Satellite Receiver Hookup
02-07-2007, 05:41
I wired from the satellite to the Direct TV receiver..from the DTV
receiver to a new splitter with gain control...from the splitter to the 3 TVs (rear, forward, bay). Works great. The old BB stuff gave a fuzzy picture. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Richard Hayden wrote: > That wouldn't be the first time Jim. Although, as I just replied to > Tom, I did try going through the existing setup and had trouble. It's > been awhile but I seem to recall a problem with the splitters behind > the switch/amp box. Maybe I have a problem there and it just isn't > showing up the way I using it now with only 1 tv. > > Dick Hayden - '87 PT 38 - Lake Stevens, WA > > ----- Original Message ----- > From: jqrjr > To: WanderlodgeForum@yahoogroups.com > > > Sent: Wednesday, February 07, 2007 8:42 AM > Subject: [WanderlodgeForum] Re: Satellite Receiver Hookup > > BY the way, I also think that Dick is wrong. > Jim Riordan > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > Well, I cannot tell you exactly how my coach is wired unless I go > out and track down the wires. It took me and a video guy a while to > get it right. Here is how mine works. > > I have 3 TV's. > > > > I have: > > In motion Satellite Receiver box(technical name escapes me at the > moment) L-3 TracVision > > A-B switch in the coach. > > Land line cable port (factory) > > Space Ship Air Antenna installed at factory. > > > > When my satellite receiver is on I receive satellite TV. > > When I plug into cable TV, park supplied, and turn off the > satellite receiver I receive cable TV. > > If I want to use the Air antenna, seldom, I switch from A to B and > I receive nearby stations over the air. Satellite TV receiver off. > > In the satellite and cable configuration the switch is always in > position A. > > > > Reception is very clear in all cases. > > > > I hope this helps you. > > > > Leroy Eckert > > 1990 WB-40 "Smoke N Mirrors" > > Niceville, FL > > > > > > > > > > > > ----- Original Message ----- > > From: what1not > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Tuesday, February 06, 2007 7:52 PM > > Subject: [WanderlodgeForum] Satellite Receiver Hookup > > > > > > Hi Everyone, > > > > I have a '87 PT40 and I am looking at adding a portable satellite > > dish to my setup. > > > > A couple of questions: > > > > 1. Can you bring the satellite signal through the cable input > switch > > to the satellite receiver? > > > > 2. I understand that there is power going to the dish from the > > satellite receiver and that there is an issue with the amplifier > for > > the regular antenna which somehow do not allow the satellite and > > reciever to properly communicate. If I can't go through the A C > > switch in the coach can I split the cable input to the switch and > > then go directly to the satellite receiver when not using a cable > > setup? > > > > Any other info is greatly appreciated! > > > > Jo and Bill Neil > > '87 PT40 > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > [Non-text portions of this message have been removed] > > |
02-07-2007, 10:32
Tom a simple diagram would be great. I have had trouble with the BB
switch to work with my sat. Set up. Thanks Jack Jones East Tn 87 PT 40 WanderlodgeForum@yahoogroups.com, Tom Warner > > In my 1985 PT 40 setup (was the same for my 1982 FC35) there is a > switch with two positions in the small upper bin that houses the > switch and amplifiers and two AC receptacles. One input to the switch > is from the outside cable TV input that is in the drivers side rear > compartment where the AC inputs are. The other input is from the > overhead TV antenna. I installed a new satellite antenna and ran the > two output cables and control cable from it thru a new cable entrance > I installed near the goat rail into the inside overhead bin. From > there the control cable goes directly to control switch for the > direct satellite control box, and one of the satellite antenna > outputs goes to the receiver, the other is left coiled up since I > dont use it. I ran a new coax from the output of the satellite > receiver to the 2 position switch provided by BB, disconnected the > input from the rear cable TV line and connected the output from the > satellite receiver in its place. Now I can chose either the overhead > TV antenna or the satellite receiver output. I also added a modulator > and DVD player and routed its output to the satellite receiver > external antenna input. Now with the satellite receiver on I can use > it, or when I switch it off can chose the DVD player. The satellite > receiver has an internal switch that switches the output from the > satellite receiver to the DVD player when it is switched off. > > Tom Warner > vernon center,ny > 1985 PT 40 > > At 12:20 PM 2/7/2007, you wrote: > >That wouldn't be the first time Jim. Although, as I just replied to > >Tom, I did try going through the existing setup and had > >trouble. It's been awhile but I seem to recall a problem with the > >splitters behind the switch/amp box. Maybe I have a problem there > >and it just isn't showing up the way I using it now with only 1 tv. > > > >Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > ----- Original Message ----- > > From: jqrjr > > To: > > WanderlodgeForum@yahoogroups.com > > Sent: Wednesday, February 07, 2007 8:42 AM > > Subject: [WanderlodgeForum] Re: Satellite Receiver Hookup > > > > > > BY the way, I also think that Dick is wrong. > > Jim Riordan > > > > --- In > > WanderlodgeForum@yahoogroups.com > > "Leroy Eckert" > > > > > > > > Well, I cannot tell you exactly how my coach is wired unless I go > > out and track down the wires. It took me and a video guy a while to > > get it right. Here is how mine works. > > > I have 3 TV's. > > > > > > I have: > > > In motion Satellite Receiver box(technical name escapes me at the > > moment) L-3 TracVision > > > A-B switch in the coach. > > > Land line cable port (factory) > > > Space Ship Air Antenna installed at factory. > > > > > > When my satellite receiver is on I receive satellite TV. > > > When I plug into cable TV, park supplied, and turn off the > > satellite receiver I receive cable TV. > > > If I want to use the Air antenna, seldom, I switch from A to B and > > I receive nearby stations over the air. Satellite TV receiver off. > > > In the satellite and cable configuration the switch is always in > > position A. > > > > > > Reception is very clear in all cases. > > > > > > I hope this helps you. > > > > > > Leroy Eckert > > > 1990 WB-40 "Smoke N Mirrors" > > > Niceville, FL > > > > > > > > > > > > > > > > > > ----- Original Message ----- > > > From: what1not > > > To: > > WanderlodgeForum@yahoogroups.com > > > Sent: Tuesday, February 06, 2007 7:52 PM > > > Subject: [WanderlodgeForum] Satellite Receiver Hookup > > > > > > > > > Hi Everyone, > > > > > > I have a '87 PT40 and I am looking at adding a portable satellite > > > dish to my setup. > > > > > > A couple of questions: > > > > > > 1. Can you bring the satellite signal through the cable input > > switch > > > to the satellite receiver? > > > > > > 2. I understand that there is power going to the dish from the > > > satellite receiver and that there is an issue with the amplifier > > for > > > the regular antenna which somehow do not allow the satellite and > > > reciever to properly communicate. If I can't go through the A C > > > switch in the coach can I split the cable input to the switch and > > > then go directly to the satellite receiver when not using a cable > > > setup? > > > > > > Any other info is greatly appreciated! > > > > > > Jo and Bill Neil > > > '87 PT40 > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > >Yahoo! Groups Links > > > > > > > |
02-07-2007, 10:48
Jack the switch itself is very simple with two inputs , one from the
rear cable tv line coming from the same small compartment that the shore line power receptacles are housed, the other from your rooftop TV antenna. The output of the switch goes to the amplifiers etc and then to each wall outlet for your tv, one near the passenger side wall in front, one to the front backup/tv monitor and the other to the rear bedroom. I dont use the one from the rear cable tv input so removed the connector from the switch and connected the new cable running from the satellite receiver to it. tom At 05:32 PM 2/7/2007, you wrote: >Tom a simple diagram would be great. I have had trouble with the BB >switch to work with my sat. Set up. >Thanks >Jack Jones >East Tn 87 >PT 40 > >WanderlodgeForum@yahoogroups.com, Tom >Warner > > > > In my 1985 PT 40 setup (was the same for my 1982 FC35) there is a > > switch with two positions in the small upper bin that houses the > > switch and amplifiers and two AC receptacles. One input to the >switch > > is from the outside cable TV input that is in the drivers side >rear > > compartment where the AC inputs are. The other input is from the > > overhead TV antenna. I installed a new satellite antenna and ran >the > > two output cables and control cable from it thru a new cable >entrance > > I installed near the goat rail into the inside overhead bin. From > > there the control cable goes directly to control switch for the > > direct satellite control box, and one of the satellite antenna > > outputs goes to the receiver, the other is left coiled up since I > > dont use it. I ran a new coax from the output of the satellite > > receiver to the 2 position switch provided by BB, disconnected the > > input from the rear cable TV line and connected the output from >the > > satellite receiver in its place. Now I can chose either the >overhead > > TV antenna or the satellite receiver output. I also added a >modulator > > and DVD player and routed its output to the satellite receiver > > external antenna input. Now with the satellite receiver on I can >use > > it, or when I switch it off can chose the DVD player. The >satellite > > receiver has an internal switch that switches the output from the > > satellite receiver to the DVD player when it is switched off. > > > > Tom Warner > > vernon center,ny > > 1985 PT 40 > > > > At 12:20 PM 2/7/2007, you wrote: > > >That wouldn't be the first time Jim. Although, as I just replied >to > > >Tom, I did try going through the existing setup and had > > >trouble. It's been awhile but I seem to recall a problem with >the > > >splitters behind the switch/amp box. Maybe I have a problem >there > > >and it just isn't showing up the way I using it now with only 1 >tv. > > > > > >Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > > > > ----- Original Message ----- > > > From: jqrjr > > > To: > > > >WanderlodgeForum@yahoogroups.com< anderlodgeForum@yahoogroups. >com> > > > Sent: Wednesday, February 07, 2007 8:42 AM > > > Subject: [WanderlodgeForum] Re: Satellite Receiver Hookup > > > > > > > > > BY the way, I also think that Dick is wrong. > > > Jim Riordan > > > > > > --- In > > > >WanderlodgeForum@yahoogroups.com< anderlodgeForum@yahoogroups. >com>, > > > "Leroy Eckert" > > > > > > > > > > > Well, I cannot tell you exactly how my coach is wired unless >I go > > > out and track down the wires. It took me and a video guy a >while to > > > get it right. Here is how mine works. > > > > I have 3 TV's. > > > > > > > > I have: > > > > In motion Satellite Receiver box(technical name escapes me >at the > > > moment) L-3 TracVision > > > > A-B switch in the coach. > > > > Land line cable port (factory) > > > > Space Ship Air Antenna installed at factory. > > > > > > > > When my satellite receiver is on I receive satellite TV. > > > > When I plug into cable TV, park supplied, and turn off the > > > satellite receiver I receive cable TV. > > > > If I want to use the Air antenna, seldom, I switch from A to >B and > > > I receive nearby stations over the air. Satellite TV receiver >off. > > > > In the satellite and cable configuration the switch is >always in > > > position A. > > > > > > > > Reception is very clear in all cases. > > > > > > > > I hope this helps you. > > > > > > > > Leroy Eckert > > > > 1990 WB-40 "Smoke N Mirrors" > > > > Niceville, FL > > > > > > > > > > > > > > > > > > > > > > > > ----- Original Message ----- > > > > From: what1not > > > > To: > > > WanderlodgeForum@yahoogroups.com > > > > Sent: Tuesday, February 06, 2007 7:52 PM > > > > Subject: [WanderlodgeForum] Satellite Receiver Hookup > > > > > > > > > > > > Hi Everyone, > > > > > > > > I have a '87 PT40 and I am looking at adding a portable >satellite > > > > dish to my setup. > > > > > > > > A couple of questions: > > > > > > > > 1. Can you bring the satellite signal through the cable input > > > switch > > > > to the satellite receiver? > > > > > > > > 2. I understand that there is power going to the dish from >the > > > > satellite receiver and that there is an issue with the >amplifier > > > for > > > > the regular antenna which somehow do not allow the satellite >and > > > > reciever to properly communicate. If I can't go through the >A C > > > > switch in the coach can I split the cable input to the >switch and > > > > then go directly to the satellite receiver when not using a >cable > > > > setup? > > > > > > > > Any other info is greatly appreciated! > > > > > > > > Jo and Bill Neil > > > > '87 PT40 > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > |
02-08-2007, 05:10
Tom,
Go to Radio shack get a switch box that can handle multiple inputs/outputs. Inputs to switch box from each source (Satellite,Cable,over air dish) would be as if they were going to tv. Instead they will go out by coax to switch box. Outputs will go to each set or vcr from the box, you can use (in most cases) the old coax wiring. The switch box allows you to switch on each set between feeds. Mine has several buttons for each appliance (tv or vcr) to choose between the sources (satellite, cable, over the air dish). This is very useful if signifigant other want to watch Wheel of Fortune and you want to watch the Playboy channel. --- In WanderlodgeForum@yahoogroups.com, Tom Warner wrote: > > Jack the switch itself is very simple with two inputs , one from the > rear cable tv line coming from the same small compartment that the > shore line power receptacles are housed, the other from your rooftop > TV antenna. The output of the switch goes to the amplifiers etc and > then to each wall outlet for your tv, one near the passenger side > wall in front, one to the front backup/tv monitor and the other to > the rear bedroom. > I dont use the one from the rear cable tv input so removed the > connector from the switch and connected the new cable running from > the satellite receiver to it. > > tom > > At 05:32 PM 2/7/2007, you wrote: > >Tom a simple diagram would be great. I have had trouble with the BB > >switch to work with my sat. Set up. > >Thanks > >Jack Jones > >East Tn 87 > >PT 40 > > > >WanderlodgeForum@yahoogroups.com, Tom > >Warner > > > > > > In my 1985 PT 40 setup (was the same for my 1982 FC35) there is a > > > switch with two positions in the small upper bin that houses the > > > switch and amplifiers and two AC receptacles. One input to the > >switch > > > is from the outside cable TV input that is in the drivers side > >rear > > > compartment where the AC inputs are. The other input is from the > > > overhead TV antenna. I installed a new satellite antenna and ran > >the > > > two output cables and control cable from it thru a new cable > >entrance > > > I installed near the goat rail into the inside overhead bin. From > > > there the control cable goes directly to control switch for the > > > direct satellite control box, and one of the satellite antenna > > > outputs goes to the receiver, the other is left coiled up since I > > > dont use it. I ran a new coax from the output of the satellite > > > receiver to the 2 position switch provided by BB, disconnected the > > > input from the rear cable TV line and connected the output from > >the > > > satellite receiver in its place. Now I can chose either the > >overhead > > > TV antenna or the satellite receiver output. I also added a > >modulator > > > and DVD player and routed its output to the satellite receiver > > > external antenna input. Now with the satellite receiver on I can > >use > > > it, or when I switch it off can chose the DVD player. The > >satellite > > > receiver has an internal switch that switches the output from the > > > satellite receiver to the DVD player when it is switched off. > > > > > > Tom Warner > > > vernon center,ny > > > 1985 PT 40 > > > > > > At 12:20 PM 2/7/2007, you wrote: > > > >That wouldn't be the first time Jim. Although, as I just replied > >to > > > >Tom, I did try going through the existing setup and had > > > >trouble. It's been awhile but I seem to recall a problem with > >the > > > >splitters behind the switch/amp box. Maybe I have a problem > >there > > > >and it just isn't showing up the way I using it now with only 1 > >tv. > > > > > > > >Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > > > > > > > ----- Original Message ----- > > > > From: jqrjr > > > > To: > > > > > >WanderlodgeForum@yahoogroups.com< > >com> > > > > Sent: Wednesday, February 07, 2007 8:42 AM > > > > Subject: [WanderlodgeForum] Re: Satellite Receiver Hookup > > > > > > > > > > > > BY the way, I also think that Dick is wrong. > > > > Jim Riordan > > > > > > > > --- In > > > > > >WanderlodgeForum@yahoogroups.com< > >com>, > > > > "Leroy Eckert" > > > > > > > > > > > > > > Well, I cannot tell you exactly how my coach is wired unless > >I go > > > > out and track down the wires. It took me and a video guy a > >while to > > > > get it right. Here is how mine works. > > > > > I have 3 TV's. > > > > > > > > > > I have: > > > > > In motion Satellite Receiver box(technical name escapes me > >at the > > > > moment) L-3 TracVision > > > > > A-B switch in the coach. > > > > > Land line cable port (factory) > > > > > Space Ship Air Antenna installed at factory. > > > > > > > > > > When my satellite receiver is on I receive satellite TV. > > > > > When I plug into cable TV, park supplied, and turn off the > > > > satellite receiver I receive cable TV. > > > > > If I want to use the Air antenna, seldom, I switch from A to > >B and > > > > I receive nearby stations over the air. Satellite TV receiver > >off. > > > > > In the satellite and cable configuration the switch is > >always in > > > > position A. > > > > > > > > > > Reception is very clear in all cases. > > > > > > > > > > I hope this helps you. > > > > > > > > > > Leroy Eckert > > > > > 1990 WB-40 "Smoke N Mirrors" > > > > > Niceville, FL > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ----- Original Message ----- > > > > > From: what1not > > > > > To: > > > > WanderlodgeForum@yahoogroups.com > > > > > Sent: Tuesday, February 06, 2007 7:52 PM > > > > > Subject: [WanderlodgeForum] Satellite Receiver Hookup > > > > > > > > > > > > > > > Hi Everyone, > > > > > > > > > > I have a '87 PT40 and I am looking at adding a portable > >satellite > > > > > dish to my setup. > > > > > > > > > > A couple of questions: > > > > > > > > > > 1. Can you bring the satellite signal through the cable input > > > > switch > > > > > to the satellite receiver? > > > > > > > > > > 2. I understand that there is power going to the dish from > >the > > > > > satellite receiver and that there is an issue with the > >amplifier > > > > for > > > > > the regular antenna which somehow do not allow the satellite > >and > > > > > reciever to properly communicate. If I can't go through the > >A C > > > > > switch in the coach can I split the cable input to the > >switch and > > > > > then go directly to the satellite receiver when not using a > >cable > > > > > setup? > > > > > > > > > > Any other info is greatly appreciated! > > > > > > > > > > Jo and Bill Neil > > > > > '87 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > |
02-08-2007, 05:32
I removed the switch box and treat the sat as if it is the prime
input. The one TV is treated asif it is the only TV and the other sets are hard wired monitors (every set is tuned to the same broadcast). Direct TV now has a air anteni input on their box. The box has input for other source of input. And you can chose for the source via the remote clicker. They also have a new box that does not require line of site and the box can be hidden. I tried to setup my 'table-top Campword Porta dish'in a RV site that had a tree blocking my automatic sat dome but the experience was not a happy one. I now use a chainsaw for those situations GregoryO'Connor 94ptRomolandCa " move it or lose it" MayorRisso'75, Greg'07 "Dont touch that Dial" NBC'85, TimV'07 --- In WanderlodgeForum@yahoogroups.com, "jqrjr" > > Tom, > > Go to Radio shack get a switch box that can handle multiple > inputs/outputs. > > > Inputs to switch box from each source (Satellite,Cable,over air dish) > would be as if they were going to tv. Instead they will go out by > coax to switch box. Outputs will go to each set or vcr from the box, > you can use (in most cases) the old coax wiring. The switch box > allows you to switch on each set between feeds. Mine has several > buttons for each appliance (tv or vcr) to choose between the sources > (satellite, cable, over the air dish). This is very useful if > signifigant other want to watch Wheel of Fortune and you want to > watch the Playboy channel. > > > > --- In WanderlodgeForum@yahoogroups.com, Tom Warner > wrote: > > > > Jack the switch itself is very simple with two inputs , one from > the > > rear cable tv line coming from the same small compartment that the > > shore line power receptacles are housed, the other from your > rooftop > > TV antenna. The output of the switch goes to the amplifiers etc and > > then to each wall outlet for your tv, one near the passenger side > > wall in front, one to the front backup/tv monitor and the other to > > the rear bedroom. > > I dont use the one from the rear cable tv input so removed the > > connector from the switch and connected the new cable running from > > the satellite receiver to it. > > > > tom > > > > At 05:32 PM 2/7/2007, you wrote: > > >Tom a simple diagram would be great. I have had trouble with the BB > > >switch to work with my sat. Set up. > > >Thanks > > >Jack Jones > > >East Tn 87 > > >PT 40 > > > > > >WanderlodgeForum@yahoogroups.com, Tom > > >Warner > > > > > > > > In my 1985 PT 40 setup (was the same for my 1982 FC35) there is > a > > > > switch with two positions in the small upper bin that houses the > > > > switch and amplifiers and two AC receptacles. One input to the > > >switch > > > > is from the outside cable TV input that is in the drivers side > > >rear > > > > compartment where the AC inputs are. The other input is from the > > > > overhead TV antenna. I installed a new satellite antenna and > ran > > >the > > > > two output cables and control cable from it thru a new cable > > >entrance > > > > I installed near the goat rail into the inside overhead bin. > From > > > > there the control cable goes directly to control switch for the > > > > direct satellite control box, and one of the satellite antenna > > > > outputs goes to the receiver, the other is left coiled up since > I > > > > dont use it. I ran a new coax from the output of the satellite > > > > receiver to the 2 position switch provided by BB, disconnected > the > > > > input from the rear cable TV line and connected the output from > > >the > > > > satellite receiver in its place. Now I can chose either the > > >overhead > > > > TV antenna or the satellite receiver output. I also added a > > >modulator > > > > and DVD player and routed its output to the satellite receiver > > > > external antenna input. Now with the satellite receiver on I can > > >use > > > > it, or when I switch it off can chose the DVD player. The > > >satellite > > > > receiver has an internal switch that switches the output from > the > > > > satellite receiver to the DVD player when it is switched off. > > > > > > > > Tom Warner > > > > vernon center,ny > > > > 1985 PT 40 > > > > > > > > At 12:20 PM 2/7/2007, you wrote: > > > > >That wouldn't be the first time Jim. Although, as I just > replied > > >to > > > > >Tom, I did try going through the existing setup and had > > > > >trouble. It's been awhile but I seem to recall a problem with > > >the > > > > >splitters behind the switch/amp box. Maybe I have a problem > > >there > > > > >and it just isn't showing up the way I using it now with only 1 > > >tv. > > > > > > > > > >Dick Hayden - '87 PT 38 - Lake Stevens, WA > > > > > > > > > > > > > > > ----- Original Message ----- > > > > > From: jqrjr > > > > > To: > > > > > > > > >WanderlodgeForum@yahoogroups.com< > > >com> > > > > > Sent: Wednesday, February 07, 2007 8:42 AM > > > > > Subject: [WanderlodgeForum] Re: Satellite Receiver Hookup > > > > > > > > > > > > > > > BY the way, I also think that Dick is wrong. > > > > > Jim Riordan > > > > > > > > > > --- In > > > > > > > > >WanderlodgeForum@yahoogroups.com< > > >com>, > > > > > "Leroy Eckert" > > > > > > > > > > > > > > > > > Well, I cannot tell you exactly how my coach is wired > unless > > >I go > > > > > out and track down the wires. It took me and a video guy a > > >while to > > > > > get it right. Here is how mine works. > > > > > > I have 3 TV's. > > > > > > > > > > > > I have: > > > > > > In motion Satellite Receiver box(technical name escapes me > > >at the > > > > > moment) L-3 TracVision > > > > > > A-B switch in the coach. > > > > > > Land line cable port (factory) > > > > > > Space Ship Air Antenna installed at factory. > > > > > > > > > > > > When my satellite receiver is on I receive satellite TV. > > > > > > When I plug into cable TV, park supplied, and turn off the > > > > > satellite receiver I receive cable TV. > > > > > > If I want to use the Air antenna, seldom, I switch from A > to > > >B and > > > > > I receive nearby stations over the air. Satellite TV > receiver > > >off. > > > > > > In the satellite and cable configuration the switch is > > >always in > > > > > position A. > > > > > > > > > > > > Reception is very clear in all cases. > > > > > > > > > > > > I hope this helps you. > > > > > > > > > > > > Leroy Eckert > > > > > > 1990 WB-40 "Smoke N Mirrors" > > > > > > Niceville, FL > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > ----- Original Message ----- > > > > > > From: what1not > > > > > > To: > > > > > WanderlodgeForum@yahoogroups.com > > > > > > Sent: Tuesday, February 06, 2007 7:52 PM > > > > > > Subject: [WanderlodgeForum] Satellite Receiver Hookup > > > > > > > > > > > > > > > > > > Hi Everyone, > > > > > > > > > > > > I have a '87 PT40 and I am looking at adding a portable > > >satellite > > > > > > dish to my setup. > > > > > > > > > > > > A couple of questions: > > > > > > > > > > > > 1. Can you bring the satellite signal through the cable > input > > > > > switch > > > > > > to the satellite receiver? > > > > > > > > > > > > 2. I understand that there is power going to the dish from > > >the > > > > > > satellite receiver and that there is an issue with the > > >amplifier > > > > > for > > > > > > the regular antenna which somehow do not allow the > satellite > > >and > > > > > > reciever to properly communicate. If I can't go through > the > > >A C > > > > > > switch in the coach can I split the cable input to the > > >switch and > > > > > > then go directly to the satellite receiver when not using > a > > >cable > > > > > > setup? > > > > > > > > > > > > Any other info is greatly appreciated! > > > > > > > > > > > > Jo and Bill Neil > > > > > > '87 PT40 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >[Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > >Yahoo! Groups Links > > > > > > > > > > > > |
