Installing new guage.
06-09-2007, 12:04
Post: #31
Recently My Happy Mouse trigger finger sent a few replys direct to an
e-mail address rather than to the forum posting. So, I hope this answer to Leroy can help someone, This has worked on our 88 FC using the replacement BB/Teleflex oil temp gage # 9153278. This sensor will work correctly with the oil temp gage.It has several different bushings with various thread sizes to fit the engine block ports. Stewart-Warner part # SW280 EE-F Available at a big truck parts store or I purchased from South West Brake, 248-486-9866 about $15 to 20.00. I do not know about the water temp gages or sensors. And Yes, the bezels can be exchanged with the new gage to match the other dash gages. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Ok. Jim in FL and Bill in MI > I received the gauges from BB. The engine oil temp gauge is Teleflex pn 9153278 and is a substitute for the original gauge. The index begins with 140 and the bezel is different. I believe the original bezel can be placed on this gauge but I have decided to paint the elevated ring silver with a paint stick. The genset water temp gauge has the same index (from memory I will verify this w/e) and the same bezel as the engine oil temp gauge. The genset oil pressure gauge has the same index and the same bezel as the original gauge. Go figure that out. All of them have new Teleflex pn's. The faces are virtually identical. > BB sent me a tranny sender for the engine oil pressure gauge. I will put that on the tranny. > Jim, based on your post should I call Teleflex and order the sender for the new configuration gauge? > Thanks; > Leroy Eckert > 1990WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: jim riordan > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, June 05, 2007 8:16 AM > Subject: Re: [WanderlodgeForum] Installing new guage. > > > Leroy, > > I just replaced many flaky guages on my coach. I got the new guage from BB. the indexing was different and better. I called BB (earl) to get the correct (new) sending unit he sent me the wrong one! an 028 I then called teleflex Joe Federsal and spoke to him he sent the correct one an 032, i called earl and told him that he needed to check with Teleflex about stocking the correct sending unit for this guage. The guage is better because it is more presise than the old one. > Jim Riordan > 88 WBWL XXV > > Leroy Eckert > Thanks Howard: > I'll give them a call. > Leroy Eckert > 1990WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: truitt44@... > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, June 04, 2007 9:25 AM > Subject: [WanderlodgeForum] Installing new guage. > > Leroy, > Contact Chuck at APT Instruments in Bloomington, Mn. about servicing Teleflex gauges 952-881-7095. > Howard Truitt > Camilla, Ga. > 86 PT40 > > > > > From: "Leroy Eckert" > > Date: 2007/06/04 Mon AM 09:59:05 EDT > > To: > > Subject: Re: [WanderlodgeForum] Re: Installing new guage. > > > > > > I want to pass along information I am receiving from Teleflex, Bluebird and other suppliers I e-mailed over the weekend. Oil Temperature gauge 54438 Bluebird part number 3865334 shows to be in stock at Bluebird today. I will see if the indexing is the same when I receive it. According to Teleflex this and other Teleflex gauges Bluebird used are no longer in production and are no longer available if Bluebird does not have inventory. I am replacing 3 flakey gauges now while they are available. > > Steve Birtles and I are searching for an instrument shop to rebuild the original gauges. I would like to keep my bird dash looking original. In the long term that may be difficult to do. > > > > Leroy Eckert > > 1990WB-40"Smoke N Mirrors" > > Niceville, FL > > > > ----- Original Message ----- > > From: pattypape > > To: WanderlodgeForum@yahoogroups.com > > Sent: Saturday, May 12, 2007 9:36 AM > > Subject: [WanderlodgeForum] Re: Installing new guage. > > > > > > > > Jim, > > > > Yep, that is the correct gage, Teleflex # 9153278. > > > > The BB# 54438 was still a good number, But > > they shipped the updated 9153278 gage , Then the temp would read > > really high, That is why there is a lot of confusion , when > > replacing gages, the sensor must be replaced also. > > I like the new scale for the oil temp,200 to 230 > > Not so good for the rear axle because, it only heats up to about > > 140 to 170. lowest part of the gage. > > > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > > wrote: > > > > > > Thanks, > > > > > > The new guage is not a 54438 Earl said the did not maske it > > anymore. He sent me a "superseded" one the index numbers were > > different. He sent me a new sensor it was for the old type guage it > > was reading 40% high. I called Teleflex spoke to Joe Federsal (great > > help) he sent me the correct sensor for the guage that I got from > > earl, everything seems to work now. This new guage 9153278 is > > improved in that it first register point is at 140 rather than 100, > > top is 320 like the old one. the end result is that the gauge will > > provide more accurate readings in the operational range than the old > > one. I hope! > > > > > > > > > Jim RIordan > > > 88 WBWL XXV > > > Stuart, Fl. > > > pattypape > > > > > > > > > Jim, > > > > > > I replaced both oil temp gages on our 88 FC ( 3208 oil and rear > > axle > > > temps) BB gage part number 54438, It is a Teleflex gage. > > > > > > If this is your gage the temp sensor is a Stewart-Warner, part > > > number 280EEF . It is available at truck parts stores. It has > > > several threaded bushings for all thread sizes, One will match the > > > original threads. BB did not have the correct sensor. > > > > > > Bill 88 FC Michigan > > > > > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > > > wrote: > > > > > > > > I have just replace my oil temp guage. I got it from BB and it is > > > indexed differently from the original one. I needed to get a new > > temp > > > sending switch also... > > > > > > > > Jim Riordan > > > > 88 WBWL XXV > > > > Stuart, Fl. > > > > > > > > "Ralph L. Fullenwider" > > > > Hi Art: > > > > > > > > **CAUTION** **CAUTION** > > > > > > > > Remove the 4 bottom out side covers of the lower dash. If the > > lower > > > dash > > > > has been out before then it should lift up from the front edge > > and > > > slip > > > > forward a little. If it has not been out before then on the left > > > side of > > > > the lower dash, under one of the blank covers, will be a screw > > that > > > has to > > > > come out. > > > > > > > > Now, with the lower dash panel slid forward, remove the cb mic > > from > > > the > > > > holder and take the long screw out that holds the cb mic holder. > > > Now the > > > > upper lower dash should be free on that side and if it has been > > > removed it > > > > will probably be free to tilt forward. If it has not been out > > > before then > > > > you need a looooong phillips screwdriver, hold the right side of > > > the upper > > > > lower dash out and reach in with the long phillips and un screw > > the > > > far > > > > left L bracket. In the bottom center of the upper lower dash, > > after > > > the > > > > lower panel is moved forward you should see a screw that needs to > > > come out > > > > as well. Now your upper lower dash panel should be free to tilt > > > forward. > > > > **CAUTION** Do NOT force it, if it won't come out enough to > > replace > > > the > > > > gauge, find what is holding it. I cannot stress **CAUTION** > > enough > > > on this. > > > > > > > > While your in there, remove the light sockets with the lamps from > > > the other > > > > gauges and clean or replace them. > > > > > > > > Your going to find a "rats nest" of wiring under and behind both > > > panels. > > > > Remember if you drill, spindle or pierce any of those panels, > > they > > > are shot > > > > and cannot be brought back. Use only holes provided for screws > > and > > > such. > > > > > > > > Good luck > > > > > > > > Safe travels, > > > > > > > > Ralph and Charolette Fullenwider > > > > 84FC35 > > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > > > At 06:44 PM 5/10/2007 +0000, you wrote: > > > > >I have recieved a new engine oil temp guage from the fellow I > > > bought > > > > >my coach from. Now to install it. The guage is on the verticle > > > part of > > > > >the dash panel.Has anyone been into that panel? Any advise will > > be > > > > >better than me going in there blind! > > > > > > > > > > > > > > >Art Weatherly > > > > >Riverside Ca. > > > > >'85 PT36 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > > Moody friends. Drama queens. Your life? Nope! - their life, your > > > story. > > > > Play Sims Stories at Yahoo! Games. > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > Be a PS3 game guru. > > > Get your game face on with the latest PS3 news and previews at > > Yahoo! Games. > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > > --------------------------------- > Yahoo! oneSearch: Finally, mobile search that gives answers, not web links. > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > |
06-09-2007, 13:52
Post: #32
Thanks Bill. I received your e-mail and answered it. You didn't receive my
response so here it is. Seems like the electronic world doesn't always get rdone. They gotta dig up some more cable to keep it going. I e-mailed the company and they do not stock the parts. I suppose I can order them. I also contacted Teleflex and have a list of senders by part number and ID that will work . I e-mailed Earl at BB and have not heard back. I expect to hear form him on Monday. I have found I get a very rapid response from BB via e-mail. One would concluded that senders would be available for the gauges. What I have determined is this. The International Line is shipped primarily to manufacturers. Boats, motorhomes etc. That is the market. I certainly appreciate your help. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Saturday, June 09, 2007 7:04 PM Subject: [WanderlodgeForum] Re: Installing new guage. Recently My Happy Mouse trigger finger sent a few replys direct to an e-mail address rather than to the forum posting. So, I hope this answer to Leroy can help someone, This has worked on our 88 FC using the replacement BB/Teleflex oil temp gage # 9153278. This sensor will work correctly with the oil temp gage.It has several different bushings with various thread sizes to fit the engine block ports. Stewart-Warner part # SW280 EE-F Available at a big truck parts store or I purchased from South West Brake, 248-486-9866 about $15 to 20.00. I do not know about the water temp gages or sensors. And Yes, the bezels can be exchanged with the new gage to match the other dash gages. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Ok. Jim in FL and Bill in MI > I received the gauges from BB. The engine oil temp gauge is Teleflex pn 9153278 and is a substitute for the original gauge. The index begins with 140 and the bezel is different. I believe the original bezel can be placed on this gauge but I have decided to paint the elevated ring silver with a paint stick. The genset water temp gauge has the same index (from memory I will verify this w/e) and the same bezel as the engine oil temp gauge. The genset oil pressure gauge has the same index and the same bezel as the original gauge. Go figure that out. All of them have new Teleflex pn's. The faces are virtually identical. > BB sent me a tranny sender for the engine oil pressure gauge. I will put that on the tranny. > Jim, based on your post should I call Teleflex and order the sender for the new configuration gauge? > Thanks; > Leroy Eckert > 1990WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: jim riordan > To: WanderlodgeForum@yahoogroups.com > Sent: Tuesday, June 05, 2007 8:16 AM > Subject: Re: [WanderlodgeForum] Installing new guage. > > > Leroy, > > I just replaced many flaky guages on my coach. I got the new guage from BB. the indexing was different and better. I called BB (earl) to get the correct (new) sending unit he sent me the wrong one! an 028 I then called teleflex Joe Federsal and spoke to him he sent the correct one an 032, i called earl and told him that he needed to check with Teleflex about stocking the correct sending unit for this guage. The guage is better because it is more presise than the old one. > Jim Riordan > 88 WBWL XXV > > Leroy Eckert > Thanks Howard: > I'll give them a call. > Leroy Eckert > 1990WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: truitt44@... > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, June 04, 2007 9:25 AM > Subject: [WanderlodgeForum] Installing new guage. > > Leroy, > Contact Chuck at APT Instruments in Bloomington, Mn. about servicing Teleflex gauges 952-881-7095. > Howard Truitt > Camilla, Ga. > 86 PT40 > > > > > From: "Leroy Eckert" > > Date: 2007/06/04 Mon AM 09:59:05 EDT > > To: > > Subject: Re: [WanderlodgeForum] Re: Installing new guage. > > > > > > I want to pass along information I am receiving from Teleflex, Bluebird and other suppliers I e-mailed over the weekend. Oil Temperature gauge 54438 Bluebird part number 3865334 shows to be in stock at Bluebird today. I will see if the indexing is the same when I receive it. According to Teleflex this and other Teleflex gauges Bluebird used are no longer in production and are no longer available if Bluebird does not have inventory. I am replacing 3 flakey gauges now while they are available. > > Steve Birtles and I are searching for an instrument shop to rebuild the original gauges. I would like to keep my bird dash looking original. In the long term that may be difficult to do. > > > > Leroy Eckert > > 1990WB-40"Smoke N Mirrors" > > Niceville, FL > > > > ----- Original Message ----- > > From: pattypape > > To: WanderlodgeForum@yahoogroups.com > > Sent: Saturday, May 12, 2007 9:36 AM > > Subject: [WanderlodgeForum] Re: Installing new guage. > > > > > > > > Jim, > > > > Yep, that is the correct gage, Teleflex # 9153278. > > > > The BB# 54438 was still a good number, But > > they shipped the updated 9153278 gage , Then the temp would read > > really high, That is why there is a lot of confusion , when > > replacing gages, the sensor must be replaced also. > > I like the new scale for the oil temp,200 to 230 > > Not so good for the rear axle because, it only heats up to about > > 140 to 170. lowest part of the gage. > > > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > > wrote: > > > > > > Thanks, > > > > > > The new guage is not a 54438 Earl said the did not maske it > > anymore. He sent me a "superseded" one the index numbers were > > different. He sent me a new sensor it was for the old type guage it > > was reading 40% high. I called Teleflex spoke to Joe Federsal (great > > help) he sent me the correct sensor for the guage that I got from > > earl, everything seems to work now. This new guage 9153278 is > > improved in that it first register point is at 140 rather than 100, > > top is 320 like the old one. the end result is that the gauge will > > provide more accurate readings in the operational range than the old > > one. I hope! > > > > > > > > > Jim RIordan > > > 88 WBWL XXV > > > Stuart, Fl. > > > pattypape > > > > > > > > > Jim, > > > > > > I replaced both oil temp gages on our 88 FC ( 3208 oil and rear > > axle > > > temps) BB gage part number 54438, It is a Teleflex gage. > > > > > > If this is your gage the temp sensor is a Stewart-Warner, part > > > number 280EEF . It is available at truck parts stores. It has > > > several threaded bushings for all thread sizes, One will match the > > > original threads. BB did not have the correct sensor. > > > > > > Bill 88 FC Michigan > > > > > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > > > wrote: > > > > > > > > I have just replace my oil temp guage. I got it from BB and it is > > > indexed differently from the original one. I needed to get a new > > temp > > > sending switch also... > > > > > > > > Jim Riordan > > > > 88 WBWL XXV > > > > Stuart, Fl. > > > > > > > > "Ralph L. Fullenwider" > > > > Hi Art: > > > > > > > > **CAUTION** **CAUTION** > > > > > > > > Remove the 4 bottom out side covers of the lower dash. If the > > lower > > > dash > > > > has been out before then it should lift up from the front edge > > and > > > slip > > > > forward a little. If it has not been out before then on the left > > > side of > > > > the lower dash, under one of the blank covers, will be a screw > > that > > > has to > > > > come out. > > > > > > > > Now, with the lower dash panel slid forward, remove the cb mic > > from > > > the > > > > holder and take the long screw out that holds the cb mic holder. > > > Now the > > > > upper lower dash should be free on that side and if it has been > > > removed it > > > > will probably be free to tilt forward. If it has not been out > > > before then > > > > you need a looooong phillips screwdriver, hold the right side of > > > the upper > > > > lower dash out and reach in with the long phillips and un screw > > the > > > far > > > > left L bracket. In the bottom center of the upper lower dash, > > after > > > the > > > > lower panel is moved forward you should see a screw that needs to > > > come out > > > > as well. Now your upper lower dash panel should be free to tilt > > > forward. > > > > **CAUTION** Do NOT force it, if it won't come out enough to > > replace > > > the > > > > gauge, find what is holding it. I cannot stress **CAUTION** > > enough > > > on this. > > > > > > > > While your in there, remove the light sockets with the lamps from > > > the other > > > > gauges and clean or replace them. > > > > > > > > Your going to find a "rats nest" of wiring under and behind both > > > panels. > > > > Remember if you drill, spindle or pierce any of those panels, > > they > > > are shot > > > > and cannot be brought back. Use only holes provided for screws > > and > > > such. > > > > > > > > Good luck > > > > > > > > Safe travels, > > > > > > > > Ralph and Charolette Fullenwider > > > > 84FC35 > > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > > > At 06:44 PM 5/10/2007 +0000, you wrote: > > > > >I have recieved a new engine oil temp guage from the fellow I > > > bought > > > > >my coach from. Now to install it. The guage is on the verticle > > > part of > > > > >the dash panel.Has anyone been into that panel? Any advise will > > be > > > > >better than me going in there blind! > > > > > > > > > > > > > > >Art Weatherly > > > > >Riverside Ca. > > > > >'85 PT36 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > > Moody friends. Drama queens. Your life? Nope! - their life, your > > > story. > > > > Play Sims Stories at Yahoo! Games. > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > Be a PS3 game guru. > > > Get your game face on with the latest PS3 news and previews at > > Yahoo! Games. > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > > --------------------------------- > Yahoo! oneSearch: Finally, mobile search that gives answers, not web links. > > [Non-text portions of this message have been removed] > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
06-09-2007, 14:06
Post: #33
Haha , Ernie
Ya can't turn your clock back , not the speedo/odometer nor the hour meter. Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, erniecarpet@... wrote: > > Bill- How come our fingers get too fast- too fat when we age? It seems that > my laptop keys are closer together then in years past. > > Ernie Ekberg > 83PT40 > Livingston, Mt > ------expecting Mike Hoehnstein to call on his arrival in Livingston, Mt > > > > ************************************** See what's free at http://www.aol.com. > > > [Non-text portions of this message have been removed] > |
06-09-2007, 14:13
Post: #34
Leroy,
We are learning, I have not found a dealer that stocks the Teleflex gages, West Marine will special order ,But your part numbers must be correct, or you may own the mistake. BB has gages , but as of my last experiences their sensors do not match. So it is best to get the correct part numbers from Joe at Teleflex Marine tech support. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Thanks Bill. I received your e-mail and answered it. You didn't receive my response so here it is. Seems like the electronicworld doesn't always get r done. They gotta dig up some more cable to keep it going. > I e-mailed the company and they do not stock the parts. I suppose I can order them. I also contacted Teleflex and have a list of senders by part number and ID that will work . I e-mailed Earl at BB and have not heard back. I expect to hear form him on Monday. I have found I get a very rapid response from BB via e-mail. > One would concluded that senders would be available for the gauges. What I have determined is this. The International Line is shipped primarily to manufacturers. Boats, motorhomes etc. That is the market. > I certainly appreciate your help. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: pattypape > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, June 09, 2007 7:04 PM > Subject: [WanderlodgeForum] Re: Installing new guage. > > > > Recently My Happy Mouse trigger finger sent a few replys direct to an > e-mail address rather than to the forum posting. > > So, I hope this answer to Leroy can help someone, This has worked on > our 88 FC using the replacement BB/Teleflex oil temp gage # 9153278. > > This sensor will work correctly with the oil temp gage.It has > several different bushings with various thread sizes to fit the > engine block ports. Stewart-Warner part # SW280 EE-F > Available at a big truck parts store or I purchased from South West > Brake, 248-486-9866 about $15 to 20.00. > I do not know about the water temp gages or sensors. And Yes, the > bezels can be exchanged with the new gage to match the other dash > gages. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > Ok. Jim in FL and Bill in MI > > I received the gauges from BB. The engine oil temp gauge is > Teleflex pn 9153278 and is a substitute for the original gauge. The > index begins with 140 and the bezel is different. I believe the > original bezel can be placed on this gauge but I have decided to > paint the elevated ring silver with a paint stick. The genset water > temp gauge has the same index (from memory I will verify this w/e) > and the same bezel as the engine oil temp gauge. The genset oil > pressure gauge has the same index and the same bezel as the original > gauge. Go figure that out. All of them have new Teleflex pn's. The > faces are virtually identical. > > BB sent me a tranny sender for the engine oil pressure gauge. I > will put that on the tranny. > > Jim, based on your post should I call Teleflex and order the sender > for the new configuration gauge? > > Thanks; > > Leroy Eckert > > 1990WB-40"Smoke N Mirrors" > > Niceville, FL > > ----- Original Message ----- > > From: jim riordan > > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, June 05, 2007 8:16 AM > > Subject: Re: [WanderlodgeForum] Installing new guage. > > > > > > Leroy, > > > > I just replaced many flaky guages on my coach. I got the new > guage from BB. the indexing was different and better. I called BB > (earl) to get the correct (new) sending unit he sent me the wrong one! > an 028 I then called teleflex Joe Federsal and spoke to him he sent > the correct one an 032, i called earl and told him that he needed to > check with Teleflex about stocking the correct sending unit for this > guage. The guage is better because it is more presise than the old > one. > > Jim Riordan > > 88 WBWL XXV > > > > Leroy Eckert > > Thanks Howard: > > I'll give them a call. > > Leroy Eckert > > 1990WB-40"Smoke N Mirrors" > > Niceville, FL > > ----- Original Message ----- > > From: truitt44@ > > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, June 04, 2007 9:25 AM > > Subject: [WanderlodgeForum] Installing new guage. > > > > Leroy, > > Contact Chuck at APT Instruments in Bloomington, Mn. about > servicing Teleflex gauges 952-881-7095. > > Howard Truitt > > Camilla, Ga. > > 86 PT40 > > > > > > > > From: "Leroy Eckert" > > > Date: 2007/06/04 Mon AM 09:59:05 EDT > > > To: > > > Subject: Re: [WanderlodgeForum] Re: Installing new guage. > > > > > > > > > I want to pass along information I am receiving from Teleflex, > Bluebird and other suppliers I e-mailed over the weekend. Oil > Temperature gauge 54438 Bluebird part number 3865334 shows to be in > stock at Bluebird today. I will see if the indexing is the same when > I receive it. According to Teleflex this and other Teleflex gauges > Bluebird used are no longer in production and are no longer available > if Bluebird does not have inventory. I am replacing 3 flakey gauges > now while they are available. > > > Steve Birtles and I are searching for an instrument shop to > rebuild the original gauges. I would like to keep my bird dash > looking original. In the long term that may be difficult to do. > > > > > > Leroy Eckert > > > 1990WB-40"Smoke N Mirrors" > > > Niceville, FL > > > > > > ----- Original Message ----- > > > From: pattypape > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Saturday, May 12, 2007 9:36 AM > > > Subject: [WanderlodgeForum] Re: Installing new guage. > > > > > > > > > > > > Jim, > > > > > > Yep, that is the correct gage, Teleflex # 9153278. > > > > > > The BB# 54438 was still a good number, But > > > they shipped the updated 9153278 gage , Then the temp would read > > > really high, That is why there is a lot of confusion , when > > > replacing gages, the sensor must be replaced also. > > > I like the new scale for the oil temp,200 to 230 > > > Not so good for the rear axle because, it only heats up to > about > > > 140 to 170. lowest part of the gage. > > > > > > Bill 88 FC Michigan > > > > > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > > > wrote: > > > > > > > > Thanks, > > > > > > > > The new guage is not a 54438 Earl said the did not maske it > > > anymore. He sent me a "superseded" one the index numbers were > > > different. He sent me a new sensor it was for the old type > guage it > > > was reading 40% high. I called Teleflex spoke to Joe Federsal > (great > > > help) he sent me the correct sensor for the guage that I got > from > > > earl, everything seems to work now. This new guage 9153278 is > > > improved in that it first register point is at 140 rather than > 100, > > > top is 320 like the old one. the end result is that the gauge > will > > > provide more accurate readings in the operational range than > the old > > > one. I hope! > > > > > > > > > > > > Jim RIordan > > > > 88 WBWL XXV > > > > Stuart, Fl. > > > > pattypape > > > > > > > > > > > > Jim, > > > > > > > > I replaced both oil temp gages on our 88 FC ( 3208 oil and > rear > > > axle > > > > temps) BB gage part number 54438, It is a Teleflex gage. > > > > > > > > If this is your gage the temp sensor is a Stewart-Warner, > part > > > > number 280EEF . It is available at truck parts stores. It has > > > > several threaded bushings for all thread sizes, One will > match the > > > > original threads. BB did not have the correct sensor. > > > > > > > > Bill 88 FC Michigan > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > > > > wrote: > > > > > > > > > > I have just replace my oil temp guage. I got it from BB and > it is > > > > indexed differently from the original one. I needed to get a > new > > > temp > > > > sending switch also... > > > > > > > > > > Jim Riordan > > > > > 88 WBWL XXV > > > > > Stuart, Fl. > > > > > > > > > > "Ralph L. Fullenwider" > > > > > Hi Art: > > > > > > > > > > **CAUTION** **CAUTION** > > > > > > > > > > Remove the 4 bottom out side covers of the lower dash. If > the > > > lower > > > > dash > > > > > has been out before then it should lift up from the front > edge > > > and > > > > slip > > > > > forward a little. If it has not been out before then on the > left > > > > side of > > > > > the lower dash, under one of the blank covers, will be a > screw > > > that > > > > has to > > > > > come out. > > > > > > > > > > Now, with the lower dash panel slid forward, remove the cb > mic > > > from > > > > the > > > > > holder and take the long screw out that holds the cb mic > holder. > > > > Now the > > > > > upper lower dash should be free on that side and if it has > been > > > > removed it > > > > > will probably be free to tilt forward. If it has not been > out > > > > before then > > > > > you need a looooong phillips screwdriver, hold the right > side of > > > > the upper > > > > > lower dash out and reach in with the long phillips and un > screw > > > the > > > > far > > > > > left L bracket. In the bottom center of the upper lower > dash, > > > after > > > > the > > > > > lower panel is moved forward you should see a screw that > needs to > > > > come out > > > > > as well. Now your upper lower dash panel should be free to > tilt > > > > forward. > > > > > **CAUTION** Do NOT force it, if it won't come out enough to > > > replace > > > > the > > > > > gauge, find what is holding it. I cannot stress **CAUTION** > > > enough > > > > on this. > > > > > > > > > > While your in there, remove the light sockets with the > lamps from > > > > the other > > > > > gauges and clean or replace them. > > > > > > > > > > Your going to find a "rats nest" of wiring under and behind > both > > > > panels. > > > > > Remember if you drill, spindle or pierce any of those > panels, > > > they > > > > are shot > > > > > and cannot be brought back. Use only holes provided for > screws > > > and > > > > such. > > > > > > > > > > Good luck > > > > > > > > > > Safe travels, > > > > > > > > > > Ralph and Charolette Fullenwider > > > > > 84FC35 > > > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > > > > > At 06:44 PM 5/10/2007 +0000, you wrote: > > > > > >I have recieved a new engine oil temp guage from the > fellow I > > > > bought > > > > > >my coach from. Now to install it. The guage is on the > verticle > > > > part of > > > > > >the dash panel.Has anyone been into that panel? Any advise > will > > > be > > > > > >better than me going in there blind! > > > > > > > > > > > > > > > > > >Art Weatherly > > > > > >Riverside Ca. > > > > > >'85 PT36 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > > > Moody friends. Drama queens. Your life? Nope! - their life, > your > > > > story. > > > > > Play Sims Stories at Yahoo! Games. > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > > Be a PS3 game guru. > > > > Get your game face on with the latest PS3 news and previews > at > > > Yahoo! Games. > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > --------------------------------- > > Yahoo! oneSearch: Finally, mobile search that gives answers, not > web links. > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > |
06-09-2007, 14:28
Post: #35
You are correct based on what I have learned. Teleflex does not have a retail
department. The Teleflex tech department has been very helpful as has West Marine here in Fort Walton Beach. BB sent me a tranny sender for the oil temp gauge . I will install that because I am sure mine is the original. Problem is, if the computer doesn't have the info, substituted product or otherwise, no one knows. That is not a knock on BB, that is the electronic world in which we live. Not necessarily a perfect world. I will post all the pn's when I get it figured out. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Power went down this afternoon in a Thunderstorm and everything blacked out including the computer. Same thing happened during Hurricane Katrina for 7 days. I learned to like cold water. ![]() ----- Original Message --.--- From: pattypape To: WanderlodgeForum@yahoogroups.com Sent: Saturday, June 09, 2007 9:13 PM Subject: [WanderlodgeForum] Re: Installing new guage. Leroy, We are learning, I have not found a dealer that stocks the Teleflex gages, West Marine will special order ,But your part numbers must be correct, or you may own the mistake. BB has gages , but as of my last experiences their sensors do not match. So it is best to get the correct part numbers from Joe at Teleflex Marine tech support. Bill 88 FC --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Thanks Bill. I received your e-mail and answered it. You didn't receive my response so here it is. Seems like the electronicworld doesn't always get r done. They gotta dig up some more cable to keep it going. > I e-mailed the company and they do not stock the parts. I suppose I can order them. I also contacted Teleflex and have a list of senders by part number and ID that will work . I e-mailed Earl at BB and have not heard back. I expect to hear form him on Monday. I have found I get a very rapid response from BB via e-mail. > One would concluded that senders would be available for the gauges. What I have determined is this. The International Line is shipped primarily to manufacturers. Boats, motorhomes etc. That is the market. > I certainly appreciate your help. > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: pattypape > To: WanderlodgeForum@yahoogroups.com > Sent: Saturday, June 09, 2007 7:04 PM > Subject: [WanderlodgeForum] Re: Installing new guage. > > > > Recently My Happy Mouse trigger finger sent a few replys direct to an > e-mail address rather than to the forum posting. > > So, I hope this answer to Leroy can help someone, This has worked on > our 88 FC using the replacement BB/Teleflex oil temp gage # 9153278. > > This sensor will work correctly with the oil temp gage.It has > several different bushings with various thread sizes to fit the > engine block ports. Stewart-Warner part # SW280 EE-F > Available at a big truck parts store or I purchased from South West > Brake, 248-486-9866 about $15 to 20.00. > I do not know about the water temp gages or sensors. And Yes, the > bezels can be exchanged with the new gage to match the other dash > gages. > > Bill 88 FC Michigan > > --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > > > > Ok. Jim in FL and Bill in MI > > I received the gauges from BB. The engine oil temp gauge is > Teleflex pn 9153278 and is a substitute for the original gauge. The > index begins with 140 and the bezel is different. I believe the > original bezel can be placed on this gauge but I have decided to > paint the elevated ring silver with a paint stick. The genset water > temp gauge has the same index (from memory I will verify this w/e) > and the same bezel as the engine oil temp gauge. The genset oil > pressure gauge has the same index and the same bezel as the original > gauge. Go figure that out. All of them have new Teleflex pn's. The > faces are virtually identical. > > BB sent me a tranny sender for the engine oil pressure gauge. I > will put that on the tranny. > > Jim, based on your post should I call Teleflex and order the sender > for the new configuration gauge? > > Thanks; > > Leroy Eckert > > 1990WB-40"Smoke N Mirrors" > > Niceville, FL > > ----- Original Message ----- > > From: jim riordan > > To: WanderlodgeForum@yahoogroups.com > > Sent: Tuesday, June 05, 2007 8:16 AM > > Subject: Re: [WanderlodgeForum] Installing new guage. > > > > > > Leroy, > > > > I just replaced many flaky guages on my coach. I got the new > guage from BB. the indexing was different and better. I called BB > (earl) to get the correct (new) sending unit he sent me the wrong one! > an 028 I then called teleflex Joe Federsal and spoke to him he sent > the correct one an 032, i called earl and told him that he needed to > check with Teleflex about stocking the correct sending unit for this > guage. The guage is better because it is more presise than the old > one. > > Jim Riordan > > 88 WBWL XXV > > > > Leroy Eckert > > Thanks Howard: > > I'll give them a call. > > Leroy Eckert > > 1990WB-40"Smoke N Mirrors" > > Niceville, FL > > ----- Original Message ----- > > From: truitt44@ > > To: WanderlodgeForum@yahoogroups.com > > Sent: Monday, June 04, 2007 9:25 AM > > Subject: [WanderlodgeForum] Installing new guage. > > > > Leroy, > > Contact Chuck at APT Instruments in Bloomington, Mn. about > servicing Teleflex gauges 952-881-7095. > > Howard Truitt > > Camilla, Ga. > > 86 PT40 > > > > > > > > From: "Leroy Eckert" > > > Date: 2007/06/04 Mon AM 09:59:05 EDT > > > To: > > > Subject: Re: [WanderlodgeForum] Re: Installing new guage. > > > > > > > > > I want to pass along information I am receiving from Teleflex, > Bluebird and other suppliers I e-mailed over the weekend. Oil > Temperature gauge 54438 Bluebird part number 3865334 shows to be in > stock at Bluebird today. I will see if the indexing is the same when > I receive it. According to Teleflex this and other Teleflex gauges > Bluebird used are no longer in production and are no longer available > if Bluebird does not have inventory. I am replacing 3 flakey gauges > now while they are available. > > > Steve Birtles and I are searching for an instrument shop to > rebuild the original gauges. I would like to keep my bird dash > looking original. In the long term that may be difficult to do. > > > > > > Leroy Eckert > > > 1990WB-40"Smoke N Mirrors" > > > Niceville, FL > > > > > > ----- Original Message ----- > > > From: pattypape > > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Saturday, May 12, 2007 9:36 AM > > > Subject: [WanderlodgeForum] Re: Installing new guage. > > > > > > > > > > > > Jim, > > > > > > Yep, that is the correct gage, Teleflex # 9153278. > > > > > > The BB# 54438 was still a good number, But > > > they shipped the updated 9153278 gage , Then the temp would read > > > really high, That is why there is a lot of confusion , when > > > replacing gages, the sensor must be replaced also. > > > I like the new scale for the oil temp,200 to 230 > > > Not so good for the rear axle because, it only heats up to > about > > > 140 to 170. lowest part of the gage. > > > > > > Bill 88 FC Michigan > > > > > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > > > wrote: > > > > > > > > Thanks, > > > > > > > > The new guage is not a 54438 Earl said the did not maske it > > > anymore. He sent me a "superseded" one the index numbers were > > > different. He sent me a new sensor it was for the old type > guage it > > > was reading 40% high. I called Teleflex spoke to Joe Federsal > (great > > > help) he sent me the correct sensor for the guage that I got > from > > > earl, everything seems to work now. This new guage 9153278 is > > > improved in that it first register point is at 140 rather than > 100, > > > top is 320 like the old one. the end result is that the gauge > will > > > provide more accurate readings in the operational range than > the old > > > one. I hope! > > > > > > > > > > > > Jim RIordan > > > > 88 WBWL XXV > > > > Stuart, Fl. > > > > pattypape > > > > > > > > > > > > Jim, > > > > > > > > I replaced both oil temp gages on our 88 FC ( 3208 oil and > rear > > > axle > > > > temps) BB gage part number 54438, It is a Teleflex gage. > > > > > > > > If this is your gage the temp sensor is a Stewart-Warner, > part > > > > number 280EEF . It is available at truck parts stores. It has > > > > several threaded bushings for all thread sizes, One will > match the > > > > original threads. BB did not have the correct sensor. > > > > > > > > Bill 88 FC Michigan > > > > > > > > --- In WanderlodgeForum@yahoogroups.com, jim riordan > > > > wrote: > > > > > > > > > > I have just replace my oil temp guage. I got it from BB and > it is > > > > indexed differently from the original one. I needed to get a > new > > > temp > > > > sending switch also... > > > > > > > > > > Jim Riordan > > > > > 88 WBWL XXV > > > > > Stuart, Fl. > > > > > > > > > > "Ralph L. Fullenwider" > > > > > Hi Art: > > > > > > > > > > **CAUTION** **CAUTION** > > > > > > > > > > Remove the 4 bottom out side covers of the lower dash. If > the > > > lower > > > > dash > > > > > has been out before then it should lift up from the front > edge > > > and > > > > slip > > > > > forward a little. If it has not been out before then on the > left > > > > side of > > > > > the lower dash, under one of the blank covers, will be a > screw > > > that > > > > has to > > > > > come out. > > > > > > > > > > Now, with the lower dash panel slid forward, remove the cb > mic > > > from > > > > the > > > > > holder and take the long screw out that holds the cb mic > holder. > > > > Now the > > > > > upper lower dash should be free on that side and if it has > been > > > > removed it > > > > > will probably be free to tilt forward. If it has not been > out > > > > before then > > > > > you need a looooong phillips screwdriver, hold the right > side of > > > > the upper > > > > > lower dash out and reach in with the long phillips and un > screw > > > the > > > > far > > > > > left L bracket. In the bottom center of the upper lower > dash, > > > after > > > > the > > > > > lower panel is moved forward you should see a screw that > needs to > > > > come out > > > > > as well. Now your upper lower dash panel should be free to > tilt > > > > forward. > > > > > **CAUTION** Do NOT force it, if it won't come out enough to > > > replace > > > > the > > > > > gauge, find what is holding it. I cannot stress **CAUTION** > > > enough > > > > on this. > > > > > > > > > > While your in there, remove the light sockets with the > lamps from > > > > the other > > > > > gauges and clean or replace them. > > > > > > > > > > Your going to find a "rats nest" of wiring under and behind > both > > > > panels. > > > > > Remember if you drill, spindle or pierce any of those > panels, > > > they > > > > are shot > > > > > and cannot be brought back. Use only holes provided for > screws > > > and > > > > such. > > > > > > > > > > Good luck > > > > > > > > > > Safe travels, > > > > > > > > > > Ralph and Charolette Fullenwider > > > > > 84FC35 > > > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > > > > > At 06:44 PM 5/10/2007 +0000, you wrote: > > > > > >I have recieved a new engine oil temp guage from the > fellow I > > > > bought > > > > > >my coach from. Now to install it. The guage is on the > verticle > > > > part of > > > > > >the dash panel.Has anyone been into that panel? Any advise > will > > > be > > > > > >better than me going in there blind! > > > > > > > > > > > > > > > > > >Art Weatherly > > > > > >Riverside Ca. > > > > > >'85 PT36 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > > > Moody friends. Drama queens. Your life? Nope! - their life, > your > > > > story. > > > > > Play Sims Stories at Yahoo! Games. > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > > Be a PS3 game guru. > > > > Get your game face on with the latest PS3 news and previews > at > > > Yahoo! Games. > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > --------------------------------- > > Yahoo! oneSearch: Finally, mobile search that gives answers, not > web links. > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
06-09-2007, 17:03
Post: #36
Bill,
Thank you for your call a few days back...and your insite is right on. Folks, pay attention...me too. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. pattypape wrote: > > Leroy, > > We are learning, I have not found a dealer that stocks the Teleflex > gages, West Marine will special order ,But your part numbers must be > correct, or you may own the mistake. > BB has gages , but as of my last experiences their sensors do not > match. So it is best to get the correct part numbers from Joe at > Teleflex Marine tech support. > > Bill 88 FC > > --- In WanderlodgeForum@yahoogroups.com > > > > > > Thanks Bill. I received your e-mail and answered it. You didn't > receive my response so here it is. Seems like the electronic> world doesn't always get r done. They gotta dig up some more cable to > keep it going. > > I e-mailed the company and they do not stock the parts. I suppose I > can order them. I also contacted Teleflex and have a list of senders > by part number and ID that will work . I e-mailed Earl at BB and have > not heard back. I expect to hear form him on Monday. I have found I > get a very rapid response from BB via e-mail. > > One would concluded that senders would be available for the gauges. > What I have determined is this. The International Line is shipped > primarily to manufacturers. Boats, motorhomes etc. That is the > market. > > I certainly appreciate your help. > > Leroy Eckert > > 1990 WB-40"Smoke N Mirrors" > > Niceville, FL > > ----- Original Message ----- > > From: pattypape > > To: WanderlodgeForum@yahoogroups.com > > > Sent: Saturday, June 09, 2007 7:04 PM > > Subject: [WanderlodgeForum] Re: Installing new guage. > > > > > > > > Recently My Happy Mouse trigger finger sent a few replys direct > to an > > e-mail address rather than to the forum posting. > > > > So, I hope this answer to Leroy can help someone, This has worked > on > > our 88 FC using the replacement BB/Teleflex oil temp gage # > 9153278. > > > > This sensor will work correctly with the oil temp gage.It has > > several different bushings with various thread sizes to fit the > > engine block ports. Stewart-Warner part # SW280 EE-F > > Available at a big truck parts store or I purchased from South > West > > Brake, 248-486-9866 about $15 to 20.00. > > I do not know about the water temp gages or sensors. And Yes, the > > bezels can be exchanged with the new gage to match the other dash > > gages. > > > > Bill 88 FC Michigan > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > Ok. Jim in FL and Bill in MI > > > I received the gauges from BB. The engine oil temp gauge is > > Teleflex pn 9153278 and is a substitute for the original gauge. > The > > index begins with 140 and the bezel is different. I believe the > > original bezel can be placed on this gauge but I have decided to > > paint the elevated ring silver with a paint stick. The genset > water > > temp gauge has the same index (from memory I will verify this > w/e) > > and the same bezel as the engine oil temp gauge. The genset oil > > pressure gauge has the same index and the same bezel as the > original > > gauge. Go figure that out. All of them have new Teleflex pn's. > The > > faces are virtually identical. > > > BB sent me a tranny sender for the engine oil pressure gauge. I > > will put that on the tranny. > > > Jim, based on your post should I call Teleflex and order the > sender > > for the new configuration gauge? > > > Thanks; > > > Leroy Eckert > > > 1990WB-40"Smoke N Mirrors" > > > Niceville, FL > > > ----- Original Message ----- > > > From: jim riordan > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Tuesday, June 05, 2007 8:16 AM > > > Subject: Re: [WanderlodgeForum] Installing new guage. > > > > > > > > > Leroy, > > > > > > I just replaced many flaky guages on my coach. I got the new > > guage from BB. the indexing was different and better. I called BB > > (earl) to get the correct (new) sending unit he sent me the wrong > one! > > an 028 I then called teleflex Joe Federsal and spoke to him he > sent > > the correct one an 032, i called earl and told him that he needed > to > > check with Teleflex about stocking the correct sending unit for > this > > guage. The guage is better because it is more presise than the > old > > one. > > > Jim Riordan > > > 88 WBWL XXV > > > > > > Leroy Eckert > > > Thanks Howard: > > > I'll give them a call. > > > Leroy Eckert > > > 1990WB-40"Smoke N Mirrors" > > > Niceville, FL > > > ----- Original Message ----- > > > From: truitt44@ > > > To: WanderlodgeForum@yahoogroups.com > > > > Sent: Monday, June 04, 2007 9:25 AM > > > Subject: [WanderlodgeForum] Installing new guage. > > > > > > Leroy, > > > Contact Chuck at APT Instruments in Bloomington, Mn. about > > servicing Teleflex gauges 952-881-7095. > > > Howard Truitt > > > Camilla, Ga. > > > 86 PT40 > > > > > > > > > > > From: "Leroy Eckert" > > > > Date: 2007/06/04 Mon AM 09:59:05 EDT > > > > To: > > > > Subject: Re: [WanderlodgeForum] Re: Installing new guage. > > > > > > > > > > > > I want to pass along information I am receiving from > Teleflex, > > Bluebird and other suppliers I e-mailed over the weekend. Oil > > Temperature gauge 54438 Bluebird part number 3865334 shows to be > in > > stock at Bluebird today. I will see if the indexing is the same > when > > I receive it. According to Teleflex this and other Teleflex > gauges > > Bluebird used are no longer in production and are no longer > available > > if Bluebird does not have inventory. I am replacing 3 flakey > gauges > > now while they are available. > > > > Steve Birtles and I are searching for an instrument shop to > > rebuild the original gauges. I would like to keep my bird dash > > looking original. In the long term that may be difficult to do. > > > > > > > > Leroy Eckert > > > > 1990WB-40"Smoke N Mirrors" > > > > Niceville, FL > > > > > > > > ----- Original Message ----- > > > > From: pattypape > > > > To: WanderlodgeForum@yahoogroups.com > > > > > Sent: Saturday, May 12, 2007 9:36 AM > > > > Subject: [WanderlodgeForum] Re: Installing new guage. > > > > > > > > > > > > > > > > Jim, > > > > > > > > Yep, that is the correct gage, Teleflex # 9153278. > > > > > > > > The BB# 54438 was still a good number, But > > > > they shipped the updated 9153278 gage , Then the temp would > read > > > > really high, That is why there is a lot of confusion , when > > > > replacing gages, the sensor must be replaced also. > > > > I like the new scale for the oil temp,200 to 230 > > > > Not so good for the rear axle because, it only heats up to > > about > > > > 140 to 170. lowest part of the gage. > > > > > > > > Bill 88 FC Michigan > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > wrote: > > > > > > > > > > Thanks, > > > > > > > > > > The new guage is not a 54438 Earl said the did not maske it > > > > anymore. He sent me a "superseded" one the index numbers were > > > > different. He sent me a new sensor it was for the old type > > guage it > > > > was reading 40% high. I called Teleflex spoke to Joe Federsal > > (great > > > > help) he sent me the correct sensor for the guage that I got > > from > > > > earl, everything seems to work now. This new guage 9153278 is > > > > improved in that it first register point is at 140 rather > than > > 100, > > > > top is 320 like the old one. the end result is that the gauge > > will > > > > provide more accurate readings in the operational range than > > the old > > > > one. I hope! > > > > > > > > > > > > > > > Jim RIordan > > > > > 88 WBWL XXV > > > > > Stuart, Fl. > > > > > pattypape > > > > > > > > > > > > > > > Jim, > > > > > > > > > > I replaced both oil temp gages on our 88 FC ( 3208 oil and > > rear > > > > axle > > > > > temps) BB gage part number 54438, It is a Teleflex gage. > > > > > > > > > > If this is your gage the temp sensor is a Stewart-Warner, > > part > > > > > number 280EEF . It is available at truck parts stores. It > has > > > > > several threaded bushings for all thread sizes, One will > > match the > > > > > original threads. BB did not have the correct sensor. > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > wrote: > > > > > > > > > > > > I have just replace my oil temp guage. I got it from BB > and > > it is > > > > > indexed differently from the original one. I needed to get > a > > new > > > > temp > > > > > sending switch also... > > > > > > > > > > > > Jim Riordan > > > > > > 88 WBWL XXV > > > > > > Stuart, Fl. > > > > > > > > > > > > "Ralph L. Fullenwider" > > > > > > Hi Art: > > > > > > > > > > > > **CAUTION** **CAUTION** > > > > > > > > > > > > Remove the 4 bottom out side covers of the lower dash. If > > the > > > > lower > > > > > dash > > > > > > has been out before then it should lift up from the front > > edge > > > > and > > > > > slip > > > > > > forward a little. If it has not been out before then on > the > > left > > > > > side of > > > > > > the lower dash, under one of the blank covers, will be a > > screw > > > > that > > > > > has to > > > > > > come out. > > > > > > > > > > > > Now, with the lower dash panel slid forward, remove the > cb > > mic > > > > from > > > > > the > > > > > > holder and take the long screw out that holds the cb mic > > holder. > > > > > Now the > > > > > > upper lower dash should be free on that side and if it > has > > been > > > > > removed it > > > > > > will probably be free to tilt forward. If it has not been > > out > > > > > before then > > > > > > you need a looooong phillips screwdriver, hold the right > > side of > > > > > the upper > > > > > > lower dash out and reach in with the long phillips and un > > screw > > > > the > > > > > far > > > > > > left L bracket. In the bottom center of the upper lower > > dash, > > > > after > > > > > the > > > > > > lower panel is moved forward you should see a screw that > > needs to > > > > > come out > > > > > > as well. Now your upper lower dash panel should be free > to > > tilt > > > > > forward. > > > > > > **CAUTION** Do NOT force it, if it won't come out enough > to > > > > replace > > > > > the > > > > > > gauge, find what is holding it. I cannot stress > **CAUTION** > > > > enough > > > > > on this. > > > > > > > > > > > > While your in there, remove the light sockets with the > > lamps from > > > > > the other > > > > > > gauges and clean or replace them. > > > > > > > > > > > > Your going to find a "rats nest" of wiring under and > behind > > both > > > > > panels. > > > > > > Remember if you drill, spindle or pierce any of those > > panels, > > > > they > > > > > are shot > > > > > > and cannot be brought back. Use only holes provided for > > screws > > > > and > > > > > such. > > > > > > > > > > > > Good luck > > > > > > > > > > > > Safe travels, > > > > > > > > > > > > Ralph and Charolette Fullenwider > > > > > > 84FC35 > > > > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > > > > > > > At 06:44 PM 5/10/2007 +0000, you wrote: > > > > > > >I have recieved a new engine oil temp guage from the > > fellow I > > > > > bought > > > > > > >my coach from. Now to install it. The guage is on the > > verticle > > > > > part of > > > > > > >the dash panel.Has anyone been into that panel? Any > advise > > will > > > > be > > > > > > >better than me going in there blind! > > > > > > > > > > > > > > > > > > > > >Art Weatherly > > > > > > >Riverside Ca. > > > > > > >'85 PT36 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > > > > Moody friends. Drama queens. Your life? Nope! - their > life, > > your > > > > > story. > > > > > > Play Sims Stories at Yahoo! Games. > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > > > Be a PS3 game guru. > > > > > Get your game face on with the latest PS3 news and previews > > at > > > > Yahoo! Games. > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > --------------------------------- > > > Yahoo! oneSearch: Finally, mobile search that gives answers, > not > > web links. > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > |
06-10-2007, 11:06
Post: #37
Curt,
Thanks and you are welcome, Good to hear your voice. On another note; I think we aided in an ACE hardware inventory shortage. No fuzzy pile in the Mid-West. Amazing what an impact this Forum has on the world. ![]() and possibly the financial community,,,, ![]() Bill 88 FC Michigan. --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Bill, > Thank you for your call a few days back...and your insite is right on. > Folks, pay attention...me too. > > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. > > > > pattypape wrote: > > > > > Leroy, > > > > We are learning, I have not found a dealer that stocks the Teleflex > > gages, West Marine will special order ,But your part numbers must be > > correct, or you may own the mistake. > > BB has gages , but as of my last experiences their sensors do not > > match. So it is best to get the correct part numbers from Joe at > > Teleflex Marine tech support. > > > > Bill 88 FC > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > Thanks Bill. I received your e-mail and answered it. You didn't > > receive my response so here it is. Seems like the electronic> > world doesn't always get r done. They gotta dig up some more cable to > > keep it going. > > > I e-mailed the company and they do not stock the parts. I suppose I > > can order them. I also contacted Teleflex and have a list of senders > > by part number and ID that will work . I e-mailed Earl at BB and have > > not heard back. I expect to hear form him on Monday. I have found I > > get a very rapid response from BB via e-mail. > > > One would concluded that senders would be available for the gauges. > > What I have determined is this. The International Line is shipped > > primarily to manufacturers. Boats, motorhomes etc. That is the > > market. > > > I certainly appreciate your help. > > > Leroy Eckert > > > 1990 WB-40"Smoke N Mirrors" > > > Niceville, FL > > > ----- Original Message ----- > > > From: pattypape > > > To: WanderlodgeForum@yahoogroups.com > > > > > Sent: Saturday, June 09, 2007 7:04 PM > > > Subject: [WanderlodgeForum] Re: Installing new guage. > > > > > > > > > > > > Recently My Happy Mouse trigger finger sent a few replys direct > > to an > > > e-mail address rather than to the forum posting. > > > > > > So, I hope this answer to Leroy can help someone, This has worked > > on > > > our 88 FC using the replacement BB/Teleflex oil temp gage # > > 9153278. > > > > > > This sensor will work correctly with the oil temp gage.It has > > > several different bushings with various thread sizes to fit the > > > engine block ports. Stewart-Warner part # SW280 EE-F > > > Available at a big truck parts store or I purchased from South > > West > > > Brake, 248-486-9866 about $15 to 20.00. > > > I do not know about the water temp gages or sensors. And Yes, the > > > bezels can be exchanged with the new gage to match the other dash > > > gages. > > > > > > Bill 88 FC Michigan > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > > > > Ok. Jim in FL and Bill in MI > > > > I received the gauges from BB. The engine oil temp gauge is > > > Teleflex pn 9153278 and is a substitute for the original gauge. > > The > > > index begins with 140 and the bezel is different. I believe the > > > original bezel can be placed on this gauge but I have decided to > > > paint the elevated ring silver with a paint stick. The genset > > water > > > temp gauge has the same index (from memory I will verify this > > w/e) > > > and the same bezel as the engine oil temp gauge. The genset oil > > > pressure gauge has the same index and the same bezel as the > > original > > > gauge. Go figure that out. All of them have new Teleflex pn's. > > The > > > faces are virtually identical. > > > > BB sent me a tranny sender for the engine oil pressure gauge. I > > > will put that on the tranny. > > > > Jim, based on your post should I call Teleflex and order the > > sender > > > for the new configuration gauge? > > > > Thanks; > > > > Leroy Eckert > > > > 1990WB-40"Smoke N Mirrors" > > > > Niceville, FL > > > > ----- Original Message ----- > > > > From: jim riordan > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > Sent: Tuesday, June 05, 2007 8:16 AM > > > > Subject: Re: [WanderlodgeForum] Installing new guage. > > > > > > > > > > > > Leroy, > > > > > > > > I just replaced many flaky guages on my coach. I got the new > > > guage from BB. the indexing was different and better. I called BB > > > (earl) to get the correct (new) sending unit he sent me the wrong > > one! > > > an 028 I then called teleflex Joe Federsal and spoke to him he > > sent > > > the correct one an 032, i called earl and told him that he needed > > to > > > check with Teleflex about stocking the correct sending unit for > > this > > > guage. The guage is better because it is more presise than the > > old > > > one. > > > > Jim Riordan > > > > 88 WBWL XXV > > > > > > > > Leroy Eckert > > > > Thanks Howard: > > > > I'll give them a call. > > > > Leroy Eckert > > > > 1990WB-40"Smoke N Mirrors" > > > > Niceville, FL > > > > ----- Original Message ----- > > > > From: truitt44@ > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > Sent: Monday, June 04, 2007 9:25 AM > > > > Subject: [WanderlodgeForum] Installing new guage. > > > > > > > > Leroy, > > > > Contact Chuck at APT Instruments in Bloomington, Mn. about > > > servicing Teleflex gauges 952-881-7095. > > > > Howard Truitt > > > > Camilla, Ga. > > > > 86 PT40 > > > > > > > > > > > > > > From: "Leroy Eckert" > > > > > Date: 2007/06/04 Mon AM 09:59:05 EDT > > > > > To: > > > > > Subject: Re: [WanderlodgeForum] Re: Installing new guage. > > > > > > > > > > > > > > > I want to pass along information I am receiving from > > Teleflex, > > > Bluebird and other suppliers I e-mailed over the weekend. Oil > > > Temperature gauge 54438 Bluebird part number 3865334 shows to be > > in > > > stock at Bluebird today. I will see if the indexing is the same > > when > > > I receive it. According to Teleflex this and other Teleflex > > gauges > > > Bluebird used are no longer in production and are no longer > > available > > > if Bluebird does not have inventory. I am replacing 3 flakey > > gauges > > > now while they are available. > > > > > Steve Birtles and I are searching for an instrument shop to > > > rebuild the original gauges. I would like to keep my bird dash > > > looking original. In the long term that may be difficult to do. > > > > > > > > > > Leroy Eckert > > > > > 1990WB-40"Smoke N Mirrors" > > > > > Niceville, FL > > > > > > > > > > ----- Original Message ----- > > > > > From: pattypape > > > > > To: WanderlodgeForum@yahoogroups.com > > > > > > > Sent: Saturday, May 12, 2007 9:36 AM > > > > > Subject: [WanderlodgeForum] Re: Installing new guage. > > > > > > > > > > > > > > > > > > > > Jim, > > > > > > > > > > Yep, that is the correct gage, Teleflex # 9153278. > > > > > > > > > > The BB# 54438 was still a good number, But > > > > > they shipped the updated 9153278 gage , Then the temp would > > read > > > > > really high, That is why there is a lot of confusion , when > > > > > replacing gages, the sensor must be replaced also. > > > > > I like the new scale for the oil temp,200 to 230 > > > > > Not so good for the rear axle because, it only heats up to > > > about > > > > > 140 to 170. lowest part of the gage. > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > wrote: > > > > > > > > > > > > Thanks, > > > > > > > > > > > > The new guage is not a 54438 Earl said the did not maske it > > > > > anymore. He sent me a "superseded" one the index numbers were > > > > > different. He sent me a new sensor it was for the old type > > > guage it > > > > > was reading 40% high. I called Teleflex spoke to Joe Federsal > > > (great > > > > > help) he sent me the correct sensor for the guage that I got > > > from > > > > > earl, everything seems to work now. This new guage 9153278 is > > > > > improved in that it first register point is at 140 rather > > than > > > 100, > > > > > top is 320 like the old one. the end result is that the gauge > > > will > > > > > provide more accurate readings in the operational range than > > > the old > > > > > one. I hope! > > > > > > > > > > > > > > > > > > Jim RIordan > > > > > > 88 WBWL XXV > > > > > > Stuart, Fl. > > > > > > pattypape > > > > > > > > > > > > > > > > > > Jim, > > > > > > > > > > > > I replaced both oil temp gages on our 88 FC ( 3208 oil and > > > rear > > > > > axle > > > > > > temps) BB gage part number 54438, It is a Teleflex gage. > > > > > > > > > > > > If this is your gage the temp sensor is a Stewart-Warner, > > > part > > > > > > number 280EEF . It is available at truck parts stores. It > > has > > > > > > several threaded bushings for all thread sizes, One will > > > match the > > > > > > original threads. BB did not have the correct sensor. > > > > > > > > > > > > Bill 88 FC Michigan > > > > > > > > > > > > --- In WanderlodgeForum@yahoogroups.com > > > > > > > > > > wrote: > > > > > > > > > > > > > > I have just replace my oil temp guage. I got it from BB > > and > > > it is > > > > > > indexed differently from the original one. I needed to get > > a > > > new > > > > > temp > > > > > > sending switch also... > > > > > > > > > > > > > > Jim Riordan > > > > > > > 88 WBWL XXV > > > > > > > Stuart, Fl. > > > > > > > > > > > > > > "Ralph L. Fullenwider" > > > > > > > Hi Art: > > > > > > > > > > > > > > **CAUTION** **CAUTION** > > > > > > > > > > > > > > Remove the 4 bottom out side covers of the lower dash. If > > > the > > > > > lower > > > > > > dash > > > > > > > has been out before then it should lift up from the front > > > edge > > > > > and > > > > > > slip > > > > > > > forward a little. If it has not been out before then on > > the > > > left > > > > > > side of > > > > > > > the lower dash, under one of the blank covers, will be a > > > screw > > > > > that > > > > > > has to > > > > > > > come out. > > > > > > > > > > > > > > Now, with the lower dash panel slid forward, remove the > > cb > > > mic > > > > > from > > > > > > the > > > > > > > holder and take the long screw out that holds the cb mic > > > holder. > > > > > > Now the > > > > > > > upper lower dash should be free on that side and if it > > has > > > been > > > > > > removed it > > > > > > > will probably be free to tilt forward. If it has not been > > > out > > > > > > before then > > > > > > > you need a looooong phillips screwdriver, hold the right > > > side of > > > > > > the upper > > > > > > > lower dash out and reach in with the long phillips and un > > > screw > > > > > the > > > > > > far > > > > > > > left L bracket. In the bottom center of the upper lower > > > dash, > > > > > after > > > > > > the > > > > > > > lower panel is moved forward you should see a screw that > > > needs to > > > > > > come out > > > > > > > as well. Now your upper lower dash panel should be free > > to > > > tilt > > > > > > forward. > > > > > > > **CAUTION** Do NOT force it, if it won't come out enough > > to > > > > > replace > > > > > > the > > > > > > > gauge, find what is holding it. I cannot stress > > **CAUTION** > > > > > enough > > > > > > on this. > > > > > > > > > > > > > > While your in there, remove the light sockets with the > > > lamps from > > > > > > the other > > > > > > > gauges and clean or replace them. > > > > > > > > > > > > > > Your going to find a "rats nest" of wiring under and > > behind > > > both > > > > > > panels. > > > > > > > Remember if you drill, spindle or pierce any of those > > > panels, > > > > > they > > > > > > are shot > > > > > > > and cannot be brought back. Use only holes provided for > > > screws > > > > > and > > > > > > such. > > > > > > > > > > > > > > Good luck > > > > > > > > > > > > > > Safe travels, > > > > > > > > > > > > > > Ralph and Charolette Fullenwider > > > > > > > 84FC35 > > > > > > > Ralph's RV Solutions, Duncan, Oklahoma > > > > > > > > > > > > > > At 06:44 PM 5/10/2007 +0000, you wrote: > > > > > > > >I have recieved a new engine oil temp guage from the > > > fellow I > > > > > > bought > > > > > > > >my coach from. Now to install it. The guage is on the > > > verticle > > > > > > part of > > > > > > > >the dash panel.Has anyone been into that panel? Any > > advise > > > will > > > > > be > > > > > > > >better than me going in there blind! > > > > > > > > > > > > > > > > > > > > > > > >Art Weatherly > > > > > > > >Riverside Ca. > > > > > > > >'85 PT36 > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > > > > > Moody friends. Drama queens. Your life? Nope! - their > > life, > > > your > > > > > > story. > > > > > > > Play Sims Stories at Yahoo! Games. > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > --------------------------------- > > > > > > Be a PS3 game guru. > > > > > > Get your game face on with the latest PS3 news and previews > > > at > > > > > Yahoo! Games. > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > --------------------------------- > > > > Yahoo! oneSearch: Finally, mobile search that gives answers, > > not > > > web links. > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > |
Seems like the electronic world doesn't always get r
