[Fwd: [Fwd: PressurePro Questions]]
05-05-2007, 06:50
Frequency Findings:
The PressurePro operates at 433.92 MHz FM. The SMI Brake System in our coach operates at 433 MHz. I'm MHz challenged so my question is, if the SMI is truly at 433 and not 433.nn MHz, is this going to work or cause interference. Thanks, Curt More questions. Anyone know the frequency the PressurePro operates on? I have the SMI Brake system and wondering if there might be a problem. I tried to find the frequency on their site but nothing available. I called the PressurePro 800 number and left a message regarding frequency. Also, anyone using the Repeater to overcome weak signals. Those that have the PressurePro system installed on your 'Bird. What is your system configuration, are you using the cabled antenna, no antenna, something else? Any issues with the control module receiving the toad signals. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. |
05-05-2007, 07:04
A typical FM channel is 200KHz wide, so between 433.00MHz and
433.92MHz there can be 5 FM channels. David Brady '02 LXi, Smokey NC Curt Sprenger wrote: > > Frequency Findings: > The PressurePro operates at 433.92 MHz FM. The SMI Brake System in our > coach operates at 433 MHz. I'm MHz challenged so my question is, if the > SMI is truly at 433 and not 433.nn MHz, is this going to work or cause > interference. > Thanks, > Curt > > More questions. Anyone know the frequency the PressurePro operates on? I > have the SMI Brake system and wondering if there might be a problem. I > tried to find the frequency on their site but nothing available. I > called the PressurePro 800 number and left a message regarding frequency. > > Also, anyone using the Repeater to overcome weak signals. > > Those that have the PressurePro system installed on your 'Bird. What is > your system configuration, are you using the cabled antenna, no antenna, > something else? Any issues with the control module receiving the toad > signals. > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > ------------------------------------------------------------------------ > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.467 / Virus Database: 269.6.4/790 - Release Date: 5/5/2007 10:34 AM > [Non-text portions of this message have been removed] |
05-05-2007, 07:33
Thank you David. That's good to know.
Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. David Brady wrote: > A typical FM channel is 200KHz wide, so between 433.00MHz and > 433.92MHz there can be 5 FM channels. > > David Brady > '02 LXi, Smokey > NC > > Curt Sprenger wrote: > > > > Frequency Findings: > > The PressurePro operates at 433.92 MHz FM. The SMI Brake System in our > > coach operates at 433 MHz. I'm MHz challenged so my question is, if the > > SMI is truly at 433 and not 433.nn MHz, is this going to work or cause > > interference. > > Thanks, > > Curt > > > > More questions. Anyone know the frequency the PressurePro operates on? I > > have the SMI Brake system and wondering if there might be a problem. I > > tried to find the frequency on their site but nothing available. I > > called the PressurePro 800 number and left a message regarding > frequency. > > > > Also, anyone using the Repeater to overcome weak signals. > > > > Those that have the PressurePro system installed on your 'Bird. What is > > your system configuration, are you using the cabled antenna, no antenna, > > something else? Any issues with the control module receiving the toad > > signals. > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, Calif. > > > > > > ---------------------------------------------------------- > > > > No virus found in this incoming message. > > Checked by AVG Free Edition. > > Version: 7.5.467 / Virus Database: 269.6.4/790 - Release Date: > 5/5/2007 10:34 AM > > > > [Non-text portions of this message have been removed] > > |
