MAXTON MINI RALLY
02-10-2007, 20:33
MAXTON MINI RALLY
This is just a reminder that the Bluebird Mini Rally at Maxton is
just a little over six weeks away and counting, the dates are March 30 to April 1, 2007. This is two weeks after the rally at Myrtle Beach and hopefully some of those attending the MB rally will be able to stick around and then make the relatively short drive of a little over 100 miles up to Maxton, NC for the Hot Rod Top Speed Challenge that is held there. For more information go to the flyer at; http://www.pbase.com/iamflagman/image/70827761 To see a map and directions to the track, plus photos of past mini rallies at Maxton, just click on the flyer and it will take you to the thumbnail page, then you can click on the thumbnail that you want to see a larger version of. Guy Smalley should have his Rat Rod done in time to make its maiden run at Maxton during this event and the weather should be mild, so normally you won't have to run the generator that long during this dry camping rally, other than to charge your house batteries and the spectator entry fee is only $5.00 per person for the entire event, making this one of the least expensive rallies that you can attend, so come join us for a fun filled time, you won't regret it. It would be a good idea to use the forums sign up sheet located in the Database section, to let us know if you are coming and also to contact Barbara Vaughn about what food to bring. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 HOPKINS, SOUTH CAROLINA |
