Generator starting issue....
06-26-2006, 13:45
update-
I have fuel to the carb and spark and the plugs, but no boom (combustion) just noticed however that my oil pressure gauge is pegged all the way to the right and off the chart(100+) I would think that it would be at zero when not running (to the left) Q. is there a oil pressure shut off switch somewhere or am I over thinking things after two whole days of trying to get this thing started... thanks Mike 80FC33 Taylor Mill, Ky (Montana may be delayed this week) |
06-26-2006, 13:52
Hi Mike, If you have fuel and spark then all you need is compression, just like
a cobra. Take out a plug, put your finger over the hole and spin the engine. Do you have compression? Maybe the timing belt jumped a notch. Dan Williams 81FCRB33 Jackson, MS ----- Original Message ----- From: Mike Meister To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 26, 2006 8:45 PM Subject: [WanderlodgeForum] Generator starting issue.... update- I have fuel to the carb and spark and the plugs, but no boom (combustion) just noticed however that my oil pressure gauge is pegged all the way to the right and off the chart(100+) I would think that it would be at zero when not running (to the left) Q. is there a oil pressure shut off switch somewhere or am I over thinking things after two whole days of trying to get this thing started... thanks Mike 80FC33 Taylor Mill, Ky (Montana may be delayed this week) [Non-text portions of this message have been removed] |
06-26-2006, 13:59
Hi Dan-
I have compression. Also looking in the manual there are two safeguard breakers on the end of generator. should these be facing left (rear of bus) or fwd (front of bus)??? --- In WanderlodgeForum@yahoogroups.com, "dan" wrote: > > Hi Mike, If you have fuel and spark then all you need is compression, just like a cobra. Take out a plug, put your finger over the hole and spin the engine. Do you have compression? Maybe the timing belt jumped a notch. > Dan Williams > 81FCRB33 > Jackson, MS > ----- Original Message ----- > From: Mike Meister > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, June 26, 2006 8:45 PM > Subject: [WanderlodgeForum] Generator starting issue.... > > > update- > I have fuel to the carb and spark and the plugs, but no boom > (combustion) just noticed however that my oil pressure gauge is pegged > all the way to the right and off the chart(100+) I would think that it > would be at zero when not running (to the left) > > Q. > is there a oil pressure shut off switch somewhere or am I over > thinking things after two whole days of trying to get this thing > started... > > thanks > > Mike > 80FC33 > Taylor Mill, Ky > > (Montana may be delayed this week) > > > > > > [Non-text portions of this message have been removed] > |
06-26-2006, 14:07
Hi Mike,
You checked the timing with a light, valve timing is good, compression is good, you gave it some ether to bypass the fuel system and it still won't start? Maybe you are getting spark but it is too weak? Dan ----- Original Message ----- From: Mike Meister To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 26, 2006 8:59 PM Subject: [WanderlodgeForum] Re: Generator starting issue.... Hi Dan- I have compression. Also looking in the manual there are two safeguard breakers on the end of generator. should these be facing left (rear of bus) or fwd (front of bus)??? --- In WanderlodgeForum@yahoogroups.com, "dan" wrote: > > Hi Mike, If you have fuel and spark then all you need is compression, just like a cobra. Take out a plug, put your finger over the hole and spin the engine. Do you have compression? Maybe the timing belt jumped a notch. > Dan Williams > 81FCRB33 > Jackson, MS > ----- Original Message ----- > From: Mike Meister > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, June 26, 2006 8:45 PM > Subject: [WanderlodgeForum] Generator starting issue.... > > > update- > I have fuel to the carb and spark and the plugs, but no boom > (combustion) just noticed however that my oil pressure gauge is pegged > all the way to the right and off the chart(100+) I would think that it > would be at zero when not running (to the left) > > Q. > is there a oil pressure shut off switch somewhere or am I over > thinking things after two whole days of trying to get this thing > started... > > thanks > > Mike > 80FC33 > Taylor Mill, Ky > > (Montana may be delayed this week) > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
