PEX Revisited
04-18-2007, 04:37
PEX Revisited
This week we had to have our water line to the house replaced. While
talking to the plumber he mentioned that he had just come from repairing a motor home that had had damaged plumbing from freezing over the winter. He said that it had PEX in it but that the brass couplings burst. The owner thought that because he had PEX plumbing he was safe. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX [Non-text portions of this message have been removed] |
04-18-2007, 08:04
PEX Revisited
While PEX is great stuff, it isn't impervious to mis-handling. It's
more forgiving than most other water pipes, but freezing can still cause damage. When water freezes, it takes more space than when it is in the liquid state. If it is restrained, it will split or damage whatever constrains it. If you don't heat the coach, you must winterize it regardless of the plumbing type. Pete Masterson '95 Blue Bird Wanderlodge WBDA 42 aeonix1@... On the road at Johnson City TX On Apr 18, 2007, at 11:37 AM, Chuck Wheeler wrote: > This week we had to have our water line to the house replaced. While > talking to the plumber he mentioned that he had just come from > repairing a > motor home that had had damaged plumbing from freezing over the > winter. He > said that it had PEX in it but that the brass couplings burst. The > owner > thought that because he had PEX plumbing he was safe. |
