Rear Bath Fresh Water Tanks
01-20-2007, 06:45
Hello all,
Wanted to share something I discovered today and also ask for advice. My 82 FC35RB has two fresh water tanks, one under each twin bed. I assume all RB's are configured this way. The fresh water fill line has a 'T' in it under the road side bed, allowing water to flow from the sporlan valve to both tanks. Since it is a 'T' and not a 'Y', though, the curb side tank fills faster as it water flows straight to its fill hose while it must make a 90 degree turn to flow into the road side bed. This means that on mine, when water starts to flow out of the overflow under the coach from the curb side tank (theoretically indicating a complete fill), the road side tank is FAR from full, maybe ony 20%. This is complicated by the fact that the tank level indicator probes are on the curb side tank, so they will show full even if the other tank isn't. This leads me to a couple questions: 1) Has anyone else noticed this problem? I am wondering if this is just a bad design on BB's part, or if I have another problem like a clogged hose. 2) If it is a bad design, my idea is to install a ball valve below the 'T', so that I can stop flow to the curb side tank while the other continues to fill. Opinions on this? I had to let water flow freely out of the curb side overflow for some time in order to get the other tank full. If you have a RB, you may want to check how yours works, you may not be getting a full load of water. Scott Forman 82 FC35RB Memphis |
01-20-2007, 07:02
Scott- the water pipes from one tank to the other are run in a cut in the
plywood in the aisle. perhaps someone has crimped that line if they replaced any of the flooring? Ernie-83PT40 in Texas ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Saturday, January 20, 2007 11:45 AM Subject: [WanderlodgeForum] Rear Bath Fresh Water Tanks Hello all, Wanted to share something I discovered today and also ask for advice. My 82 FC35RB has two fresh water tanks, one under each twin bed. I assume all RB's are configured this way. The fresh water fill line has a 'T' in it under the road side bed, allowing water to flow from the sporlan valve to both tanks. Since it is a 'T' and not a 'Y', though, the curb side tank fills faster as it water flows straight to its fill hose while it must make a 90 degree turn to flow into the road side bed. This means that on mine, when water starts to flow out of the overflow under the coach from the curb side tank (theoretically indicating a complete fill), the road side tank is FAR from full, maybe ony 20%. This is complicated by the fact that the tank level indicator probes are on the curb side tank, so they will show full even if the other tank isn't. This leads me to a couple questions: 1) Has anyone else noticed this problem? I am wondering if this is just a bad design on BB's part, or if I have another problem like a clogged hose. 2) If it is a bad design, my idea is to install a ball valve below the 'T', so that I can stop flow to the curb side tank while the other continues to fill. Opinions on this? I had to let water flow freely out of the curb side overflow for some time in order to get the other tank full. If you have a RB, you may want to check how yours works, you may not be getting a full load of water. Scott Forman 82 FC35RB Memphis [Non-text portions of this message have been removed] |
01-20-2007, 07:25
That would make sense, except it's the line that doesn't run under
the floor that has the problem. It's the street side line. Thanks Scott --- In WanderlodgeForum@yahoogroups.com, > > Scott- the water pipes from one tank to the other are run in a cut in the plywood in the aisle. perhaps someone has crimped that line if they replaced any of the flooring? Ernie-83PT40 in Texas > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, January 20, 2007 11:45 AM > Subject: [WanderlodgeForum] Rear Bath Fresh Water Tanks > > > Hello all, > > Wanted to share something I discovered today and also ask for advice. > > My 82 FC35RB has two fresh water tanks, one under each twin bed. I > assume all RB's are configured this way. The fresh water fill line > has a 'T' in it under the road side bed, allowing water to flow from > the sporlan valve to both tanks. Since it is a 'T' and not a 'Y', > though, the curb side tank fills faster as it water flows straight to > its fill hose while it must make a 90 degree turn to flow into the > road side bed. This means that on mine, when water starts to flow > out of the overflow under the coach from the curb side tank > (theoretically indicating a complete fill), the road side tank is FAR > from full, maybe ony 20%. This is complicated by the fact that the > tank level indicator probes are on the curb side tank, so they will > show full even if the other tank isn't. This leads me to a couple > questions: > > 1) Has anyone else noticed this problem? I am wondering if this is > just a bad design on BB's part, or if I have another problem like a > clogged hose. > > 2) If it is a bad design, my idea is to install a ball valve below > the 'T', so that I can stop flow to the curb side tank while the > other continues to fill. Opinions on this? > > I had to let water flow freely out of the curb side overflow for some > time in order to get the other tank full. If you have a RB, you may > want to check how yours works, you may not be getting a full load of > water. > > Scott Forman > 82 FC35RB > Memphis > > > > > > [Non-text portions of this message have been removed] > |
01-20-2007, 08:04
Hi Scott,
Don't have two tanks so can't share your situation. Some things I might try: 1.) Run water into the bottom of the "T" so it will go in equal directions. 2.)Restrict the curbside with a smaller hose, fitting, or check valve. 3.)If possible pipe the overflow from street side to curbside allowing street side to fill first. 4.)Restrict the air escaping from curbside, it cannot fill fast if the air is not displaced to outside the tank. If you can solve the problem without adding a valve that you have to turn on and off at each fill-up you will not only make it eaiser on yourself but eliminate the opportunity to forget. bob janes, 87fc35, greenville, sc --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Hello all, > > Wanted to share something I discovered today and also ask for advice. > > My 82 FC35RB has two fresh water tanks, one under each twin bed. I > assume all RB's are configured this way. The fresh water fill line > has a 'T' in it under the road side bed, allowing water to flow from > the sporlan valve to both tanks. Since it is a 'T' and not a 'Y', > though, the curb side tank fills faster as it water flows straight to > its fill hose while it must make a 90 degree turn to flow into the > road side bed. This means that on mine, when water starts to flow > out of the overflow under the coach from the curb side tank > (theoretically indicating a complete fill), the road side tank is FAR > from full, maybe ony 20%. This is complicated by the fact that the > tank level indicator probes are on the curb side tank, so they will > show full even if the other tank isn't. This leads me to a couple > questions: > > 1) Has anyone else noticed this problem? I am wondering if this is > just a bad design on BB's part, or if I have another problem like a > clogged hose. > > 2) If it is a bad design, my idea is to install a ball valve below > the 'T', so that I can stop flow to the curb side tank while the > other continues to fill. Opinions on this? > > I had to let water flow freely out of the curb side overflow for some > time in order to get the other tank full. If you have a RB, you may > want to check how yours works, you may not be getting a full load of > water. > > Scott Forman > 82 FC35RB > Memphis > |
01-20-2007, 09:12
Scott,
My 'Bird is identical to yours and I just now finished filling the water tanks. I stopped filling as soon as there was water flowing just a little bit out of the curb side overflow, I went in and checked the street side water tank level, by accessing it through the small compartment door at the bathroom door end of the street side bed and by placing a flashlight up against the tank I can see what the water level is and it is 2 1/2" from the top, I'm guessing that would be about 90% full. I always stop filling at this point, so I have no idea how much longer I would have to leave thee water running out the curbside overflow to finish filling that last 10%. I might try raising the right side levelers next time to elevate the curbside tank and overflow and see if that helps, maybe you can try just the opposite on yours. "REMEMBER SEPTEMBER 11, 2001" John Finn '82 35FCRB BLUEBIRD WANDERLODGE TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE GO TO; http://www.pbase.com/image/24977457 HOPKINS, SOUTH CAROLINA ////////////////////////////////////////////////////////////// --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Hello all, > > Wanted to share something I discovered today and also ask for advice. > > My 82 FC35RB has two fresh water tanks, one under each twin bed. I > assume all RB's are configured this way. The fresh water fill line > has a 'T' in it under the road side bed, allowing water to flow from > the sporlan valve to both tanks. Since it is a 'T' and not a 'Y', > though, the curb side tank fills faster as it water flows straight to > its fill hose while it must make a 90 degree turn to flow into the > road side bed. This means that on mine, when water starts to flow > out of the overflow under the coach from the curb side tank > (theoretically indicating a complete fill), the road side tank is FAR > from full, maybe ony 20%. This is complicated by the fact that the > tank level indicator probes are on the curb side tank, so they will > show full even if the other tank isn't. This leads me to a couple > questions: > > 1) Has anyone else noticed this problem? I am wondering if this is > just a bad design on BB's part, or if I have another problem like a > clogged hose. > > 2) If it is a bad design, my idea is to install a ball valve below > the 'T', so that I can stop flow to the curb side tank while the > other continues to fill. Opinions on this? > > I had to let water flow freely out of the curb side overflow for some > time in order to get the other tank full. If you have a RB, you may > want to check how yours works, you may not be getting a full load of > water. > > Scott Forman > 82 FC35RB > Memphis > |
01-20-2007, 09:54
Scott:
I have a side bath as well, but my two suggestions: - What happens when you turn the water on with less pressure? - Why not plug the curb side overflow and let it fill the other tank till it overflows. Bill 84 FC 35 SB "$quanderlodge" Terrace, B.C. Canada ----- Original Message ---- From: one_dusty_hoot To: WanderlodgeForum@yahoogroups.com Sent: Saturday, January 20, 2007 12:04:17 PM Subject: [WanderlodgeForum] Re: Rear Bath Fresh Water Tanks Hi Scott, Don't have two tanks so can't share your situation. Some things I might try: 1.) Run water into the bottom of the "T" so it will go in equal directions. 2.)Restrict the curbside with a smaller hose, fitting, or check valve. 3.)If possible pipe the overflow from street side to curbside allowing street side to fill first. 4.)Restrict the air escaping from curbside, it cannot fill fast if the air is not displaced to outside the tank. If you can solve the problem without adding a valve that you have to turn on and off at each fill-up you will not only make it eaiser on yourself but eliminate the opportunity to forget. bob janes, 87fc35, greenville, sc --- In WanderlodgeForum@ yahoogroups. com, "Scott Forman" <sforman@... > wrote: > > Hello all, > > Wanted to share something I discovered today and also ask for advice. > > My 82 FC35RB has two fresh water tanks, one under each twin bed. I > assume all RB's are configured this way. The fresh water fill line > has a 'T' in it under the road side bed, allowing water to flow from > the sporlan valve to both tanks. Since it is a 'T' and not a 'Y', > though, the curb side tank fills faster as it water flows straight to > its fill hose while it must make a 90 degree turn to flow into the > road side bed. This means that on mine, when water starts to flow > out of the overflow under the coach from the curb side tank > (theoretically indicating a complete fill), the road side tank is FAR > from full, maybe ony 20%. This is complicated by the fact that the > tank level indicator probes are on the curb side tank, so they will > show full even if the other tank isn't. This leads me to a couple > questions: > > 1) Has anyone else noticed this problem? I am wondering if this is > just a bad design on BB's part, or if I have another problem like a > clogged hose. > > 2) If it is a bad design, my idea is to install a ball valve below > the 'T', so that I can stop flow to the curb side tank while the > other continues to fill. Opinions on this? > > I had to let water flow freely out of the curb side overflow for some > time in order to get the other tank full. If you have a RB, you may > want to check how yours works, you may not be getting a full load of > water. > > Scott Forman > 82 FC35RB > Memphis > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
01-20-2007, 10:33
Scott
Our 1980 rear bath has 2 fill lines and no sporlan valve as far as I can tell,there is a ball valve on each fill line. It does draw water similar to the way yours fills because of the T to the pump. I did cut a hole in the top of each tank to add water on the road without a hose, used 8 inch round screw in deck lids. It allows us to clean the inside of the tanks, also helps to blow out the lines before winter. I just wish there was a way to keep from losing so much water out the overflows each time you hit the brakes, every time I stop I leave a good trail of water out of each tank, I bet thats not what the people behind me think it is? Sorry to get alittle of topic as usual. Michelle and Jeff August 1980FC35RB Plymouth Wi. --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Hello all, > > Wanted to share something I discovered today and also ask for advice. > > My 82 FC35RB has two fresh water tanks, one under each twin bed. I > assume all RB's are configured this way. The fresh water fill line > has a 'T' in it under the road side bed, allowing water to flow from > the sporlan valve to both tanks. Since it is a 'T' and not a 'Y', > though, the curb side tank fills faster as it water flows straight to > its fill hose while it must make a 90 degree turn to flow into the > road side bed. This means that on mine, when water starts to flow > out of the overflow under the coach from the curb side tank > (theoretically indicating a complete fill), the road side tank is FAR > from full, maybe ony 20%. This is complicated by the fact that the > tank level indicator probes are on the curb side tank, so they will > show full even if the other tank isn't. This leads me to a couple > questions: > > 1) Has anyone else noticed this problem? I am wondering if this is > just a bad design on BB's part, or if I have another problem like a > clogged hose. > > 2) If it is a bad design, my idea is to install a ball valve below > the 'T', so that I can stop flow to the curb side tank while the > other continues to fill. Opinions on this? > > I had to let water flow freely out of the curb side overflow for some > time in order to get the other tank full. If you have a RB, you may > want to check how yours works, you may not be getting a full load of > water. > > Scott Forman > 82 FC35RB > Memphis > |
01-20-2007, 13:13
Scott has a good answer to his question, in the question, replace
the T with a Y. I myself would just drink coffee and watch TV until both tanks overflow. Irrigation suppliers sell pressure compensating flow valves for drip irrigation. I've used them inline on drip systems that run down hill over 200 feet (major PSI variables) with little problem. http://www.hendricksonbros.com/flwcntrl.htm the problem with using a ball valve restrictor on one tank is volumn change expodentialy with increased pressure at given line size. and using a pressure regulator on the fill to maintain the proper pressure for the adjusted restriction will only protect the top side of the math. (just wait for both tanks to blow water) GregoryO'Connor 94ptRomolandCa --- In WanderlodgeForum@yahoogroups.com, Wilhelmus Schreurs > > Scott: > I have a side bath as well, but my two suggestions: > - What happens when you turn the water on with less pressure? > - Why not plug the curb side overflow and let it fill the other tank till it overflows. > > > > Bill 84 FC 35 SB "$quanderlodge" > Terrace, B.C. Canada > > > > > ----- Original Message ---- > From: one_dusty_hoot > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, January 20, 2007 12:04:17 PM > Subject: [WanderlodgeForum] Re: Rear Bath Fresh Water Tanks > > Hi Scott, > Don't have two tanks so can't share your situation. > Some things I might try: > 1.) Run water into the bottom of the "T" so it will > go in equal directions. > 2.)Restrict the curbside with a smaller hose, fitting, > or check valve. > 3.)If possible pipe the overflow from street side to > curbside allowing street side to fill first. > 4.)Restrict the air escaping from curbside, it > cannot fill fast if the air is not displaced to > outside the tank. > > If you can solve the problem without adding a valve > that you have to turn on and off at each fill-up you > will not only make it eaiser on yourself but eliminate > the opportunity to forget. > > bob janes, 87fc35, greenville, sc > > --- In WanderlodgeForum@ yahoogroups. com, "Scott Forman" <sforman@ > > wrote: > > > > Hello all, > > > > Wanted to share something I discovered today and also ask for > advice. > > > > My 82 FC35RB has two fresh water tanks, one under each twin bed. I > > assume all RB's are configured this way. The fresh water fill line > > has a 'T' in it under the road side bed, allowing water to flow > from > > the sporlan valve to both tanks. Since it is a 'T' and not a 'Y', > > though, the curb side tank fills faster as it water flows straight > to > > its fill hose while it must make a 90 degree turn to flow into the > > road side bed. This means that on mine, when water starts to flow > > out of the overflow under the coach from the curb side tank > > (theoretically indicating a complete fill), the road side tank is > FAR > > from full, maybe ony 20%. This is complicated by the fact that the > > tank level indicator probes are on the curb side tank, so they will > > show full even if the other tank isn't. This leads me to a couple > > questions: > > > > 1) Has anyone else noticed this problem? I am wondering if this is > > just a bad design on BB's part, or if I have another problem like a > > clogged hose. > > > > 2) If it is a bad design, my idea is to install a ball valve below > > the 'T', so that I can stop flow to the curb side tank while the > > other continues to fill. Opinions on this? > > > > I had to let water flow freely out of the curb side overflow for > some > > time in order to get the other tank full. If you have a RB, you > may > > want to check how yours works, you may not be getting a full load > of > > water. > > > > Scott Forman > > 82 FC35RB > > Memphis > > > > > > > __________________________________________________ > Do You Yahoo!? > Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > [Non-text portions of this message have been removed] > |
