Don't loose track of where your rear wheels are!
06-14-2007, 13:19
I found this on another forum. This is an example of where you need to
keep your attention centered on your vehicle and let the othet guy worry about his. Sometimes just stopping is the best solution. http://carsonphotos.net/webpage1497.htm Gardner 78FC33 |
06-14-2007, 13:24
yes, i can see how that could happen on an inside curve. like making a turn and
the rear wheels cut across the corner. Dan 81FC35 ----- Original Message ----- From: Gardner Yeaw To: WanderlodgeForum@yahoogroups.com Sent: Thursday, June 14, 2007 8:19 PM Subject: [WanderlodgeForum] Don't loose track of where your rear wheels are! I found this on another forum. This is an example of where you need to keep your attention centered on your vehicle and let the othet guy worry about his. Sometimes just stopping is the best solution. http://carsonphotos.net/webpage1497.htm Gardner 78FC33 ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.472 / Virus Database: 269.8.15/848 - Release Date: 6/13/2007 12:50 PM [Non-text portions of this message have been removed] |
06-14-2007, 13:59
Surprised the plastic is still relatively in tact...
Scott --- In WanderlodgeForum@yahoogroups.com, "Gardner Yeaw" wrote: > > I found this on another forum. This is an example of where you need to > keep your attention centered on your vehicle and let the othet guy > worry about his. Sometimes just stopping is the best solution. > > http://carsonphotos.net/webpage1497.htm > > Gardner > 78FC33 > |
