Cruise control wiring on 82 Fc
06-03-2007, 04:00
Kerry- did you find all the cruise control components behind the battery
compartment close to the engine? Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
06-03-2007, 07:08
Kerry- while lying on the ground under you battery compartment, there is
about a 3 inch wide black metal panel. That panel is located vertical and right behind the battery compartment. 4 screws hold the cover to that and when those are removed, your cruise control mechanism is there Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
06-03-2007, 07:52
I'm about to replace the vacuum cruise control on my 82 FC with a Rostra
electric unit due to failure of the vacuum generator. There are five wires going to the vacuum cruise control actuator on the engine. Green, white, black, light brown, dark brown. Does anyone who what each wire does? The green is obviously a ground. Where is the brain of the current cruise control and does anyone know how to interpret its wiring? I assume the brain is separate from the actuator on the engine. Is that correct? Kerry 82 FC 35 Denver |
06-03-2007, 08:07
No, I haven't found any of them besides the actuator on the engine. Can you
describe their location again? My batteries are on a pull out tray in the front left compartment under the driver's seat area. Are you saying the cruise control brain is in that vicinity? kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Kerry- did you find all the cruise control components behind the battery > compartment close to the engine? > > Ernie Ekberg > 83PT40 > Livingston, Mt > > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
06-03-2007, 13:21
ON my 1983 FC-35 the vacuum pump is behind the the left driving light, there are
two plastic air lines connected to it. re in Ga. 1983 FC-35 > > From: "davidkerryedwards" > Date: 2007/06/03 Sun PM 04:07:30 EDT > To: WanderlodgeForum@yahoogroups.com > Subject: [WanderlodgeForum] Re: Cruise control wiring on 82 Fc > > No, I haven't found any of them besides the actuator on the engine. Can you describe > their location again? My batteries are on a pull out tray in the front left compartment > under the driver's seat area. Are you saying the cruise control brain is in that vicinity? > > kerry > 82 FC 35 > Denver > > > --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > > > Kerry- did you find all the cruise control components behind the battery > > compartment close to the engine? > > > > Ernie Ekberg > > 83PT40 > > Livingston, Mt > > > > > > > > > > ************************************** See what's free at http://www.aol.com. > > > > > > [Non-text portions of this message have been removed] > > > > > > |
06-03-2007, 13:32
That sounds better. I spent a lot of time recently in the battery compartment
replacing the power steering hose and didn't notice anything there. Yes, I am replacing it with a Rostra on the basis of your prior posts about it. How do I tell which wire is which going into the old brain? Should there be a wiring diagram in the bluebox or are they labeled in any way? I'll give you a call. Is your phone number in your profile? I think you sent it to me once when I first purchased the Rostra but now I can't find it. I've looked at your pictures of the retrofit on line. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Chuck Wheeler" > > On our 82 the "brain" was located on above the throttle pedal on the > firewall. All the connections you will need for the new unit will be in the > wiring harness connections to the brain. The harness from the new unit > will be routed to this area then the connections made there. If you are > using a rostra replacement I can help if you need it. Give me a call. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > |
06-03-2007, 15:25
firewall. All the connections you will need for the new unit will be in the wiring harness connections to the brain. The harness from the new unit will be routed to this area then the connections made there. If you are using a rostra replacement I can help if you need it. Give me a call. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of erniecarpet@... Sent: Sunday, June 03, 2007 4:08 PM To: WanderlodgeForum@yahoogroups.com Subject: Re: [WanderlodgeForum] Re: Cruise control wiring on 82 Fc Kerry- while lying on the ground under you battery compartment, there is about a 3 inch wide black metal panel. That panel is located vertical and right behind the battery compartment. 4 screws hold the cover to that and when those are removed, your cruise control mechanism is there Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol. <http://www.aol.com.> com. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
06-03-2007, 15:36
I just got your personal email and answered that. It might be easier if we
talk. - Chuck Wheeler - 82 FC 31 SB Fort Worth, TX _____ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of davidkerryedwards Sent: Sunday, June 03, 2007 6:32 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Re: Cruise control wiring on 82 Fc That sounds better. I spent a lot of time recently in the battery compartment replacing the power steering hose and didn't notice anything there. Yes, I am replacing it with a Rostra on the basis of your prior posts about it. How do I tell which wire is which going into the old brain? Should there be a wiring diagram in the bluebox or are they labeled in any way? I'll give you a call. Is your phone number in your profile? I think you sent it to me once when I first purchased the Rostra but now I can't find it. I've looked at your pictures of the retrofit on line. Kerry 82 Fc 35 Denver --- In WanderlodgeForum@ yahoogroups.com, "Chuck Wheeler" > > On our 82 the "brain" was located on above the throttle pedal on the > firewall. All the connections you will need for the new unit will be in the > wiring harness connections to the brain. The harness from the new unit > will be routed to this area then the connections made there. If you are > using a rostra replacement I can help if you need it. Give me a call. > > > > - Chuck Wheeler - > > 82 FC 31 SB > > Fort Worth, TX > > [Non-text portions of this message have been removed] |
06-04-2007, 06:30
Found the cruise control brain this morning. It's was mounted directly in front
of the driver's left knee. Got the old vacuum system removed and the new brain/actuator installed in the engine compartment (but not hooked up to the throttle yet). All I need to do now is hook up the wiring. I'll talk to Chuck Wheeler tonight to confirm his technique. There should be a plug in connector coming from the turn signal stalk cruise switch which should plug directly into the wiring for the new unit. I'll need to find the speed signal wires coming from the sensor on the rear wheel, hook up to the brake switch, get 12 volts and it should be ready to go. I doesn't look very simple to find the stalk switch wires or the speed sensor wires. i have lots of wiring diagrams in my Bluebox, but nothing on the cruise wiring that i could find. Kerry 92 Fc 35 Denver |
