hard to pull out paddles on grey and black water
09-14-2006, 02:47
Hey Jeff and others of interest.......
I am having a hard time pulling out the levers on my tanks...the twist left is ok but it takes a ton to pull them out and a ton to put them in the last 1/2 inch...and...I am getting olser...... been thinking about electrics....saw them at camping world for $100 but they do not seem to be easy to install....I may just order some new paddles from Jeff mif this is the problem...I welcome suggestions. Thanks. Regards, Hank Hannigan 90SP36 80FC31 ps...paddle problem is on my 80FC31...the 90SP has new Dupree/Miller air dumps. |
09-14-2006, 05:24
Vaseoline??, or, KY Jelly??
Bob Janes, Greenville, SC --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > Hey Jeff and others of interest....... > I am having a hard time pulling out the levers on my tanks...the twist > left is ok but it takes a ton to pull them out and a ton to put them > in the last 1/2 inch...and...I am getting olser...... > been thinking about electrics....saw them at camping world for $100 > but they do not seem to be easy to install....I may just order some > new paddles from Jeff mif this is the problem...I welcome suggestions. > > Thanks. > Regards, > Hank Hannigan > 90SP36 > 80FC31 > ps...paddle problem is on my 80FC31...the 90SP has new Dupree/Miller > air dumps. > |
09-14-2006, 07:16
Magnalube
http://www.magnalube.com Step[hen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > Vaseoline??, or, KY Jelly?? > Bob Janes, Greenville, SC > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > Hey Jeff and others of interest....... > > I am having a hard time pulling out the levers on my tanks...the > twist > > left is ok but it takes a ton to pull them out and a ton to put > them > > in the last 1/2 inch...and...I am getting olser...... > > been thinking about electrics....saw them at camping world for $100 > > but they do not seem to be easy to install....I may just order some > > new paddles from Jeff mif this is the problem...I welcome > suggestions. > > > > Thanks. > > Regards, > > Hank Hannigan > > 90SP36 > > 80FC31 > > ps...paddle problem is on my 80FC31...the 90SP has new > Dupree/Miller > > air dumps. > > > |
09-14-2006, 07:38
Dupree/Miller will likey reply also...but I have had luck with: 1:
doing a good dump & flush. 2: then removing the two small recessed screws and removing the paddles (this is why you flush well in #1)...if the rubber seal looks good, just clean and lube (i use silicone and avoid petro based for rubber) and reinstall, noting which side faces in/outlet. If the seal is torn, hard or "wavy" around the perimeter...order a new paddle. Frank W. 85FC33 Woodbridge, VA. --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > Vaseoline??, or, KY Jelly?? > Bob Janes, Greenville, SC > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > Hey Jeff and others of interest....... > > I am having a hard time pulling out the levers on my tanks...the > twist > > left is ok but it takes a ton to pull them out and a ton to put > them > > in the last 1/2 inch...and...I am getting olser...... > > been thinking about electrics....saw them at camping world for $100 > > but they do not seem to be easy to install....I may just order some > > new paddles from Jeff mif this is the problem...I welcome > suggestions. > > > > Thanks. > > Regards, > > Hank Hannigan > > 90SP36 > > 80FC31 > > ps...paddle problem is on my 80FC31...the 90SP has new > Dupree/Miller > > air dumps. > > > |
09-14-2006, 13:54
Went electric and never looked back..pretty easy to install.
Bob Lawrence 84 PT36 Tacky Tacoma, Wa. > been thinking about electrics....saw them at camping world for $100 > but they do not seem to be easy to install....I may just order some > new paddles from Jeff mif this is the problem...I welcome suggestions. > > Thanks. > Regards, > Hank Hannigan > 90SP36 > 80FC31 > ps...paddle problem is on my 80FC31...the 90SP has new Dupree/Miller > air dumps. > |
09-14-2006, 14:29
Pretty much what Frank said.
If the seal is still in good shape, lube with plumber's grease from any hardware. Lubed they should slide open/closed freely, provided the seals weren't installed improperly or are damaged. - Jeff Miller in Holland, MI --- In WanderlodgeForum@yahoogroups.com, "fwernlein" wrote: > > Dupree/Miller will likey reply also...but I have had luck with: 1: > doing a good dump & flush. 2: then removing the two small recessed > screws and removing the paddles (this is why you flush well in > #1)...if the rubber seal looks good, just clean and lube (i use > silicone and avoid petro based for rubber) and reinstall, noting > which side faces in/outlet. If the seal is torn, hard or "wavy" > around the perimeter...order a new paddle. > > Frank W. > 85FC33 > Woodbridge, VA. > > --- In WanderlodgeForum@yahoogroups.com, "one_dusty_hoot" > > > > > Vaseoline??, or, KY Jelly?? > > Bob Janes, Greenville, SC > > > > --- In WanderlodgeForum@yahoogroups.com, "Henry Jay Hannigan" > > > > > > > > Hey Jeff and others of interest....... > > > I am having a hard time pulling out the levers on my tanks...the > > twist > > > left is ok but it takes a ton to pull them out and a ton to put > > them > > > in the last 1/2 inch...and...I am getting olser...... > > > been thinking about electrics....saw them at camping world for > $100 > > > but they do not seem to be easy to install....I may just order > some > > > new paddles from Jeff mif this is the problem...I welcome > > suggestions. > > > > > > Thanks. > > > Regards, > > > Hank Hannigan > > > 90SP36 > > > 80FC31 > > > ps...paddle problem is on my 80FC31...the 90SP has new > > Dupree/Miller > > > air dumps. > > > > > > |
