now continous duty Solenoid
10-10-2006, 13:12
Greg,
That could be. I haven't noticed any heat on the solenoids. The continous duty solenoids that are energized when the ignition switch is turned on, carry a significant load. The solenoids that provided 12V for the Redi-Line generator had to allow about 150 amps (there were 2 solenoids in series on my Redi-Line circuit) to pass thru them. I did replace the Redi-Line solenoids with 30amp intermittent duty solenoids(cause I didn't know any better), they lasted about 15 minutes. So now, try to use a bit of overkill to be sure they will last 20 years. The fantom draw you mentioned, would that allow continuty thru the solenoid from power source to load? or from the activation terminal to ground? I do not notice continuity thru the solenoid when it is not activated by voltage at the activation terminal. Thanks Jay Darst 85PT40 Springfield, IL --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > Jay, I wonder if continous duty solenoids are a fantom draw on the > battery while the bus is at rest. Dodge put in a two relay solenoid > in my old 97 Cummins for the fuel shut off. high amp draw opens and > low amp is used to maintain open. less draw, less heat. > GregoryO'Connor > 94PtRomolandCa |
10-10-2006, 16:35
I have been trying to find the major fantom draws. My batteries
drain out after 4 days (all 8) The gen set wont start without full charge. I think the starter is weak or the 40 foot cable run is faulty. The chicken/egg thing kicks in as I can only guess that the low battery starts caused starter damage. The genset fuel drains back to the tank and I think the previous owner must have just cranked and cranked untill it started. Thought about installing a battery in the genset but I should bench test the starter first. I never considered the existance of a energized solenoid when the bus is parked at rest. GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, "Jay Darst" > > Greg, > > That could be. > > I haven't noticed any heat on the solenoids. > > The continous duty solenoids that are energized when the ignition > switch is turned on, carry a significant load. The solenoids that > provided 12V for the Redi-Line generator had to allow about 150 amps > (there were 2 solenoids in series on my Redi-Line circuit) to pass > thru them. I did replace the Redi-Line solenoids with 30amp > intermittent duty solenoids(cause I didn't know any better), they > lasted about 15 minutes. > > So now, try to use a bit of overkill to be sure they will last 20 > years. > > The fantom draw you mentioned, would that allow continuty thru the > solenoid from power source to load? or from the activation terminal > to ground? > > I do not notice continuity thru the solenoid when it is not > activated by voltage at the activation terminal. > > > Thanks > Jay Darst > 85PT40 > Springfield, IL > > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor" > > > > > Jay, I wonder if continous duty solenoids are a fantom draw on > the > > battery while the bus is at rest. Dodge put in a two relay > solenoid > > in my old 97 Cummins for the fuel shut off. high amp draw opens > and > > low amp is used to maintain open. less draw, less heat. > > GregoryO'Connor > > 94PtRomolandCa > |
