Service in Florida
06-24-2005, 05:01
Service in Florida
Ron,
Thanks a lot for all the information. I get no output when the switch is in either direction and when in the middle, just a slight move of the needle. Tom Gibbs -----Original Message----- From: ronmarabito2002 [mailto:remarabito@...] Sent: Thursday, June 23, 2005 11:31 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Service in Florida Sorry that I haven't gotten back to you. Been busy with housekeeping on the forum lately. First on the alternator fault light. Do you have it with both of the alternators. Change switch from 1 to 2 and also look at the amps output on the dash for the chassis 12 volt system. If you have amperage output, it could be that only one of the alternators is bad. Any good generator shop should be able to recondition the alternator for under $150, but that's if you deliver it. If only one alternator is putting out, you can go into the engine compartment on the passenger side firewall and disconnect each alternator charging cable directly below the shunt, one at a time to see which one is working. That's the easy part. One alternator is mounted under the rear of the engine directly below the a/c compressor. It is easiest removed by accessing it from the top after removing the a/c compressor and tying it up to one side. The lines are long enough. There is a cooling air line covering the end of the alternator to remove also. NOW! if it's the other alternator, that is mounted on the front of the engine near the top and must be accessed from the bedroom floor. Not a pretty job. If you take it to a shop, the labor will be in the neighborhood of $500 just to remove and reinstall. If you need more information on this, let me know. About the transmission light. I suggest you take the coach to a local Detroit Dealer and have him check the fault codes and clear all the old ones. The connection for the reader is located in the lower side dash console below the shifter panel. I can email you the fault codes and explain how to read them tomorrow. It's too late tonight to do that. Can't help with the generator muffler. Since you are in Florida now, get a hold of Power Tech and they can give you some good help with this item. Call service at 954-979-8946. The clicking sound on the jacks is probably a bad solenoid. There are two for the system. One is located on the front right wheel well vertical water deflector at the front and just behing the stepwell into the coach. Have someone feel this solenoid while you operate the switch. If that functions, then check for power to the one attached directly to the pump motor under the steps in the stepwell. Stay clear of the step or get rid of all the air in the auxiliary system so the step can't function. If you are not comfortable with the electrical, the generator shop might be able to troubleshoot it for you. I just recently had the main terminal replaced on my pump motor. Someone else on the forum should be able to give you assistance with the curtain motors. I only have one in my coach and I've never had any problems with it. Hope this helps. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "transportcycles" > Just purchased, and moved from Cincinnati, OH area to Orland area a > 1991 WLWB. New to both motorhoming and Bluebirds, although I've > always had a fondness for the older birds. > > Need to have several things looked at including Alternators (Fault > light is on), transmission (light came on on trip down, checked fluid > and added 2 quarts, but light stayed on), new generator muffler (looks > like a real job to get at), leveling jacks (clicking noise but nothing > moves), electric curtain operators (some work and some don't). I > boought from a dealer in Cincy that really didn't have a clue about > Bluebirds. Any help with shops that could help with any of these > services would be greatly appreciated. > > Thanks in advance. > > Tom Gibbs _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . [Non-text portions of this message have been removed] |
06-24-2005, 07:26
Service in Florida
There is no question that the Detroit Dealer would be the place to
choose. Parliament and Vantare would do for many of the other things. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "Tom Gibbs" > Thanks for both posts. Lots of useful info. Would you think that > Florida Detroit Diesel would be a better choice for the > engine/transmission stuff than Parliament or Vantare? > > -----Original Message----- > From: William Jensen [mailto:fljensen@b...] > Sent: Thursday, June 23, 2005 10:37 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Service in Florida > > > Tom: > > Had another thought.....You may want to talk to Vantare Coach in > Sanford. They may be willing to work on your coach too. I don't know > this for sure.......but they often take wanderlodges in for trades on > the Prevost conversions. I'm not sure where in Orlando are you are, > but that may save you some miles. > > Your generator is made by Powertech. These units are built in > Leesburg, FL, just up the road from you. They will only work on your > gennie, don't know if they are in the muffler business. > > It is often hard to find one shop that will address all your needs. > Part of the problem when you have so many different systems on a coach. > > Sorry about the double post. > > William Jensen > 1993 PT40 WBWL "Maudi" > Deerfield Beach, FL > > On the road to W. Virginia in the AM.........need to get out of the > rain down here. 14 inches in the month of June so far!!! > > > > > _____ > > Yahoo! Groups Links > > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/> . > > > > > [Non-text portions of this message have been removed] |
06-24-2005, 07:34
Service in Florida
Make sure you have a load on the system when checking the
alternators. Turn on your headlights. If you get nothing, then the alternators are not putting out or there is a circuit breaker or relay bad in the system. The alternators are controlled by 6 relays in the coach battery compartment. Look at the top of the opening on the left side. Benny at BB could send you a copy of the wiring or I have a copy if you need it. After loading the system and checking the switch, I suggest you have a good generator shop look at it. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "Tom Gibbs" > Ron, > Thanks a lot for all the information. I get no output when the switch > is in either direction and when in the middle, just a slight move of the > needle. > > Tom Gibbs > > -----Original Message----- > From: ronmarabito2002 [mailto:remarabito@a...] > Sent: Thursday, June 23, 2005 11:31 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Service in Florida > > > Sorry that I haven't gotten back to you. Been busy with > housekeeping on the forum lately. > > First on the alternator fault light. Do you have it with both of > the alternators. Change switch from 1 to 2 and also look at the > amps output on the dash for the chassis 12 volt system. If you have > amperage output, it could be that only one of the alternators is > bad. Any good generator shop should be able to recondition the > alternator for under $150, but that's if you deliver it. If only > one alternator is putting out, you can go into the engine > compartment on the passenger side firewall and disconnect each > alternator charging cable directly below the shunt, one at a time to > see which one is working. That's the easy part. One alternator is > mounted under the rear of the engine directly below the a/c > compressor. It is easiest removed by accessing it from the top > after removing the a/c compressor and tying it up to one side. The > lines are long enough. There is a cooling air line covering the end > of the alternator to remove also. NOW! if it's the other > alternator, that is mounted on the front of the engine near the top > and must be accessed from the bedroom floor. Not a pretty job. If > you take it to a shop, the labor will be in the neighborhood of $500 > just to remove and reinstall. If you need more information on this, > let me know. > > About the transmission light. I suggest you take the coach to a > local Detroit Dealer and have him check the fault codes and clear > all the old ones. The connection for the reader is located in the > lower side dash console below the shifter panel. I can email you > the fault codes and explain how to read them tomorrow. It's too > late tonight to do that. > > Can't help with the generator muffler. Since you are in Florida > now, get a hold of Power Tech and they can give you some good help > with this item. Call service at 954-979-8946. > > The clicking sound on the jacks is probably a bad solenoid. There > are two for the system. One is located on the front right wheel > well vertical water deflector at the front and just behing the > stepwell into the coach. Have someone feel this solenoid while you > operate the switch. If that functions, then check for power to the > one attached directly to the pump motor under the steps in the > stepwell. Stay clear of the step or get rid of all the air in the > auxiliary system so the step can't function. If you are not > comfortable with the electrical, the generator shop might be able to > troubleshoot it for you. I just recently had the main terminal > replaced on my pump motor. > > Someone else on the forum should be able to give you assistance with > the curtain motors. I only have one in my coach and I've never had > any problems with it. > > Hope this helps. > > R.E. (Ron) Marabito, Dallas, TX 92WB40 > Moderator > --- In WanderlodgeForum@yahoogroups.com, "transportcycles" > > > Just purchased, and moved from Cincinnati, OH area to Orland area > a > > 1991 WLWB. New to both motorhoming and Bluebirds, although I've > > always had a fondness for the older birds. > > > > Need to have several things looked at including Alternators (Fault > > light is on), transmission (light came on on trip down, checked > fluid > > and added 2 quarts, but light stayed on), new generator muffler > (looks > > like a real job to get at), leveling jacks (clicking noise but > nothing > > moves), electric curtain operators (some work and some don't). I > > boought from a dealer in Cincy that really didn't have a clue > about > > Bluebirds. Any help with shops that could help with any of these > > services would be greatly appreciated. > > > > Thanks in advance. > > > > Tom Gibbs > > > > > _____ > > Yahoo! Groups Links > > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/> . > > > > > [Non-text portions of this message have been removed] |
06-24-2005, 08:06
Service in Florida
Thanks again. I'll give them a call.
-----Original Message----- From: ronmarabito2002 [mailto:remarabito@...] Sent: Friday, June 24, 2005 3:27 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Service in Florida There is no question that the Detroit Dealer would be the place to choose. Parliament and Vantare would do for many of the other things. R.E. (Ron) Marabito, Dallas, TX 92WB40 Moderator --- In WanderlodgeForum@yahoogroups.com, "Tom Gibbs" > Thanks for both posts. Lots of useful info. Would you think that > Florida Detroit Diesel would be a better choice for the > engine/transmission stuff than Parliament or Vantare? > > -----Original Message----- > From: William Jensen [mailto:fljensen@b...] > Sent: Thursday, June 23, 2005 10:37 PM > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Service in Florida > > > Tom: > > Had another thought.....You may want to talk to Vantare Coach in > Sanford. They may be willing to work on your coach too. I don't know > this for sure.......but they often take wanderlodges in for trades on > the Prevost conversions. I'm not sure where in Orlando are you are, > but that may save you some miles. > > Your generator is made by Powertech. These units are built in > Leesburg, FL, just up the road from you. They will only work on your > gennie, don't know if they are in the muffler business. > > It is often hard to find one shop that will address all your needs. > Part of the problem when you have so many different systems on a coach. > > Sorry about the double post. > > William Jensen > 1993 PT40 WBWL "Maudi" > Deerfield Beach, FL > > On the road to W. Virginia in the AM.........need to get out of the > rain down here. 14 inches in the month of June so far!!! > > > > > _____ > > Yahoo! Groups Links > > > * To visit your group on the web, go to: > http://groups.yahoo.com/group/WanderlodgeForum/ > > > * To unsubscribe from this group, send an email to: > WanderlodgeForum-unsubscribe@yahoogroups.com > > > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of > Service <http://docs.yahoo.com/info/terms/> . > > > > > [Non-text portions of this message have been removed] _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . [Non-text portions of this message have been removed] |
06-24-2005, 08:40
Service in Florida
thats where they would take it.engines and trannys today are too complicated for
the average shop to deal with.randydupree93wb ----- Original Message ----- From: Tom Gibbs To: WanderlodgeForum@yahoogroups.com Sent: Friday, June 24, 2005 12:29 PM Subject: RE: [WanderlodgeForum] Re: Service in Florida Thanks for both posts. Lots of useful info. Would you think that Florida Detroit Diesel would be a better choice for the engine/transmission stuff than Parliament or Vantare? -----Original Message----- From: William Jensen [mailto:fljensen@...] Sent: Thursday, June 23, 2005 10:37 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Service in Florida Tom: Had another thought.....You may want to talk to Vantare Coach in Sanford. They may be willing to work on your coach too. I don't know this for sure.......but they often take wanderlodges in for trades on the Prevost conversions. I'm not sure where in Orlando are you are, but that may save you some miles. Your generator is made by Powertech. These units are built in Leesburg, FL, just up the road from you. They will only work on your gennie, don't know if they are in the muffler business. It is often hard to find one shop that will address all your needs. Part of the problem when you have so many different systems on a coach. Sorry about the double post. William Jensen 1993 PT40 WBWL "Maudi" Deerfield Beach, FL On the road to W. Virginia in the AM.........need to get out of the rain down here. 14 inches in the month of June so far!!! _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
06-24-2005, 12:58
Service in Florida
You might give lazy Days RV a call they are near I75 on I4 (east of
tampa) they told me they had a BlueBird Tech on site. They are one of the largest RV dealers in the country and have over 80 service bays and three full size paint booths. I have never taken my bird there, but I know other with buses that have. Thanks Bruce Campbell (currently at the Birds Nest) Clearwater, FL 83'FCSB "Blue Skies" formerly "Rainbow Chaser", darn those stripes are hard to get off "sorry Arley!" --- In WanderlodgeForum@yahoogroups.com, "transportcycles" wrote: > Just purchased, and moved from Cincinnati, OH area to Orland area a > 1991 WLWB. New to both motorhoming and Bluebirds, although I've > always had a fondness for the older birds. > > Need to have several things looked at including Alternators (Fault > light is on), transmission (light came on on trip down, checked fluid > and added 2 quarts, but light stayed on), new generator muffler (looks > like a real job to get at), leveling jacks (clicking noise but nothing > moves), electric curtain operators (some work and some don't). I > boought from a dealer in Cincy that really didn't have a clue about > Bluebirds. Any help with shops that could help with any of these > services would be greatly appreciated. > > Thanks in advance. > > Tom Gibbs |
06-25-2005, 00:29
Service in Florida
Thanks. I've been there when we were shopping. Very impressive place.
-----Original Message----- From: fl_bluebird_1983 [mailto:fl_bluebird_1983@...] Sent: Friday, June 24, 2005 8:59 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re:Service in Florida You might give lazy Days RV a call they are near I75 on I4 (east of tampa) they told me they had a BlueBird Tech on site. They are one of the largest RV dealers in the country and have over 80 service bays and three full size paint booths. I have never taken my bird there, but I know other with buses that have. Thanks Bruce Campbell (currently at the Birds Nest) Clearwater, FL 83'FCSB "Blue Skies" formerly "Rainbow Chaser", darn those stripes are hard to get off "sorry Arley!" --- In WanderlodgeForum@yahoogroups.com, "transportcycles" wrote: > Just purchased, and moved from Cincinnati, OH area to Orland area a > 1991 WLWB. New to both motorhoming and Bluebirds, although I've > always had a fondness for the older birds. > > Need to have several things looked at including Alternators (Fault > light is on), transmission (light came on on trip down, checked fluid > and added 2 quarts, but light stayed on), new generator muffler (looks > like a real job to get at), leveling jacks (clicking noise but nothing > moves), electric curtain operators (some work and some don't). I > boought from a dealer in Cincy that really didn't have a clue about > Bluebirds. Any help with shops that could help with any of these > services would be greatly appreciated. > > Thanks in advance. > > Tom Gibbs _____ Yahoo! Groups Links * To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ * To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com * Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> . [Non-text portions of this message have been removed] |
07-08-2006, 05:04
Service in Florida
Hi Where did you get the wheels for the motor that works the side
curtains? Have looked all over. What was the cost? Thanks Greg |
07-08-2006, 06:21
Service in Florida
Greg,
Below is a note to myself regarding the drape tires.* * * Drape Tires (electric drapes)* February 14, 2005 Spring Window Fashions says tires are obsolete and to call . Somfy Systems 800 637-6639 One set (3 tires), cost is $16.17 Ordered 4 sets. Received 4 sets. Curt Sprenger 1987 PT38, Anaheim Hills, Calif. pbe43 wrote: > Hi Where did you get the wheels for the motor that works the side > curtains? Have looked all over. What was the cost? > Thanks Greg > > |
