AC panel designations
05-07-2007, 10:00
Art- your battery heaters are probably 99% removed. The block heater, with a
switch in the rear closet is located on the curb side of the engine. Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
05-07-2007, 13:09
I've been crawling all over my new purchase for the last two weeks
verifying that everything works ( I was assured that was so). So far everthing works does work. The only inconsistancy I've found is several of the AC circuit breakers are mis-labled. I've been able to track most of them down and properly label them. What is eluding me is the location of the engine block heater and the battery heater. The only thing I know is that the breakers are mis-marked.I ne4es to find out the location of these heaters so I can trace them back to the AC panel using a multimeter. Anybody--- jump in. Art Weatherly Riverside Ca. '85 PT 36 (6V92) |
05-07-2007, 13:28
Art,
The switches that control the on/off for the block heater and the battery heater are located in one of the rear closets if your 'Bird is set up the same as ours. If you want, stop by the house and we'll take a look your panel and my panel. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. amweath wrote: > I've been crawling all over my new purchase for the last two weeks > verifying that everything works ( I was assured that was so). So far > everthing works does work. The only inconsistancy I've found is several > of the AC circuit breakers are mis-labled. I've been able to track > most of them down and properly label them. What is eluding me is the > location of the engine block heater and the battery heater. The only > thing I know is that the breakers are mis-marked.I ne4es to find out > the location of these heaters so I can trace them back to the AC panel > using a multimeter. Anybody--- jump in. > > Art Weatherly > Riverside Ca. > '85 PT 36 (6V92) > > |
05-08-2007, 02:47
Curt
I have three switches in one of the rear closets. One is marked "hot water heater", the other two are unmarked. Perhaps those are the two I'm looking for. Art Weatherly Riverside Ca. '85 PT 36 ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Monday, May 07, 2007 6:28 PM Subject: [SPAM] Re: [WanderlodgeForum] AC panel designations Art, The switches that control the on/off for the block heater and the battery heater are located in one of the rear closets if your 'Bird is set up the same as ours. If you want, stop by the house and we'll take a look your panel and my panel. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. amweath wrote: > I've been crawling all over my new purchase for the last two weeks > verifying that everything works ( I was assured that was so). So far > everthing works does work. The only inconsistancy I've found is several > of the AC circuit breakers are mis-labled. I've been able to track > most of them down and properly label them. What is eluding me is the > location of the engine block heater and the battery heater. The only > thing I know is that the breakers are mis-marked.I ne4es to find out > the location of these heaters so I can trace them back to the AC panel > using a multimeter. Anybody--- jump in. > > Art Weatherly > Riverside Ca. > '85 PT 36 (6V92) > > [Non-text portions of this message have been removed] |
05-08-2007, 03:02
Art,
Top switch is Water Heater, center is Engine Heater, bottom is Battery Heater. I opened up the battery heater wiring box located in the engine bay, disconnected the wires for the battery heaters and put the heater system in the trash, they were in bad shape. I then install a 110V outlet in that box, flip up cover over the outlet. Move over one closet and I believe you will find a couple more switches, small/black, that control the bedroom chassis heater. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Art Weatherly wrote: > Curt > > I have three switches in one of the rear closets. One is marked "hot > water heater", the other two are unmarked. Perhaps those are the two > I'm looking for. > > Art Weatherly > Riverside Ca. > '85 PT 36 > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, May 07, 2007 6:28 PM > Subject: [SPAM] Re: [WanderlodgeForum] AC panel designations > > Art, > The switches that control the on/off for the block heater and the > battery heater are located in one of the rear closets if your 'Bird is > set up the same as ours. If you want, stop by the house and we'll take a > look your panel and my panel. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > amweath wrote: > > > I've been crawling all over my new purchase for the last two weeks > > verifying that everything works ( I was assured that was so). So far > > everthing works does work. The only inconsistancy I've found is several > > of the AC circuit breakers are mis-labled. I've been able to track > > most of them down and properly label them. What is eluding me is the > > location of the engine block heater and the battery heater. The only > > thing I know is that the breakers are mis-marked.I ne4es to find out > > the location of these heaters so I can trace them back to the AC panel > > using a multimeter. Anybody--- jump in. > > > > Art Weatherly > > Riverside Ca. > > '85 PT 36 (6V92) > > > > > > [Non-text portions of this message have been removed] > > |
05-08-2007, 12:54
Hi Art,
What Curt says is true. Mine is set up the same way. Bob Lawrence 84 PT36 Tacoma, Wa. > I have three switches in one of the rear closets. One is marked "hot water heater", the other two are unmarked. Perhaps those are the two I'm looking for. > > Art Weatherly > Riverside Ca. > '85 PT 36 > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, May 07, 2007 6:28 PM > Subject: [SPAM] Re: [WanderlodgeForum] AC panel designations > > > Art, > The switches that control the on/off for the block heater and the > battery heater are located in one of the rear closets if your 'Bird is > set up the same as ours. If you want, stop by the house and we'll take a > look your panel and my panel. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > amweath wrote: > > > I've been crawling all over my new purchase for the last two weeks > > verifying that everything works ( I was assured that was so). So far > > everthing works does work. The only inconsistancy I've found is several > > of the AC circuit breakers are mis-labled. I've been able to track > > most of them down and properly label them. What is eluding me is the > > location of the engine block heater and the battery heater. The only > > thing I know is that the breakers are mis-marked.I ne4es to find out > > the location of these heaters so I can trace them back to the AC panel > > using a multimeter. Anybody--- jump in. > > > > Art Weatherly > > Riverside Ca. > > '85 PT 36 (6V92) > > > > > > > > > > [Non-text portions of this message have been removed] > |
05-10-2007, 13:19
Curt
I do indeed have those 3 switches in the rear curbside closet. Traced them back to the AC panel today. They went where they were marked except the water heater. I have no switches in the other rear closets. Ther motor/generator and chargers have been replaced by an 2500 watt inverter/charger bolted to the rear center closet wall. I'm guessing they (?) rearanged some of the circuits to balance the inverter load. Art Weatherly '85 PT36 ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, May 08, 2007 8:02 AM Subject: [SPAM] Re: [SPAM] Re: [WanderlodgeForum] AC panel designations Art, Top switch is Water Heater, center is Engine Heater, bottom is Battery Heater. I opened up the battery heater wiring box located in the engine bay, disconnected the wires for the battery heaters and put the heater system in the trash, they were in bad shape. I then install a 110V outlet in that box, flip up cover over the outlet. Move over one closet and I believe you will find a couple more switches, small/black, that control the bedroom chassis heater. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Art Weatherly wrote: > Curt > > I have three switches in one of the rear closets. One is marked "hot > water heater", the other two are unmarked. Perhaps those are the two > I'm looking for. > > Art Weatherly > Riverside Ca. > '85 PT 36 > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, May 07, 2007 6:28 PM > Subject: [SPAM] Re: [WanderlodgeForum] AC panel designations > > Art, > The switches that control the on/off for the block heater and the > battery heater are located in one of the rear closets if your 'Bird is > set up the same as ours. If you want, stop by the house and we'll take a > look your panel and my panel. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > amweath wrote: > > > I've been crawling all over my new purchase for the last two weeks > > verifying that everything works ( I was assured that was so). So far > > everthing works does work. The only inconsistancy I've found is several > > of the AC circuit breakers are mis-labled. I've been able to track > > most of them down and properly label them. What is eluding me is the > > location of the engine block heater and the battery heater. The only > > thing I know is that the breakers are mis-marked.I ne4es to find out > > the location of these heaters so I can trace them back to the AC panel > > using a multimeter. Anybody--- jump in. > > > > Art Weatherly > > Riverside Ca. > > '85 PT 36 (6V92) > > > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] |
05-10-2007, 23:13
From: Art Weatherly To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 10, 2007 8:19 PM Subject: Re: [SPAM] Re: [SPAM] Re: [WanderlodgeForum] AC panel designations Hi Art On mine the switch for water heater is the middle one in the back curb side closets.You can also locate it buy connecting a A/C volt meter to the water heater 110 volt wiring and by turning your switches/breaker on and off you will fined it. Bob Loomas 1985 PT 36 Curt I do indeed have those 3 switches in the rear curbside closet. Traced them back to the AC panel today. They went where they were marked except the water heater. I have no switches in the other rear closets. Ther motor/generator and chargers have been replaced by an 2500 watt inverter/charger bolted to the rear center closet wall. I'm guessing they (?) rearanged some of the circuits to balance the inverter load. Art Weatherly '85 PT36 ----- Original Message ----- From: Curt Sprenger To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, May 08, 2007 8:02 AM Subject: [SPAM] Re: [SPAM] Re: [WanderlodgeForum] AC panel designations Art, Top switch is Water Heater, center is Engine Heater, bottom is Battery Heater. I opened up the battery heater wiring box located in the engine bay, disconnected the wires for the battery heaters and put the heater system in the trash, they were in bad shape. I then install a 110V outlet in that box, flip up cover over the outlet. Move over one closet and I believe you will find a couple more switches, small/black, that control the bedroom chassis heater. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. Art Weatherly wrote: > Curt > > I have three switches in one of the rear closets. One is marked "hot > water heater", the other two are unmarked. Perhaps those are the two > I'm looking for. > > Art Weatherly > Riverside Ca. > '85 PT 36 > ----- Original Message ----- > From: Curt Sprenger > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, May 07, 2007 6:28 PM > Subject: [SPAM] Re: [WanderlodgeForum] AC panel designations > > Art, > The switches that control the on/off for the block heater and the > battery heater are located in one of the rear closets if your 'Bird is > set up the same as ours. If you want, stop by the house and we'll take a > look your panel and my panel. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > amweath wrote: > > > I've been crawling all over my new purchase for the last two weeks > > verifying that everything works ( I was assured that was so). So far > > everthing works does work. The only inconsistancy I've found is several > > of the AC circuit breakers are mis-labled. I've been able to track > > most of them down and properly label them. What is eluding me is the > > location of the engine block heater and the battery heater. The only > > thing I know is that the breakers are mis-marked.I ne4es to find out > > the location of these heaters so I can trace them back to the AC panel > > using a multimeter. Anybody--- jump in. > > > > Art Weatherly > > Riverside Ca. > > '85 PT 36 (6V92) > > > > > > [Non-text portions of this message have been removed] > > [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
