					Gas Springs, again
					12-14-2006, 06:54
				 Post: #1 | |||
| Gas Springs, again
					Greetings All: Review of the archives leaves some questions unanswered. For example, several vendors are described as capable of cross-referencing the numbers from existing springs on the coach. What numbers? Of the 17 on the interior of my 85 PT40, I don't think any two are numbered the same. I've found at least these manufacturers markings--"SPD," "Spring Lift," "Lift-O-Mat," and "Stabilus." Here are examples: SPD-GS-5100-20 (Is this a 20 pound unit?) Spring Lift <M 3504 MI 0140N 300/99> (This a 140 Newton--30 pounder?) Lift-O-Mat ???Anyone have the secret decoder ring for these??? In addition, suggested replacements (in the "database" and "files" sections) have strengths ranging from 20 to 30 pounds, if I understand the numbers given. My bin doors range from 26--36 inches in width, plus the aft panel over the camera which is 48" wide with two springs. Does one size fit all? If I get stronger replacements am I at risk of knocking my glasses off each time one is opened? The exterior bay doors are similar--some appear to be 500 Newton (120 pound) Lift-O-Mat units and some are 90 pound SPDs. ??? A final question: several of the interior bin door latches are failing. I can find no manufacturers mark. What are these named? Is there a suggested source? Thanks-- M.R.Kane 1985 PT40 | |||
					12-14-2006, 12:46
				 Post: #2 | |||
| Gas Springs, again
					M.R. I got springs from ORR&ORR. I ordered the 35# units but found they were overkill, I got some 20# units and they work great on the shorter overheads. I had fastened a booster amp for the stereo on one of the doors, and the 35# was a perfect size. Measure your springs retracted and extended. then look for a good fit on the ORR&ORR site. They are great to do business with. Also, the prices on the web are higher than the actual price you will pay. Contact them and get a price, you will be pleased. I also got some for the outside doors. I found the 45# units were good for the long door on the left rear of my '78FC. I originaly got 65# units, again way too powerful. It was hard to open the door, and stressed the hinges when open. On my last order they inadvertently sent two incorrect springs. When I sent an e-mail they sent the correct ones and said to just keep the others. Real good customer service. Gardner 78FC33 --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote: > > Greetings All: > > Review of the archives leaves some questions unanswered. For example, > several vendors are described as capable of cross-referencing the > numbers from existing springs on the coach. What numbers? Of the 17 > on the interior of my 85 PT40, I don't think any two are numbered the > same. I've found at least these manufacturers markings--"SPD," > "Spring Lift," "Lift-O-Mat," and "Stabilus." Here are examples: > > SPD-GS-5100-20 (Is this a 20 pound unit?) > > Spring Lift > <M 3504 MI 0140N 300/99> (This a 140 Newton--30 pounder?) > > Lift-O-Mat > > > ???Anyone have the secret decoder ring for these??? > > In addition, suggested replacements (in the "database" and "files" > sections) have strengths ranging from 20 to 30 pounds, if I understand > the numbers given. My bin doors range from 26--36 inches in width, > plus the aft panel over the camera which is 48" wide with two springs. > Does one size fit all? If I get stronger replacements am I at risk of > knocking my glasses off each time one is opened? > > The exterior bay doors are similar--some appear to be 500 Newton (120 > pound) Lift-O-Mat units and some are 90 pound SPDs. ??? > > A final question: several of the interior bin door latches are > failing. I can find no manufacturers mark. What are these named? Is > there a suggested source? > > Thanks-- > > M.R.Kane > 1985 PT40 > | |||
 Member Funded
Member Funded Link Directory
User Locations Gallery
Gallery Calendar
