Miliage Issue
05-05-2007, 03:37
Miliage Issue
My old coach has about 150,000 miles on it and it still runs like a
champ. I was wondering if these older Wanderlodges (1978)if the Pm's are kept up and run often wouldn't it be better to buy a Wanderlodge with a little more miles than one that just sat in a barn ? I have not had any trouble with mine and as far putting money into it I can only say that I had new brakes installed and a fresh set of tires installed and that it. I was always told that if you use a vehicle than it just tends to deteriorate from non usage what do you guys think? 150 thousand miles over a 30 years is only 5,000 a year and that's not much driving. Jon 78 Wanderlodge Bremerton Washington |
05-05-2007, 04:57
Miliage Issue
On 5/5/07, Jon
> > I was always told that if you use a vehicle than it just tends to > deteriorate from non usage what do you guys think? You mean if you "don't use" a vehicle it tends to deteriorate, right? I've found this to be true across the board. One of my other toys is an '81 DeLorean; when they sit and don't get used, as many do, they rot. I'm sure the same is true of our birds. I, for one, fully intend to use my bid constantly. -Ryan '86 PT-40 8V92 Tri-Cities, WA |
05-05-2007, 05:05
Miliage Issue
I believe in using our coach. I would bet that most people will say it is
better to drive them than letting them sit. I have not had any serious problems with mine in three years of ownership. Yes, new tires. That is PM. Everything else has been elective upgrades except for my stupidity that caused a recent flood. That turns out to be a minor inconvience. Leroy Eckert 1990WB-40"Smoke N Mirrors" Niceville, FL On Panama City Beach ----- Original Message ----- From: Jon To: WanderlodgeForum@yahoogroups.com Sent: Saturday, May 05, 2007 10:37 AM Subject: [WanderlodgeForum] Miliage Issue My old coach has about 150,000 miles on it and it still runs like a champ. I was wondering if these older Wanderlodges (1978)if the Pm's are kept up and run often wouldn't it be better to buy a Wanderlodge with a little more miles than one that just sat in a barn ? I have not had any trouble with mine and as far putting money into it I can only say that I had new brakes installed and a fresh set of tires installed and that it. I was always told that if you use a vehicle than it just tends to deteriorate from non usage what do you guys think? 150 thousand miles over a 30 years is only 5,000 a year and that's not much driving. Jon 78 Wanderlodge Bremerton Washington [Non-text portions of this message have been removed] |
05-05-2007, 06:54
Miliage Issue
I have over 300,000 miles on my bird. She runs great, needs a paint job, but
I can live with that for a while. i love it when folks pass you and give you a thumbs up. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
05-05-2007, 10:09
Miliage Issue
Jon,
Condition, maintenance and use are the most important factors in how trouble-free your coach will be. Knowing people who've bought new coaches over the past 15 years, I can tell you they spend just as much time in the shop as anyone else, only they don't have to pay for the work. If a coach has been allowed to just sit outside, I think that's the hardest. It's getting condensation inside and UV damage outside, not to mention minor leaks around ceiling vents and windows that dry out before they can be detected. A coach that's been sheltered from water and sun exposure..and plugged in is probably better. Maintenance can be detected not only by paperwork and records but also, look at their car, house and garage. They can provide clues as to how careful they are about maintaining things in general. Frequent use is not a problem. In fact, frequent use ensures that little problems are usually detected and fixed routinely. Hard use may be an issue for the drive train, brakes and suspension. There's a difference between towing a Saturn and a 4-horse trailer. And there's really no way I know of to know how hard a coach has been driven. Maybe other have some ideas on that. Brad Barton 00LXiDFW bbartonwx@... >From: "Jon" >Reply-To: WanderlodgeForum@yahoogroups.com >To: WanderlodgeForum@yahoogroups.com >Subject: [WanderlodgeForum] Miliage Issue >Date: Sat, 05 May 2007 15:37:07 -0000 > >My old coach has about 150,000 miles on it and it still runs like a >champ. I was wondering if these older Wanderlodges (1978)if the Pm's >are kept up and run often wouldn't it be better to buy a Wanderlodge >with a little more miles than one that just sat in a barn ? > >I have not had any trouble with mine and as far putting money into it I >can only say that I had new brakes installed and a fresh set of tires >installed and that it. > >I was always told that if you use a vehicle than it just tends to >deteriorate from non usage what do you guys think? > >150 thousand miles over a 30 years is only 5,000 a year and that's not >much driving. > >Jon >78 Wanderlodge >Bremerton Washington > _________________________________________________________________ Need a break? Find your escape route with Live Search Maps. http://maps.live.com/default.aspx?ss=Res...=33.8\ 32922~-117.915659&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene=1118863&encType=\ 1&FORM=MGAC01 |
