PressurePro Questions
05-05-2007, 05:32
Those that have the PressurePro system installed on your 'Bird. What is
your system configuration, are you using the cabled antenna, no antenna,
something else? Any issues with the control module receiving the toad
signals.
Curt Sprenger
Anaheim Hills, Calif.
05-05-2007, 06:16
Curt,
The system that I'm ordering from Stephen has the optional RV ECHO
REPEATER;
http://www.doranmfg.com/cgi-bin/gzpstore.pl?
user_action=detail&catalogno=7007
The basic system will be this model, but without the DORAN name on it;
user_action=detail&catalogno=RV7008
I'm only getting eight sensors, as I have CrossFires on my rear duals
and I haven't contacted CrossFire about using the sensors on them,
but if that wont work I will have two spare sensors, or I can place
them on two of my trailer spare tires, that way I will have at least
6 of my ten tires on the ground monitored and that is more than I
have now. I prefer using the CrossFires on the rear duals, rather
than removing them.
"REMEMBER SEPTEMBER 11, 2001"
John Finn
'82 35FCRB
BLUEBIRD WANDERLODGE
TO VISIT THE "FINN'S INN EXPRESS" REMODELING ADVENTURE
GO TO;
http://www.pbase.com/image/24977457
HOPKINS, SOUTH CAROLINA
What is
antenna,
toad
> signals.
> Curt Sprenger
05-05-2007, 10:46
I have about 40K miles with a PressurePro system and love it. I have a
M380 and tow a Honda CR-V. I was not able to get reliable readings on
the rear tires on the tow using the standard antenna. I installed the
cabled antenna inside the coach about 2/3 of the way back. I works
very reliably now. I preferred to mount the antenna inside the coach
to avoid road hazards with the antenna mounted under the coach. I am
sure there are many other options but this works well for me.
Marv
2004 M380
Ocean Shores, WA
is
antenna,
> signals.
> Curt Sprenger
05-05-2007, 11:33
Hey i never thought of that mounting under the coach
no more holes in the roof plenty in floor to use
Thanaks for the heads up
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "Marv & Jean"
> Marv
> 2004 M380
> Ocean Shores, WA
> is
> antenna,
> > signals.
> > Curt Sprenger
