camping supply store about 10 bucks > > > > >drain and blow out water system > > > > >inject antifreeze with fresh water pump going to each faucet > > and the > > > > >toilet individually and opening faucet or treadle till > > antifreeze > > > appears > > > > >isolate ice maker and drain > > > > >you dont want antifreeze in ice maker > > > > >if the fresh water tank is drained I have not found it > > necessaary to > > > > >to put antifreeze in tank, Drain hot water tank and if you > have > > a > > > > >bypass use it > > > > >We used to use the city water connection but it is easier to > > use to > > > > >antifreeze pickup on the pump > > > > >have not had any problems in 8 years with freeze problems in > > Niagara > > > > >Falls. > > > > >I certainly dont think you need 12 gallons of anti freeze > > > > >Also Use Prestone rv antifreeze if you can find it does not > > impart the > > > > >nasty aftertaste as the cheap pink stuff > > > > >Antifreeze is Freeze proctection not fluid replacement > > > > > > > > > >Stephen > > > > > > > > > >--- In > > > > > > > > 40yahoogroups.com>WanderlodgeForum@yahoogroups.com > , > > > > > > > >Tom Warner > > > > > > > > > > > > If you go thru the city water connection with antifreeze > > everything > > > > > > is NOT protected unless you do the following and even then > > its going > > > > > > to take a lot of antifreeze unless you bypass the hot > water > > heater. > > > > > > > > > > > > 1. Activate the sporlan valve so the antifreeze will go > into > > the > > > > > > fresh water tank first, then after a few gallons the water > > pump can > > > > > > pick it up and force it to the fixtures so when you turn > on > > each > > > > > > individual faucet, toilet fixture etc the line will be > > purged and > > > > > > antifreeze will be added to that line. When you open a hot > > water > > > > > > faucet the antifreeze will go into the hotwater tank first > > until it > > > > > > is filled and then will go to each hot water line until > > antifreeze > > > > > > comes out of that fixture when you open it. That is why > you > > need a > > > > > > bypass. If not you must pump approximately 12 gallons of > > antifreeze > > > > > > into the system before you will get any distributed thru > the > > hot > > > > > > water pipes to the kitchen sink, bath sink and shower. > Hmmmm. > > > > > > 2. Purge the water from the instant hot and then pump > > antifreeze > > > > >into it. > > > > > > > > > > > > 3. Pour a cup or so of antifreeze into each water trap in > > the sinks, > > > > > > and shower. > > > > > > > > > > > > 4. Purge the water in the ice maker if you have one and > then > > pump > > > > > > antifreeze into it. > > > > > > > > > > > > Pray. > > > > > > > > > > > > tom warner > > > > > > Vernon Center,NY > > > > > > 1985 PT 40 > > > > > > > > > > > > > > > > > > At 02:55 PM 6/14/2006, you wrote: > > > > > > > > > > > > >Yes, > > > > > > >If you go thru the city water hook-up, I think everything > is > > > > > > >protected. Rig an air compressor fitting to the city hook- > > up. > > > > > > >I do not exceed 40 psi, Then rig up a pump line into the > > same city > > > > > > >water hook-up, all fittings available at HomeDepot/ > > Hardware Store, > > > > > > >Etc. The drain was accessable for the HWT, your 82 may be > > > > > > >different. > > > > > > >Drilled a hole into the floor, I think it was plywood > then > > a steel > > > > > > >sheeting, On our 88 Fc, if you keep drilling you are into > > the fuel > > > > > > >Tank, Go carefully and slow with the drill bits. > > > > > > > > > > > > > >Bill 88 FC Michigan > > > > > > > > > > > > > >--- In > > > > > > > > > > > > %40yahoogroups.com>WanderlodgeForum@yahoogroups.com > , > > > > > > > > > > > >"davidkerryedwards" > > > > > > > > > > > > > > > > > > > > > > > I like the idea of a drain on the hw heater. Where is > the > > > petcock > > > > > > >for > > > > > > > > that drain, I can't see one on mine. > > > > > > > > I was thinking of some kind of overkill system like > you > > use. How > > > > > > >do > > > > > > > > you pump in the antifreeze thru the city pressure > hookup? > > > > > > > > > > > > > > > > Kerry > > > > > > > > > > > > > > > > --- In > > > > > > > > > > > > > > > 40yahoogroups.com>WanderlodgeForum@yahoogroups.com > , > > > > > > > > > > > > "pattypape" > > > > > > > > wrote: > > > > > > > > > > > > > > > > > > > > > > > > > > > Kerry, > > > > > > > > > > > > > > > > > > On our 88 FC, there was no HWT bypass nor a HWT > drain. > > > > > > > > > All water in the pipes are drained by the internal > air > > > pressure > > > > > > > > > system, the fresk tank drain and the outside faucet. > > > > > > > > > > > > > > > > > > Not trusting this method, I drilled a hole in the > > floor to > > > drain > > > > > > >the > > > > > > > > > HWT thru the drain cockpet. I now use the BB air > > system to > > > blow > > > > > > >the > > > > > > > > > pipes out, then use a shop compressor to blow-blow- > > blow more > > > > > > >water > > > > > > > > > out. > > > > > > > > > Then pump in the pink the stuff, thru the city water > > > hookup into > > > > > > >the > > > > > > > > > plumbing and fresh tank. Run the pump, look for pink > > stuff at > > > > > > >each > > > > > > > > > faucet, toilet etc, Then, I blow it out again. I > feel > > this > > > is a > > > > > > >bit > > > > > > > > > overkill, But inline with the entire Wanderlodge > > Overkill. > > > > > > > > > We get really hard freezes and the time spent is > > worthwhile. > > > > > > > > > No fresh water is added until we head South for > Winter. > > > > > > > > > Frozen pipes are always a worry, but this has worked > > for us. > > > > > > > > > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --- In > > > > > > > > > > > > > > > 40yahoogroups.com>WanderlodgeForum@yahoogroups.com > , > > > > > > > > > > > > "davidkerryedwards" > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Having just repaired freeze breaks in my plumbing > I'd > > > like to > > > > > > >get a > > > > > > > > > > conceptual grasp of how the drain system works for > > the > > > > > > >plumbing. I > > > > > > > > > > know there's a manual drain under the vanity and > an > > external > > > > > > > > > faucet > > > > > > > > > in > > > > > > > > > > the propane compartment. I also see three cable > > operated > > > > > > >valves > > > > > > > > > near > > > > > > > > > > the hw heater and tank in the back but I don't > > > understand how > > > > > > >they > > > > > > > > > > work. How do the hot water heater and water tank > > drain and > > > > > > >does > > > > > > > > > > anyone have an easy way of retrofitting a system > > which gets > > > > > > > > > antifreeze > > > > > > > > > > into the system? Since there are no bypass > fittings > > on the > > > > > > >water > > > > > > > > > > heater it seems virtually impossible to get > > antifreeze > > > in the > > > > > > >hot > > > > > > > > > > water pipes. > > > > > > > > > > > > > > > > > > > > Kerry > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
06-15-2006, 11:36
Kerry,
We filled up the water tank with the pink stuff versus putting in a bypass. Prior year I tried to just flush versus filling with pink, not too successful, lots of broken pipes. I may opt for bypass this year. If you put something in I would like to see it. Do you have the original manual on how to winterize? That helped me. It explains all the switches and values and the sequence to winterize. SDF 80FC35 Boulder ----Original Message Follows---- From: "davidkerryedwards" Reply-To: WanderlodgeForum@yahoogroups.com To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Water drain system on 82 FC 35 Date: Wed, 14 Jun 2006 15:06:50 -0000 I like the idea of a drain on the hw heater. Where is the petcock for that drain, I can't see one on mine. I was thinking of some kind of overkill system like you use. How do you pump in the antifreeze thru the city pressure hookup? Kerry --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > > Kerry, > > On our 88 FC, there was no HWT bypass nor a HWT drain. > All water in the pipes are drained by the internal air pressure > system, the fresk tank drain and the outside faucet. > > Not trusting this method, I drilled a hole in the floor to drain the > HWT thru the drain cockpet. I now use the BB air system to blow the > pipes out, then use a shop compressor to blow-blow-blow more water > out. > Then pump in the pink the stuff, thru the city water hookup into the > plumbing and fresh tank. Run the pump, look for pink stuff at each > faucet, toilet etc, Then, I blow it out again. I feel this is a bit > overkill, But inline with the entire Wanderlodge Overkill. > We get really hard freezes and the time spent is worthwhile. > No fresh water is added until we head South for Winter. > Frozen pipes are always a worry, but this has worked for us. > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > > > > Having just repaired freeze breaks in my plumbing I'd like to get a > > conceptual grasp of how the drain system works for the plumbing. I > > know there's a manual drain under the vanity and an external > faucet > in > > the propane compartment. I also see three cable operated valves > near > > the hw heater and tank in the back but I don't understand how they > > work. How do the hot water heater and water tank drain and does > > anyone have an easy way of retrofitting a system which gets > antifreeze > > into the system? Since there are no bypass fittings on the water > > heater it seems virtually impossible to get antifreeze in the hot > > water pipes. > > > > Kerry > > > |
