Air leak question
09-06-2006, 04:34
Air leak question
I found my air leak. It wasn't behind the left headlight but up behind the
bumper at an air manifold. There is a device attached to the manifold with an air line attached and what appears to be a vacuum line. There is one barbed fitting on it that looks as if it never had a line attached and it is leaking out that barbed fitting. (at least I can't find a line that should be attached there and the barb is greasy as if it has never had anything attached) The device has a round flat bottom about the size of a fifty cent piece. What is this device? the previously mentioned vacuum generator for the cruise control? Where can I get a replacement? Kerry 82 FC 35 Denver |
